03-05-2010, 06:40 PM | #1 |
Moderator
673
Rep 4,737
More Findings About the M3 GT4 Suspension
Anyone want to give these babies a try?
Front Coil Over Kit (PN: 31308321857/31308321858)
Rear Coil Over Kit (PN: 31308321633)
Sway Bars
Rear Sub-Frame
03-06-2010, 04:37 PM | #7 |
Rep 4,567
25mm adjustable coilovers (at least, I think they're coilovers) by SACHS.
'09 E92 M3: Space Gray, Black, Carbon Leather | ZTP 2MK ZPP 2MT 6FL | link 1 / link 2
Mods: M Performance exhaust | ZCP retrofit | Euro airbox | GTS DCT flash | JPN 240 ECU flash | Euro LCI taillights | CRT lip | OEM alarm retrofit | Space Gray bumper plugs | BMW Performance: Mk. II spoiler / Mk. II non-electronic steering wheel / mirror caps / front grilles / side gills / intake louvers / emblem |
03-06-2010, 05:28 PM | #8 |
Rep 1,144
03-06-2010, 07:27 PM | #9 |
Rep 2,266
these arent from BMW is it?
Edit: nvm, found the thread about this in General Discussion...
Cheers
Ben Last edited by bunnn; 03-06-2010 at 09:15 PM.. |
03-07-2010, 01:06 AM | #10 |
Rep 9,032
Do you need that brace piece for the rear coils?
03-07-2010, 02:10 AM | #11 |
Rep 3,303
Damn, 10k+ just for coil overs.....damn. I thought the GTS had an edc system, no? If so, the EDC system on a non-GTS //M3 would need to be reprogrammed to use these.
Cheers, e46e92
"...it's not about the money and not about the brand of the car, it's about handling,performance and passion......And that, no other car has all together like an M3........when you talk about the most complete car the M is invincible." --Tony Kanaan. |
03-07-2010, 11:32 AM | #12 |
Moderator
673
Rep 4,737
The only other thing is the top mount (Turner sells them) and proper structural support (i.e. brace, roll cage). Though quite a few people with E46 M3 have done a rear coilover conversion w/o any additional structural support, and I haven't heard of any problems.
03-07-2010, 11:56 AM | #13 |
Rep 4,567
The GTS doesn't have EDC.
03-08-2010, 08:03 PM | #16 | |
e36s54, e70x5d
151
Rep 1,723
So you are sure there are no other components to replace or modify to fit this rear coilover kit? If not, that is very cool ... cause it took alot more to convert the e36 and e46 rear to accept a true coilover. |
03-08-2010, 09:19 PM | #17 |
Rep 3,303
No I was thinking GTS and just brain farted...... on me.....
Cheers, e46e92
03-11-2010, 12:39 PM | #18 |
Rep 193
how effective would this suspension be on a standard E92 M3 coupe? Does the fact that the gt4 weighs a few hundred pounds less make this less than ideal for the heftier standard coupe?
03-11-2010, 08:55 PM | #19 |
Moderator
673
Rep 4,737
With the price and available spring rate, this should only be used for serious racers. The GT4 is a few hundred pounds lighter, but you can easily choose stiffer springs based on your needs. The GT4 shocks are adjustable and should work with any reasonable amount of spring rates for the M3.
03-11-2010, 09:35 PM | #21 | |
Moderator
673
Rep 4,737
http://bmwfans.info/parts/catalog/E9...abilizer_rear/ |
03-23-2010, 10:44 PM | #22 | |
Rep 697
http://www.realoem.com/bmw/showparts...11&hg=33&fg=45 |
