07-01-2015, 08:43 PM | #1 |
Ultimate Driving Machine E92ESS625 M3/G05 X5 Msport 40i Individual
460
Rep 2,002
Drives: 2011 E92 M3 DCT/ESS 625 kit
Looking to go coilovers
I currently have edc with swift springs. I want my rear lower and the only option is coilovers. Can anyone give me any ideas on what set up to go with. I would still like edc functionality. I would also have to order this online. Thanks for ur feedback.
"The Ultimate Driving Machine"
2011 E92 M3 supercharged ESS 625 2016 F15 X5 Msport 35i |
07-01-2015, 08:44 PM | #2 |
460
Rep 2,002
Here is a pic of my car now with swift springs
07-02-2015, 10:54 AM | #3 | |
Crazy!
1180
Rep 1,440
I am sure you will come up with something.
First "real" widebody M3 ever thread.[url]http://www.m3post.com/forums/showthread.php?p=17461963
07-02-2015, 11:42 AM | #4 | ||
460
Rep 2,002
07-10-2015, 09:04 AM | #6 |
Rep 947
I think it's Ohlins or Blistein that have a model for EDC cars. Quick questions and sorry OP for digging into yr thread, what's the difference between shocks and springs and Coilovers? I understand that coilovers are the fronts and springs on the back, is this correct?
07-10-2015, 09:31 AM | #7 |
Mr. Nice Says Hello
636
Rep 16,662
Drives: BMW M3 | X5 xdrive 35i MSport
if your looking to just slam the car you can also go with KW sleeves. That will retain EDC and allow you be at the height you are looking to achieve. I would just say ditch the EDC and go closers.
07-10-2015, 02:16 PM | #8 |
Rep 969
This. While the Bilstein setups maintain the appearance of EDC functionality, they are way overpriced for what you get.
Sold 2011.5 E92 M3 ZCP.
07-10-2015, 02:35 PM | #9 | |
Rep 6,218
IF you get proper coilovers, you will have a better performance in the corners, AND you will have more compliant/supple ride at the same time. Hard to believe but yes it is true. |
07-10-2015, 04:24 PM | #10 | |
460
Rep 2,002
07-11-2015, 04:00 AM | #11 | ||
Lord Scrip
1815
Rep 3,013
Drives: 2011 M3 Coupe
07-11-2015, 10:07 AM | #13 |
Rep 1,711
This is exactly what i did. Replaced stock EDC system with Ohlins R&T coilovers w/ GC c. plates. Not a hard core suspension for the track like MCS or kw clubsports, but a huge upgrade from stock.
07-11-2015, 01:08 PM | #14 |
Mr. Nice Says Hello
636
Rep 16,662
07-12-2015, 08:33 PM | #15 | |
Automobilist
395
Rep 2,632
07-12-2015, 09:44 PM | #16 | |
Rep 1,536
07-14-2015, 09:55 PM | #17 |
Rep 982
Very nice OP, love the "OEM+" look with the ZCP wheels.
In regards to suspension, there is no right or wrong answer. The only way for us to give you proper advice, is to find out what you will be using your car for. Will it be used on the street only, or will it see some track time? If it will see track time, how many days/events per year? Just because many members here run something, doesn't mean it is right for you. For example, the KW HAS (adjustable sleeve kit)... please pass on that. You already have swift lowering springs which utilize your stock shocks, and if you decide to dump any more money towards suspension, you will want to do it right the first time (or would this be considered the second time? ). As others have already mentioned, forget about something the utilizes EDC. My general opinion: Street: $ Stock shocks w/ swift or eibach springs $$ KW V3 $$$ Ohlins R&T Double Duty (Street & Track): $$ TC Kline $$$ KW Clubsports $$$$ Motion Control Suspension (MCS) Single's $$$$ JRZ Single's Track Rat / Competition: $$$$$ MCS doubles/triples $$$$$ JRZ doubles/triples Plan on adding some Vorshlag or Ground Control camber plates to the equation, especially if you plan on tracking your machine. KW Clubsports will actually come with camber plates, so that should be factored into your decision. Also note that KW V3's and KW Clubsports will likely create front fitment issues with your wheels/tires. This is due to the lower location of the spring perch, and the wheel/tire ends up rubbing. This can be remedied with the clubsports by either running 5mm spacers, or by removing the helper spring and purchasing different springs from eibach or other companies alike. MCS and JRZ are vastly superior then most (I love my MCS's ), but that may be complete overkill for your application. We need a bit more info from you before we press on.
07-15-2015, 03:57 PM | #18 | |
460
Rep 2,002
07-15-2015, 05:15 PM | #19 |
Rep 824
My car is on the BC Racing Coilovers, installed by the PO. I've had the car for almost 2 weeks now and I have nothing but good things to say about them. I've ran different coilovers on different cars, and these have a smooth ride on the street, and when I push the car they stay stiff. For less than $1000, I think these coilovers are one of the best for the price.
07-15-2015, 07:59 PM | #20 | |
460
Rep 2,002
07-15-2015, 08:08 PM | #21 |
Rep 2,400
If you want to retain EDC, Dinan, TCKline, Bilstein and KW Sleeves (I think Ground Control has one too). Dinan and TCKline use Koni shocks. But stock EDC is highly overrated as it only adjusts for compression, not rebound and this is a big drawback. Will say though that you will get a little more noise with coilovers (though Dinan probably has the least) but that is really only drawback. I have TCKline double adjustable coilovers set on soft and ride is better than EDC and softest setting is faster on the track than hardest EDC. I don't know if the other kits have clicking knobs for the rebound adjustment. The koni shocks in front have pins and IMO, they are a bit temperamental to set right. If you go with TC, be sure the installer follows the TCKline installation guide exactly.
I honestly don't know why BMW even did an EDC for the M3 with no rebound adjustability for the various modes. |
07-15-2015, 10:22 PM | #22 |
Supreme Allied Commander
3847
Rep 54,376
Drives: F80 M3
Location: Santa Barbara, AP, Brembo, GIAC, Koni, Ohlins, Performance Friction, www.hpautosport.com
Can't beat the ride quality of the Ohlins on the street and performance at the track.
