  TireRack
      03-08-2015, 03:52 PM   #1
Alohaaaaa
Alohaaaaa's Avatar
Drives: 2011 550xi
Anyone use 305's on ZCP's?
Thinking of 305 Nitto NT05's and 265 NT05's on my OEM ZCP rims for track use. Can't seem to find anyone who ran them to check 100% fitment.
Anyone here have an idea? I see most people run a 295 but the NT05 only comes in 305/35/19.
2017 Nitro Blue Ford Focus RS
2008 Sparkling Grey Metallic 135i 6MT - JB4 G5 - MHD Race BEF - N54Tuning DP's - ER Chargepipe/w HKS SSQV - Coolingmist Progressive Meth - MMP Hot Side Inlets - AFE Exhaust - Seconday Cat Delete - AMS FMIC - BMS Catch Can - Rob Beck PCV - LUX 160 AE
      03-08-2015, 04:10 PM   #2
///M Ryder
Grown Azz Man
///M Ryder's Avatar
Drives: GT4
Will never fit.....too much tire for a 10" rim.........Phil
2016 GT4.....Sapphire Blue Metallic, Platinum stitch Leather/Alcantara interior, Carbon Fiber Trim, PCM w/Nav, Guards Red Belts, 2 Zone Climate, Sport Chrono, LWB, Smokers Pack, Big Gas Tank, Light Design Pack, Bi-Xenon w/PDL, Auto Dim Mirror, Clear Side Markers, GTS Clear Taillights
      03-08-2015, 04:15 PM   #3
Alohaaaaa
Alohaaaaa's Avatar
Drives: 2011 550xi
I've seen people run 305's on them (PSS I believe), just not specifically the NT05.
I believe size for size PSS tend to be wider too.
      03-08-2015, 04:18 PM   #4
roastbeef
roastbeef's Avatar
I'm on zcp suspension with zcp wheels running a 295/30, and I didn't see any rubbing at a recent track visit. 305/35 is significantly bigger and I would be a little hesitant to run it.
Not sure if this helps, but I can take close pics of mine for you to look at clearances.
      03-08-2015, 04:19 PM   #5
///M Ryder
Grown Azz Man
///M Ryder's Avatar
Drives: GT4
Really? I have yet to see anyone run a 305-35 on a ZCP wheel. Point me to the pictures so I can see them.......Phil
      03-08-2015, 04:34 PM   #6
Alohaaaaa
Alohaaaaa's Avatar
Drives: 2011 550xi
Never seen a 35. But PSS come in a 30 I believe.
I know the 295's fit for sure, my buddy runs them, but I wanted to go with an NT05 and they don't make a 295.
      03-08-2015, 09:28 PM   #7
Kurt_OH
Kurt_OH's Avatar
Drives: E90 M3 ZCP
I'm running 275/30 and 295/30 PSS on E90 ZCP all stock. No rub up front, slight rub rear.
Tire shop had a tough time getting those 295s on the rear rims; I'm fairly certain they would have given up had I tried anything wider ...
Also, Tire Rack has rim size range for each tire. They don't list Nitto, but for 305/30 PSS, they require 10.5-11.5" rim width.
Nitto web site states 10-12" rims for their 305/35, but you'll likely get a TON of rubbing with that tall+wide of a tire out back on stock rims.
... a glorious V8 that screamed and hollered as the revs rose and then howled in an orgy of what sounded like BDSM ecstasy as it neared the red line.
Well, you can forget all that. The new car is fitted with a turbocharged straight six. Turbocharging? In an M car? That’s like putting gravy on an ice cream.
- Jeremy Clarkson, discussing the S65 and then S55 M3 engines.
      03-08-2015, 09:37 PM   #8
Alohaaaaa
Alohaaaaa's Avatar
Drives: 2011 550xi
Oh these ZCP rims in general are a pain to mount anything on.
275 in the front? Jeeze man thats a biggun. I might just have to do that.
How slight of rub do you mean? No damage/paint burns I assume?
      03-08-2015, 09:41 PM   #9
roastbeef
roastbeef's Avatar
i'm running 275/30 and 295/30 michelin pss on zcp wheels with about -2* camber with ground control camber plates. no rubbing with track use.
      03-08-2015, 10:20 PM   #10
Alohaaaaa
Alohaaaaa's Avatar
Drives: 2011 550xi
Figure I can do it with stock ZCP suspension setup?
      03-08-2015, 10:21 PM   #11
roastbeef
roastbeef's Avatar
I forgot to mention that I'm on zcp suspension with this setup.
      03-08-2015, 10:24 PM   #12
Alohaaaaa
Alohaaaaa's Avatar
Drives: 2011 550xi
You figure I would be fine without camber plates though?
      03-08-2015, 11:07 PM   #13
roastbeef
roastbeef's Avatar
Never ran this setup without camber plates, so I can't confidently answer.
