12-28-2023, 01:33 AM | #1 |
Rep 137
P65 Conversion kit!
I just stumbled across a P65 conversion kit Sold by M24, a race team out of Germany. They make a whole slew of mods for our cars.
Theres a Crankshaft to take it up to 9k rpm too. But the more interesting thing is the S65/P65 4.4l stroker it. It comes with the Z4 GT3 (P65) rotating assembly. I believe you can also buy just the Crankshaft on its own, but I’m not sure that’s just a “drop in” thing. This seems quite Interesting, I know there was someone on here who was trying to P65 swap his E9X. This almost seems just as “easy” as any other stroker kit. But I’d imagine a Vanos delete would be needed. Let’s hope someone is ballsy enough to do this!!! |
12-28-2023, 08:31 AM | #2 |
Rep 5,546
Having a P65 and its sound would be awesome. Only problem with most stroker builds is the relatively low mileage between rebuilds. I suppose limiting max RPM and pure street use will net you a longer rebuild interval but reducing max rpm defeats one of the best reasons for building such an amazing engine - the sound!
M3MATT91.00 |
12-28-2023, 11:56 AM | #3 |
Rep 210
I still think the interval will be longer for a street car vs a full blown track car that’s seeing sustained high rpm pulls lap after lap. I know someone with a dinan 4.6 and he has 96k miles on the motor and has never been rebuilt.
M3MATT91.00 |
12-28-2023, 01:54 PM | #4 | |
Rep 5,546
Here’s why you build a S65 stroker: https://www.m3post.com/forums/showpo...11&postcount=3 Last edited by M3SQRD; 12-28-2023 at 01:59 PM.. |
M3MATT91.00 |
01-03-2024, 02:15 PM | #5 | |
Rep 210
M3MATT91.00 |
01-03-2024, 02:44 PM | #6 |
Rep 5,546
I know. I’m talking about the kit that uses a flat plane crank to build a P65. There’s a couple P65s being built/converted from a S65 to a P65. The link I included is for a s65 4.6 L Carbshn stroker with 292 cams that makes almost 500 whp and originally used in a dedicated track car but the point was to show why you’d build a P65 in the first place - an ultimate track weapon. Building a P65 and then limiting max rpm to increase longevity and using it on the street seems like a huge waste. P motors are true M Motorsport race engines so an original S65 rebuilt into a P65 should spend its life on the track making the glorious sounds only a flat plane crank motor can make! If it’s for street use, just build a S65 cross plane stroker.
gh0stE92M3159.00 |
01-03-2024, 08:34 PM | #7 | |
Rep 210
01-05-2024, 01:06 PM | #8 | |
Rep 137
01-08-2024, 11:24 PM | #9 |
Rep 82
I believe the Z4 GT3 uses a crossplane crank. The e92 GT2 is the one with a flat plane crank.
Cool that it is possible to buy this stuff if your pockets are deep enough though! |
01-09-2024, 03:42 PM | #11 |
Rep 137
01-09-2024, 03:59 PM | #12 |
Rep 5,546
01-09-2024, 10:05 PM | #13 |
Rep 82
Listen to the e92 m3 GT2. They sound completely different. The Z4 sounds similar to an s65 with a crossplane crank. I believe the GT3 crossplane p65 has a different firing order than the road going s65 but it is still a crossplane crank. The flat plane p65 in the e92 GT2 sounds more like a Ferrari (think 458).
Listen for yourself. |
M3MATT91.00 |
01-13-2024, 12:44 AM | #14 | |
Rep 137
One crosses exhaust banks while the other doesn’t Similar to how different the side exit RSR sounds compared to the normal RSR. A lot more “Gnatty” |
01-13-2024, 04:08 AM | #15 | |
Rep 5,546
https://www.m3post.com/forums/showthread.php?t=1065981 |
M3MATT91.00 iamtrashman184.50 |
01-13-2024, 01:57 PM | #16 | |
Rep 137
But they both sound so different due to exhaust setups. Same engine, different exhaust = different sound. |
01-13-2024, 02:14 PM | #17 |
Rep 5,546
I agree the difference in header stepped equal/non-equal length collector designs and exhaust geometry can completely change the sound of an engine. It’s easy to screw up the sound of an engine with badly designed headers. Flat vs cross plane changes the sound even more. Firing order also affects sound. I remember hearing the Honda (Acura badged) IndyCar engines from the early-mid 90s and they were playing around with firing order to maximize torque - it sounded as if it was a new clean-sheet engine design. They may have tweaked header designs as well but it was known they were changing the firing order.
iamtrashman184.50 M3MATT91.00 |
