04-11-2024, 09:17 AM | #1 |
Rep 150
Vanos Covers
How good are the vanos covers from Evolve? Im doing NRW valve covers and plugs and everything related very soon. I might as well do the vanos covers as well. What are y'alls thoughts?
04-11-2024, 11:41 PM | #2 | |
Rep 85
I知 also doing the throttle actuators (better rebuild ones) at the same time, as well as the vanos covers. However I opted for the Mporium bolt on vanos covers, I知 not saying the Evolve ones are not good, but the bolt on ones from Mporium look to be a better solution in my personal opinion. The Mporium ones are a bit more labour intensive to fit though, as they require the motor to be re-timed, as they involve removal and replacement of the vanos stretch bolts (if you get the complete kit from Mporium it includes OEM stretch bolts and also the gaskets for the vanos cover housing). |
04-12-2024, 09:16 AM | #3 | |
Rep 150
Johnny E9298.00 |
04-24-2024, 01:30 AM | #4 |
Rep 7
I have a friend whose Vanos unit spring exploded and put a hole in the valve cover and upper timing cover. After seeing this I don't think the clip-on covers can handle that force. Something to think about.
04-24-2024, 02:00 AM | #5 |
Rep 1,138
Your friend had bigger problems than his choice of vanos caps if his spring exploded. The plastic caps would never have prevented that either. Nothing short of Carbahn or Mporium caps would have worked but again, what causes the spring to dislodge in the first place?
amg6975504.50 |
04-25-2024, 02:03 PM | #6 |
Rep 511
I知 going to get my vanos covers changed and NRW valve covers fitted.
Can this be done without changing the oil - or does the oil need to be drained? I知 asking because my oil is only a couple of thousand miles old, so if it doesn稚 need to be drained I壇 rather leave it. |
04-26-2024, 07:42 PM | #8 | |
Rep 85
05-04-2024, 10:09 PM | #9 |
Rep 175
I have the Evolve caps. They're developed by Mr. Vanos so I don't expect them to have issues, but only time will tell. The MPorium/NRW caps are a superior alternative, but the installation is much more involved than the snap on covers. Something to keep in mind if you're planning to DIY.
05-06-2024, 06:29 AM | #10 | |||
Rep 1,042
Agreed they're stronger, but overkill IMO. Quote:
Assuming something else didn't happen, what probably happened to your friend's car is that the plastic cover dis-integrated and the spring gradually walked off. These covers do restrain the spring, but clearly their isn't much force involved or the plastic covers would've failed a long time ago. Clip on ally covers are plenty strong enough to keep the springs in place.
Oil analysis for finding wearing rod bearings?. Collation of oil analysis reports with some rod bearing photos for the M3's S65. My categorisation of pulled rod bearings in the rod bearing condition thread. My updated 'Blown engines' list. |
05-07-2024, 10:37 AM | #11 |
Rep 2,918
Drives: 2011 E93 M3
Regarding clip-on vs captured design...It comes down to whether you want to truly bullet-proof it, or get by with another part that can potentially come loose. I have sold numerous sets of my chromoly cups to owners who have had clip-on covers loosen or come off. Slon's original part seems to be more resilient than the dozens of "me-too" copies new to the market. If you want to go with a clip-on set, support the originator of the design.
The NRW valve covers are a welcome solution, however when it comes to their captured aluminum vanos caps which appear to almost identically duplicate our Mporium chromoly cups, we recommend to do more research. Steel is the risk-free material for this location as this style spring cover replaces the steel washer under the central bolt and is under significant clamping force responsible for maintaining cam timing. You don't replace a steel washer with an aluminum variant. Years ago we were experimenting with aluminum alloys here before settling on chromoly for longevity. |
05-08-2024, 03:28 PM | #12 | |
Rep 1,042
And are you talking about replacement metal ones, and not the OEM plastic ones? I recall reading of a few cases where people found they hadn't fully latched in their replacement metal covers, I could certainly see those coming loose! But it's hardly the makers fault. Btw, FWIW, I have Slon covers, but are they still available with sanctions on Russia? I know they were a little while after Russia invaded Ukraine, but I don't know if they still are.
05-09-2024, 11:50 AM | #13 | |
Rep 2,918
Drives: 2011 E93 M3
The issue goes deeper than the clips alone. The VANOS adjusters themselves are an assembly from multiple parts. There is a "body" and a "lid". The lid is not pinned or positively located radially and therefore some units have a good lip all the way around the adjuster, and some aren't perfectly centered so they don't have a consistent lip around the perimeter of the adjuster for clips to grab onto. This is why some installers note difficulty getting a positive click with the clip ears. Some installers don't have problems because their adjusters happen to have a consistent lip for the clips to grab. Some have problems because some of the clips might not have much to grab. Just another reason we advise against clip-on styles. We have sampled thousands of adjusters over the years so we are aware of this possibility. People with access to a CNC cranking out copies of clip on covers have usually only installed them on a car or two (if even that), so they are not aware of this potential problem from a larger sample pool. It's a main reason why we went away from a clip on style to a captured design. Dinan did the same thing years ago too with their flat disc. We both saw the potential issue, it wasn't because we didn't have the ability to machine a complex part. Some are catching on....and starting to copy our Mporium Cup style design. |
05-10-2024, 01:33 AM | #14 |
Rep 1,042
Hmm, curious, seems very odd that a precision made part (the hub) would have that kind of variance, and yet the plastic ones stay on their for at least several years (until the ones that distort break up at some point).....
05-10-2024, 08:54 AM | #15 | |
Rep 2,918
Drives: 2011 E93 M3
One day when I have time I'll provide evidence showing how the front plate runout on each unit varies. I probably have over 100 adjusters on hand to sample from. |
05-10-2024, 03:51 PM | #16 | |
Rep 1,073
I don't ever want to think about this problem again, and now, I won't. |
deansbimmer3784.00 CamasM3e933224.00 |
05-15-2024, 03:09 PM | #17 | |
Rep 1,042
Are you sure it was on properly in the first place? Knowing how tight they are to clip on, there's no way I can see they could unclip, unless it didn't click home to start with.
