04-27-2015, 11:09 PM | #1 |
Rep 1,925
ZCP Steering Heavier than non?
I'm currently in a 2011 E92 ZCP coupe, looking to get back to a sedan. Found a local 2011 sedan, however it doesn't have ZCP. The steering felt quite a bit "lighter" than my coupe. I thought the ZCP was suspension only, is there any difference in the steering weight? Thanks.
Current: 17 OG M2 / R8 Performance
Past Performance Cars: 01 M3, 05 M3, 06 M5, 08 M6, 08 M3, 11 M3, 13 M3, 15 M3, 911 C4S, 911 GTS, 17 M2,R8 V8, R8 RWS |
04-27-2015, 11:14 PM | #2 |
Rep 12,726
short answer; i don't know for sure.
however, zcp cars with nav can change the servo setting via idrive. this may be possible with non-nav cars with the blinker stalk option settings, but again, i don't know. it could have been something that was quietly reworked in the facelift and addition of the zcp package.
Flying Ace4984.50 |
04-28-2015, 08:52 AM | #5 |
Rep 1,366
04-28-2015, 08:58 AM | #6 |
Rep 262
did you feel any change in suspension feel? I noticed my non-ZCP car has a lot more body roll on the track than my friend's ZCP.
2010 E92 SSII DCT, Akra Evo, ESS Tune, Performance Spolier &Splitter, Edition Side Markers, AD08R
04-28-2015, 09:36 AM | #7 | |
Rep 39
The Non-Comp M3 that I have has a light steering because it doesn't have as stiff of a suspension. My theory is all cars with aftermarket suspension or comp or even the new M3/M4 are going to be really stiff/heavy even because the suspension just stiffens up the steering also. |
04-28-2015, 09:50 AM | #8 | |
Rep 747
04-28-2015, 09:52 AM | #9 | |
11817
Rep 23,187
04-28-2015, 10:30 AM | #10 |
Rep 11,891
What's your tire pressure?
22 Phytonic/Coffee X5 45e (CoVID-free)
08 Speed Yellow 911 GT3 Sharkwerks 12 AW/Cinnamon X5d Sports Pkg (retired) 14 AW/Beige M6GC ZCP, MPE, V2 steering wheel, vorsteiner (retired) 08 SSII/Black E90 M3 (retired) |
Three Pedal Steve874.50 |
04-28-2015, 11:09 AM | #11 | |
Rep 4,341
04-28-2015, 11:39 AM | #12 |
Rep 4,488
Tires can also make a difference. When I switched from PSS to AD08R's, the steering got heavier. It wasn't a big deal and within 10 miles I stopped noticing it, but I suppose it would be noticeable in an A/B comparison. The same thing happened when I got my StopTech BBK, only that made the steering lighter. Abnormally low or high tire pressure can also make steering feel unusually heavy or light, respectively.
Lastly, maybe power steering fluid level/age would influence this somewhat too, despite BMW claiming that it's a "lifetime fill" -- which means it will last the lifetime of your power steering setup, right up until it fails from never having had its fluid changed.
Gone but not forgotten: '11.75 M3 E92 Le Mans | Black Nov w/ Alum | 6MT (owned 5/2011 - 11/2015) Last edited by jphughan; 04-28-2015 at 11:50 AM.. |
04-28-2015, 11:42 AM | #14 | |
Rep 3,387
04-28-2015, 11:45 AM | #15 |
Rep 4,488
It's funny, I used to use Sport whenever on back roads and the track (never saw the use for it during casual driving), but recently I've switched to Normal full-time. I think Sport definitely helped smooth out my inputs by requiring them to be more deliberate when I was learning, but now I enjoy the lighter feel, though I admit it's not a really strong preference. I've also noticed that previous BMWs and all Porsches I've tried have steering feel much closer to Normal mode, and a friend who drove my car said that Sport mode made it feel like it weighed an extra 400 pounds.
04-28-2015, 11:54 AM | #16 |
Rep 3,341
My current ZCP steering does feel slightly heavier than my previous civics as does the firmness in comfort...less bounce, more planted. I've got Conti 3's on the ZCP and had PSS's on the civics.
04-28-2015, 12:13 PM | #17 |
Global Moderator
6381
Rep 2,309
Drives: E90 M3 6MT
E9X M3 has the same steering across the board, ZCP be damned.
Only the E46 M3 ZCP had a different steering rack a la CSL.
2011.5 E90 ///M3 | 6-Speed Manual | Slicktop | Jerez Black | Fox Red
E9x M3 Press/Media Archives Thread | S65-based Racing Engines Thread |
04-28-2015, 12:26 PM | #18 |
Rep 11,891
maybe this is the difference between a real M3 and a civic?
04-28-2015, 12:54 PM | #19 |
Rep 7,110
At least when you step up Normal and Sport I hope the EDC better stiffen up and reduce role compared to non EDC or I spent money for nothing mate!
04-28-2015, 01:01 PM | #20 |
Rep 657
alignment settings can also affect steering feel. heck when i changed my rear differential fluid (with FM) i swear the steering felt lighter afterward
04-28-2015, 02:21 PM | #21 |
Rep 4,488
I can't see how this would be anything but placebo effect or something else that happened around the same time. FM fluid is only "inline" to the rear wheels, and the steering rack is only connected to the fronts.
04-28-2015, 02:45 PM | #22 |
Rep 4,341
. Toe in will make it require a little more effort to move from center when driving. Toe out will make jump off center. But tires and pressures make a big difference. Remember zcp has the biggest wheel and contact patch.
