im curious is that 19" wheel also comes in 18"?thank you
154.4KVIEWS
74REPLIES
2APPRECIATES
11-14-2010LAST POST
PrinceSmooth wrote245/35 front, 265/35 rear.anyone got the tires sizes for the 19's?
BoB-O wroteYes, that's true.Hey all,
I've seen two colors for the 18" wheels. One is a dark smoky color and the other is more silver. Anyone know the difference? I heard the dark ones are what ended up on the production units. Is this true?
Thanks,
BoB
KRAL21 wroteNo, 18" and 19" are different in design.im curious is that 19" wheel also comes in 18"?thank you
Best regards, south
maan i love those 19"s but its too big for roads in here
is the m3 able to go over speed bumps or are there problems/???
Carfreak9922 wroteIt's not a F40, it'll do fine.is the m3 able to go over speed bumps or are there problems/???
thanks
Carfreak9922 wroteWith EDC on Comfort you can fly over them.is the m3 able to go over speed bumps or are there problems/???
I posted my measurements here (post #10): http://www.m3post.com/forums/showthread.php?t=127032
Pretty much the only "performance" part on the M3 I am worried about is the brakes....sure 14" rotors sound good....but single piston brakes....come on thats weak...my 20 year old Porsche has 12" 4 piston brembos at EVERY corner...& that thing STOPS...never faded them at the track, even with worn pads!
icemang17 wroteThe number of pistons has no bearing on fade resistance. Pad material and cooling are more important, along with the rotor size. Most tests say the brakes on the E92 are pretty good. Not Porsche quality, but fine unless you track a lot.Pretty much the only "performance" part on the M3 I am worried about is the brakes....sure 14" rotors sound good....but single piston brakes....come on thats weak...my 20 year old Porsche has 12" 4 piston brembos at EVERY corner...& that thing STOPS...never faded them at the track, even with worn pads!
ILC32 wroteTwo piece rotor with aluminum hat weighs less than one piece cast rotor. Four piston StopTech or Brembo ST40/F40 caliper weight less than stock caliper. Look up the respective weights of both on the web and you will see significant savings in weight by going with a similar sized BBK.Of course lighter weight benefits handling.
Bigger rotors and calipers weigh more than smaller rotors and calipers.
Please provide support for your assertion that a BBK weighs less than the stock setup.
sg335 wroteYep, weights of stock vs. Brembo and Stoptech here (post #3): http://www.m3post.com/forums/showthread.php?t=150944Two piece rotor with aluminum hat weighs less than one piece cast rotor. Four piston StopTech or Brembo ST40/F40 caliper weight less than stock caliper. Look up the respective weights of both on the web and you will see significant savings in weight by going with a similar sized BBK.
GregW / Oregon wrotei'd think that it'd be dangerous in comfort because that would allow more travel and would be more likely to bottom out. or is this a non-issue entirely?With EDC on Comfort you can fly over them.
Big Windy wroteObviously depends on the size and shape of the hump. I find most don't slow me down.i'd think that it'd be dangerous in comfort because that would allow more travel and would be more likely to bottom out. or is this a non-issue entirely?
I haven't had a problem yet, but if I think there might be a clearance issue I always use the sport mode.
Does anyone have the weight for the stock 18" rims? Cant find it on
m3manila wrotehttp://www.m3post.com/forums/showthread.php?t=138728Does anyone have the weight for the stock 18" rims? Cant find it on
try going to google and typing:
site:m3post.com _____________ (put whatever you are looking for in the space where the line is)
it works a lot better than the forum's internal search function.
m3manila wroteThe following was posted log ago from a Euro listing, but not sure of its accuracy. Sounds about right.Does anyone have the weight for the stock 18" rims? Cant find it on
18" 219 M Doppelspeiche wheels:
Front: 23.19 lbs
Rear: 24.93 lbs
What is the length of OEM wheel bolts? (I need it for proper spacer extended bolts) Thanks!
Sur wroteIf you check this thread, you will find spacers that come with the proper lugs as a kit: http://www.m3post.com/forums/showthread.php?t=240884.What is the length of OEM wheel bolts? (I need it for proper spacer extended bolts) Thanks!
GregW / Oregon wroteThanks, but for spacers > 20mm H&R have the technology when the spacer is connected to the car first, and then the rim is connected to the spacer with the OEM bolts. That's why i need the length for it - that's what i was asked by the vendor..If you check this thread, you will find spacers that come with the proper lugs as a kit: http://www.m3post.com/forums/showthread.php?t=240884.
Guys, whats the max tyre dimension (front and rear) that can fit on OEM 19''?
