03-01-2023, 03:00 PM | #1 |
Rep 270
F8X M3/M4 Blue Brakes Upgrade For E9X M3
Anyone seen this kit from Turner? https://www.turnermotorsport.com/p-3...m3/?pdk=AQEBCA
Looks like it is only for the front, would it be possible to get rear calipers to match as well? According to them these do not work with ZCP wheels. Can anyone confirm? Really want a BBK and deciding between this and or StopTech front/rear. |
03-02-2023, 10:31 AM | #2 |
Όλα ρόδες
760
Rep 560
Drives: BMW
Garage List 2004 e46 M3 Convert ... [7.50]
2023 M4 CSL [8.17] 2007 E86 M Coupe [0.00] 2008 e93 M3 [0.00] 2019 M2 Competition [9.67] 2017 f48 X1 xdrive 25d [6.00] |
03-04-2023, 12:33 AM | #3 | |
Rep 1,050
"*Will not ZCP Wheels*" They wouldn't have put that there without reason. This kit uses adapter brackets rather than the f8x spindles. One major advantage of this approach is it will not alter the ride height in the front like the f8x spindle approach does. The major issue here I see is it seems that by using the adapter bracket, it requires custom rotors. The rotors are 382x36mm, with unknown offset, which is not the stock f8x size. The stock m4 rotors are 380x30. Possible that they needed a custom rotor to work with the adapter bracket. Unfortunately, I can't seem to locate the rotors individually on ECS or Turner. The use of the adapter bracket and rotor combination is probably why the ZCP wheels don't work with this kit. Especially when we know doing this conversion using the f8x spindles works fine with the ZCP wheels. I'm not sure I'd want to do the conversion that way, as not being able to use stock size rotors is a major disadvantage. Sourcing replacement rotors would suck compared to being able to use a readily available OEM or aftermarket f8x rotor. |
03-06-2023, 09:05 AM | #4 | |
Rep 270
03-14-2023, 12:36 AM | #5 | |
Rep 1,050
If peak performance is your ultimate goal, a BBK is always the answer. |
