      07-29-2021, 01:12 PM   #1
besiktas
Ultimate Driver for the Ultimate Driving Machine
Drives: BMW M3 E92
Fuel gauge/needle is moving while accelerating or decelerating
My ride decided to give me another surprise before its 12th anniversary. I noticed that the fuel needle is moving during accelerating and decelerating significantly. ie almost no gas to more than qtr tank of gas. Trying to figure out how severe ($$$) is the problem. any insights appreciated
BMW M3 E92 - Silverstone II
BPM Sport Stage II Tune + Test Pipes, GTS DCT Tune
      07-30-2021, 01:48 AM   #2
jvictormp
jvictormp's Avatar
Brazil
881
Drives: 2008 M3 E92 6MT
You should check your wiring harness at the right rear wheel well, above the fender liner.
I had exactly that problem for a long time, didn't know how to figure it out.
Someday, because of ABS sensor failure, I had to access the wheel well and remove the fender liner. And there it was, the wiring harness completely split.
Just repaired the wires, problem solved.
Or maybe it was related to the ABS sensors, because the DSC unit makes a huge mess with the car when fails, and mine was faulty. I'll never know. Just solved the two problems at once.
I'll get some pictures.
      07-30-2021, 01:54 AM   #3
jvictormp
jvictormp's Avatar
Brazil
881
DrFerry6728.50
KawBoy154.50
      07-30-2021, 08:06 AM   #4
besiktas
Drives: BMW M3 E92
Interesting that you mentioned ABS because now i have a slew of lights on my dashboard, from airbag to damping control including ABS. The car seems to be running fine though, it just wants me to drop a ton of money at the dealership
      07-30-2021, 08:35 AM   #5
jvictormp
jvictormp's Avatar
Brazil
881
That's EXACTLY what I faced.
Airbag fault
EDC fault
DSC fault
Passenger restraint system fault
Tank level needle oscillating
Onboard computer not showing consumption
Changed all four abs wheel sensors, and repaired the wiring harness mentioned.
Everything came back on flawlessly.
DrFerry6728.50
      08-02-2021, 02:15 PM   #6
jvictormp
jvictormp's Avatar
Brazil
881
besiktas
Please report back when you have news.
      08-03-2021, 03:57 PM   #7
besiktas
Drives: BMW M3 E92
I will. reached out to dealer, waiting to see if they have any deals but SA immediately mentioned that all these symptoms point to wheel speed sensors. Will keep you posted
      08-07-2021, 05:19 AM   #8
G60nut
G60nut's Avatar
42
Drives: 2011 M3
Originally Posted by jvictormp View Post
[IMG]https://www.m3post.com/forums/attachment.php?
attachmentid=2636163&stc=1&d=1624784360[/IMG]
That looks like rodent damage. Maybe a common spot on our cars for them to try to hang out. In a past life I had a customer that brought his truck in for a CEL, It had Evap codes, smoke tested the system and found one of the evap hoses above the fuel tank had been chewed through. He brought it back three times and we had to replace the same chewed through hose each time. and then he got a cat, problem solved lol.
2011 White E92M ZCP
2003 VW Jetta 1.8t
1990 VW Corrado 16vG60
Davisca4552207.50
      08-09-2021, 09:43 PM   #9
jvictormp
jvictormp's Avatar
Brazil
881
You may be right. I had problems with mice when my house was in construction, and I had to let the car sit in the new house garage before moving there definitely.
Once I found some food traces in engine bay, and damn, there they were.
Got some of them killed with traps, but wasn't enough.
It was only over when I moved and brought my cats with me. Maybe you're right.
Davisca4552207.50
      08-14-2021, 09:56 PM   #10
besiktas
Drives: BMW M3 E92
I took the car to the dealership. they told me all 4 ABS wheel sensors are to be replaced and they said this was the trigger of the slew of errors i was having. Also getting my battery replaced (been dying for some time) and air filters replaced in the meantime.
jvictormp881.00
      08-20-2021, 09:59 AM   #11
besiktas
Drives: BMW M3 E92
Update:
Picked car up from dealership today. Had battery replaced along with 3 wheel speed sensors.
Wheel sensors addressed the slew of errors i was getting (ABS, damping control, airbag etc.).
The fuel gauge is now working fine, needle not moving around. I am told its likely due to battery and now is resolved.
      08-20-2021, 10:12 AM   #12
jvictormp
jvictormp's Avatar
Brazil
881
Originally Posted by besiktas View Post
Update:
Nice!
My problem was not due to battery, as it's 2 year old, and I didn't replace it to solve to problem.
But there was the abs sensors and the wiring harness.
      02-25-2024, 05:06 PM   #13
Assimilator1
Assimilator1's Avatar
United Kingdom
594
2010 BMW 330d  [8.00]
2008 BMW M3  [0.00]
Old thread I know, but I just stumbled across it investigating something else.
My 2010 330d had the same problems, ABS lights, no DSC, airbag light, no speedo and fuel gauge giving a (supposedly) live reading.
It turned out that both rear ABS rubber rings disintegrated within 50 miles of each other! (wth are the chances of that!!?? Happened just after going through a big puddle, which was 2-3 minutes after I left home on my way to France!!). The 2nd ABS ring failure caused the speedo to stop working and the fuel gauge to give a live & undamped reading.
Although later on, and before I could replace the wheel bearings, it broke down. Somehow, even though the gauge was still moving a little, it had actually stuck at just under 1/4 of a tank, but I'd run out of fuel!! (remembering that no speedo means no trip counter either). I took the pump in and out, checked it's level sensor, no problem, checked the transfer pump level sensor, also no problem, and it's been fine since!! (and I've run it lower than when it broke down last).
If the ABS loses one sensor that obviously stops that and the DSC working, but if you loose 2 or more it stops the speedo working (+trip and MPG), fuel gauge switches to live-undamped reading, the air bag system stops working because of no speedo reading (even though surely it could read the speed from the remaining sensor(s)!?).
No EDC on my 330d ..... or my M3 come to that.
Pic of bearing, rubber ring breaking up at about the 2pm position.
      02-26-2024, 05:12 AM   #14
amrazM
mTekMods
amrazM's Avatar
Drives: like a granny.
it happens especially with rust, it just falls off. good time for new bearings!
G-Power Supercharged
      02-26-2024, 03:14 PM   #15
Assimilator1
United Kingdom
594
2008 BMW M3  [0.00]
Roger that, well I guess they hadn't done badly at ~140k miles , the bearings themselves were fine, just the pick up rings had failed. Annoying to have to change them for that!
And what are the odds that both failed at virtually the same time!? lol
(btw, I had discussions with the other BMW techs I worked with at the time as to whether the bearings were genuine, but we weren't sure. I can't remember if they were GSK or NSK bearings now, but they were made in England).
      02-27-2024, 05:10 AM   #16
amrazM
mTekMods
amrazM's Avatar
ive seen it on cars that i have worked on in the northeast us alot. when one fails its almost 100% sure the other side is nearly out as well, I hate doing rear wheel bearings on these cars.
      02-27-2024, 01:33 PM   #17
Assimilator1
United Kingdom
594
2008 BMW M3  [0.00]
Interesting to hear, and yea they're a right PITA!
Tags
fuel guage
