  TireRack
      07-22-2013, 06:05 PM   #1
哇靠M3
Taiwan
85
Drives: e92 M3
2009 E92 M3  [9.00]
No rub? Which tires for 18x9.5 ET20 rear & 18x10.5 ET25
Time to run new wheels on the car and switch up a bit.
I'm looking to run 18x9.5 ET20 rear and 18x10.5 ET25 rear. Right now, my car is on stock oem suspensions, but plan on KW v3 or KW sleeve kit. If I do suspensions, I'm not going to be slamming them since this car is my daily driver.
What tire size can I run without rubbing?
      07-23-2013, 05:14 PM   #2
哇靠M3
Taiwan
85
Drives: e92 M3
2009 E92 M3  [9.00]
Wheels will be arriving soon, was hoping someone can help me with tires.
      07-23-2013, 05:21 PM   #3
slicer
slicer's Avatar
2739
265/35/18 front and 285/35/18 rear
I prefer 275/35/18's in the front but there is some potential for rubbing without proper camber.
You have not gotten responses because this information is readily available on the forum. Plus you didn't ask nicely Tons of people run those same wheel sizes.
Here is a thread dedicated to wheel / tire sizing, offsets, suspension settings and rubbing:
http://www.m3post.com/forums/showthread.php?t=522139
'23 X7
'04 M3 - Fall Line Motorsports Built Race Car - S65 swap, Dry Sump, Bosch Stand-Alone ECU, Drenth Sequential Trans, MCS 3-Way, Flossmann Wide Body, Brembo Motorsports Brakes, Drexler LSD, BBS E88 Etc.
INSTAGRAM - @Slicer_M
      07-24-2013, 04:10 PM   #4
哇靠M3
Taiwan
85
Drives: e92 M3
2009 E92 M3  [9.00]
Sounds like that's the way to go.. This should also be good if I decide for a moderate drop on KW right?
Thanks for all your help!
