12-01-2014, 07:46 AM | #1 |
Rep 40
2008 iPhone 5 and idrive
Guys,
My iPhone 4s just shit the bed. I will be upgrading to the iPhone 5s. Will I sti have full access to my music library on my idrive just like i had with my iPhone. 4s? Keep in mind this car is an 08 m3 and has the older idrive unlike the 2009 and up. I apologize if this question has been asked before. I'm in a rush and my search didn't bring up my answer. |
12-01-2014, 04:14 PM | #2 |
Rep 248
Both my old Iphone 5 and current Iphone 6 work as designed in my 2008 E90 M3 with the same shitty, lame version of Idrive you have.
Hope that helps. |
12-01-2014, 06:45 PM | #4 |
Rep 244
Related question.. I have a 2011 with the snap in iPhone 4 adapter. Can I just get the y cable with the firewire plug and leave the plug in adapter as is? That snap in adapter is a pain, and I like to keep the phone charged anyway.
12-01-2014, 10:32 PM | #5 | |
Rep 4,488
Also note that even if you have the iPhone 4 MEDIA cradle (assuming you have a 2011.75 with BMW Apps), the "iPod Out/PlugIn" and video playback features will not work with an iPhone 5.
12-02-2014, 02:17 AM | #6 |
Rep 4,381
Would something like this work? (iphone 5 and 5s only)
http://www.amazon.co.uk/Vktech-Outpu...for+iphone5S+5 I have one on order but won't be allowed to try it out untill xmas. Last edited by SenorFunkyPants; 12-02-2014 at 03:52 AM.. |
12-02-2014, 07:41 AM | #7 | |
Rep 244
12-02-2014, 11:12 AM | #9 | ||
Rep 4,488
And yes, as mentioned above, Bluetooth audio streaming is also available as of 2011.5, which is much more convenient and avoids the potential for you to forget your phone in your glovebox. It doesn't sound QUITE as good as USB since bandwidth is more limited, so I still connect via USB for longer trips, but Bluetooth being digital still means it sounds as good or better than using AUX via a Y-cable, which is why I use it 95% of the time.
12-02-2014, 11:18 AM | #10 | |
Rep 4,488
12-02-2014, 11:37 AM | #11 |
Rep 4,381
If you are not bothered about charging your device then there are also several bluetooth units that can fit into the glove box and pair with your iphone (for pre- 2011.5 cars).
02-03-2015, 08:22 AM | #12 |
Rep 337
Hi guys - I posted in another sub forum but thought I'd get more response here. I have an 08 and just upgraded to an iPhone 6. I was using the y-cable previously and purchased a 30 pin-to-lightening adapter and that doesn't seem to work. I've also tried using just the usb, but get a "device not supported" message. What am I doing wrong?
02-03-2015, 12:06 PM | #13 |
Rep 212
Sorry, can't answer your question as I'm having the same issue trying to connect with my adapter. Is yours a true Apple brand adapter?
Anyone tried to use this device or something similar? http://www.amazon.com/CoolStream-Blu.../dp/B00GHUHMUS I'm thinking about ordering one to hook up to my Y-Cable and hopefully have Bluetooth audio. |
02-03-2015, 12:44 PM | #15 |
Rep 212
I bought the CoolStream in the link above. I'll let you know if it works. Some said it won't work with BMW but I'm going to try anyway with Amazons great return policy.
Also found this: http://www.amazon.com/ViseeO-Tune2ai.../dp/B00B52LLJ6 Price point is a bit higher but supposedly it will work. Some said it would even tie into the idrive for controlling the iPod like the factory Y-Cable. It's advertised to integrate with Audi MMI so maybe it would play with iDrive as well. |
02-03-2015, 12:49 PM | #16 |
Rep 212
And then I found this....http://www.amazon.com/gp/aw/d/B00R3A...=AC_SX230_QL60
Advertised to work with BMW and a reviewer claiming it works well with his 07' 335i. I'm canceling my order for the CoolStream and ordering the above. |
02-03-2015, 01:58 PM | #17 |
Rep 11,891
OP has a CCC idrive, no Bluetooth streaming.
22 Phytonic/Coffee X5 45e (CoVID-free)
08 Speed Yellow 911 GT3 Sharkwerks 12 AW/Cinnamon X5d Sports Pkg (retired) 14 AW/Beige M6GC ZCP, MPE, V2 steering wheel, vorsteiner (retired) 08 SSII/Black E90 M3 (retired) |
02-03-2015, 02:14 PM | #18 | |
Rep 337
I've heard good things about the Viseo and might go with this if I can't find a hardwire solution. |
02-03-2015, 02:15 PM | #19 |
Rep 337
02-03-2015, 07:08 PM | #20 | ||
Rep 4,488
If you're going to be buying a new adapter anyway, I'd recommend the more expensive one that actually includes some cable length rather than the plastic block version. The reason is that the latter might not connect to your iPhone properly if you have a case, whereas the one with cable length has much less plastic around the Lightning connector side. Once you've got the proper cable, the 08s will continue to need the Y-cable; you'd simply add the adapter to the chain. ///Mvy, Tune2air is known to work well and even allows playback control and I believe song metadata display. The WMA1000 + a Y-cable is equivalent to the 3000B you purchased. The WMA2000 is for cars that actually accept the audio signal over USB, which the pre-2011.5 cars do not, and the 3000A is specific to Audi models, apparently.
Gone but not forgotten: '11.75 M3 E92 Le Mans | Black Nov w/ Alum | 6MT (owned 5/2011 - 11/2015) Last edited by jphughan; 02-03-2015 at 07:19 PM.. |
02-05-2015, 05:19 PM | #22 | |
Rep 979