However, I don't think there would be an issue.
I'm not running any spacers, by the way.
      03-09-2015, 05:42 AM   #14
Kurt_OH
Kurt_OH's Avatar
Drives: E90 M3 ZCP
You do NOT need camber plates, as long as you can INITIALLY accept a slight rub occasionally. No rub up front with 275/30 and slight in rear with 295/30 PSS only over long cycle dips where the suspension settles a lot, like a dip in the highway. There is a small protrusion on the inside of the rear fender where it meets the bumper cover. That protrusion is about the size of the end joint of a person's pinky finger. Anyway, it touches the outside shoulder of the rear tire, just next to the tread. That little bump wore off over the course of a couple thousand miles with no visible damage to the tire (there WAS a small smear of that plastic on the tire that I would occasionally pick/peel off, but my family didn't even notice it - it's not dramatic).
I would absolutely do it again, and it doesn't surprise me at all that adding some camber eliminates it. I thought about doing that, but wanted to see if it would self-resolve, which it did.
      03-09-2015, 08:17 AM   #15
81bear
Drives: G80 M3 - FDG
OP - I think I said this before to you but 305 is a hard tire to fit in the rear. I wouldn't try it with the zcp especially if you're going 305/35/19.
On a side note do you plan on doing any suspension mods? Like lowering springs or coilovers. If so, you may want to take that future mod into account before settling on a tire size/brand.
That's something I'm doing right now. I was all set on running 295/30/19 R888's on zcp wheels out back but now that I have a set of swift springs I'm concerned it may be rub city...
      03-09-2015, 09:14 AM   #16
jra85
M3NTAL
jra85's Avatar
Drives: 2011 E92 M3 ZCP
I think I recall somebody on here saying they have AD08 in 305s on an E92 ZCP, but my understanding is the AD08 runs slightly narrower than PSS tires do, so it's not that much wider than a PSS 295/30.
I believe I was one of the first (at least on here) to do the 275/295 PSS combo on an E92 ZCP, and that was only after knowing for sure 295s would fit in the rear after a member with an E90 did it, and Phil (M Ryder) did a 265/295 combo on his E92. I couldn't see going any wider than those sizes.
Unless you can find somebody else that specifically has used Nitto NT05s on ZCP, you may want to punt on that idea and just use 295s in another brand, unless you're fine with rolling the dice and being the guinea pig
      03-09-2015, 09:22 AM   #17
1MOREMOD
1MOREMOD's Avatar
Drives: Race car->
Ad08s run wider and have square shoulder rather than rounded like pss.
      03-09-2015, 10:11 AM   #18
jra85
M3NTAL
jra85's Avatar
I stand corrected. Just did a search for the guy running 305s on ZCP and they were actually RE-11s (305/30/19), which do appear to run slightly narrower than PSS. Here's the thread, it's long but look for posts by member RenoE92M3. He has some pics in there too:
http://www.m3post.com/forums/showthread.php?t=894795
      03-10-2015, 09:31 AM   #19
///M Ryder
Grown Azz Man
///M Ryder's Avatar
Drives: GT4
Again, a 305-35 will be a stretch (no pun intended) for a 10" wheel. My personal thoughts are this.....I've seen many suspension set ups and tire combos, but I think the best daily set up for the E9x series is the 275-30 and 295-30 set up. It's the perfect fit and leaves just a small amount of room for suspensions mods. My current set up with the Swift springs is maxed out. I can't go any lower on my stance or any wider on tires. The added grip is sooooo worth it.................Phil
      03-11-2015, 09:55 PM   #20
Alohaaaaa
Alohaaaaa's Avatar
Drives: 2011 550xi
Thanks guys!
Going with 275/295 PSS.
No suspension mods, because where I park has a very harsh dip and any lower would cause my lip to hit the ground.
Picking up a set of 19x11 and 19x9 HRE P40SC's as well, but they have 295 PSS on them already. Plan to track on my ZCP's as I don't want to accidentally curb an HRE!
      03-28-2015, 06:41 PM   #21
Alohaaaaa
Alohaaaaa's Avatar
Drives: 2011 550xi
Bumping this with a new question...
New rims I picked up are an E22 rear 19x11 super deep concave.
Anyone tried to fit a 315/25/19 Nitto invo on those? I'm thinking it should clear due to the invo's rounded corners, but don't want to order some and then be stuck with them.
      03-28-2015, 09:16 PM   #22
Ezio
Ezio's Avatar
Drives: 2023 Alfa Romeo, 2023 m240i
I run 285 on my rears. I was going for a wider look with traction as a plus. Honestly you could put a 295 on, but it's not going to look as wide as you think. Because the tire is not stretching the rubber out.
Even if the zcp could fit a 305 is not going to be what you think.
I knew someone, who ran a 275 on a wide rim and it looked a lot much better than my setup. Wider
