08-16-2012, 09:31 AM | #1 |
Rep 14
Track settings
I'll be instructing at a 3 day BMWCCA school at NJMP next weekend.
My car for the weekend is an "09 E90 M3 DTC w/ tech package. All stock exept for 285/30-18 Toyo R888s. What are some recomended settings?
Gerry Walsh
Director of Motorsports Otto's BMW West Chester, PA |
08-16-2012, 10:48 AM | #3 |
Apex Everything!
976
Rep 4,378
Drives: 2007 Honda S2000, 2017 GT350
I do, but definitely need power on the normal setting.
2011 E92 M3(Sold). 2007 Honda S2000 (Track Car). 2016 Cayman GT4 (Sold). 2017 Shelby GT350 (AKA Crowd Killer).
My pet project: https://stickershift.com |
08-16-2012, 11:25 AM | #4 |
Rep 124
08-16-2012, 11:27 AM | #5 |
Rep 4,488
DSC Off if you're comfortable with the car or cautious enough not to get overeager and drive above your abilities. Otherwise start with MDM or even DSC On if you're really worried; just be aware when it's intervening to make sure you're not developing bad habits that are only possible because the car is saving you. As you get better, you'll find that it intervenes for safety on inputs where you would've been fine without it as opposed to intervening to correct mistakes on your part; your instructor would be able to help you determine whether that's the case if you can't tell.
As for Power, I do NOT recommend Sport. Normal is the way to go. Sport is twitchier, whereas Normal is linear. Since the key to being fast on the track is being smooth, the more linear and precise your throttle, the better. I started with Sport initially but I found I was much faster (and far more confident) when running in Normal. Sport does not entail any power boost, it's purely throttle response. I now drive in Sport on the road because it makes the car feel faster (I know, I know) but use Normal for spirited back road driving and on the track. If you're worried that this might cause extra work/confusion from having to train your foot to adapt between the two modes, don't. You're adapting your entire driving style on the track anyway so it's really not any extra work at all. As for EDC, on a non-ZCP car Normal is popular because it's an adaptive setup, whereas Sport is a fixed firmness -- but the kicker is that the firmest end of Normal's range is actually FIRMER than Sport. There was an interview with an M engineer where he recommended that you use Normal for tracks with elevation changes and other things that require suspension travel and use Sport only if you're on a flat track. Steering is a personal preference, of course. I prefer Sport on track because I find the added heft helps me be smooth. Normal is great for city driving because it's light, but it's too light for spirited driving IMHO.
Gone but not forgotten: '11.75 M3 E92 Le Mans | Black Nov w/ Alum | 6MT (owned 5/2011 - 11/2015) Last edited by jphughan; 08-16-2012 at 11:34 AM.. |
08-16-2012, 11:34 AM | #6 |
Bored at work....
890
Rep 5,391
Only throttle response. No increase in HP like the previous gen M5 & M6.
Grey Matter:2008 E92 M3:608/425. SG/PS SOLD!
Dark Matter:2015 F80 M3:495/505. SOLD! Anti Matter :2016 F82 M4 GTS What next?!? A 2022 M235i GC- I must be getting old |
08-16-2012, 11:36 AM | #7 |
Rep 8,496
just throttle. It's more beneficial for 6MT owners as it allows quicker rev-match down shifts when you blip the throttle. I practice this all the time with power button on (Sport). Sport + is a bit too much sensitivity for me though for daily use, the car tends to jerk around when you modulate the gas pedal around town, so I turn it all off for daily use.
For DCT owners, I guess it's just your preference... |
08-16-2012, 01:00 PM | #8 | |
Smiling Politely
1381
Rep 29,118
im running
s5 mdm power-normal servotronic-sport edc-sport will start trying dsc off at next event.
08-16-2012, 03:41 PM | #9 | |
Rep 15,818
Otherwise I'm the same. DD i used Power on (sport), but track I tend to turn it off. It's too damn sensitive
08-16-2012, 03:57 PM | #10 |
Rep 915
A 3 day school should afford you ample time to determine how the car will handle and what you should have on and/or off. Assume since you are an instructor, you already have good driving skills, so any transition between settings should not cause surprise or difficulty. One thing, you say stock everything except for tires, then be aware of brake issues. Stock pads on that heavy car when driven with sprit do not necessarily agree with the event. Have fun, and I wish you sucess with your student(s).
vz
Previous Track Toy |
08-16-2012, 04:29 PM | #11 |
Track Addict
110
Rep 813
Drives: 2010 BMW M3 E92 | 2008 Z4M E86
Off topic: When you guys drive around town with power on (I have 6mt) if I am in 3rd gear for instance and i am lightly accelerating, I give it a little bit of gas when rpm is around 3k and it launches forward like I floored it and when I give it more gas it doesnt feel like it is pulling faster... like if I push down the pedal more it doesnt seem to be giving it more gas. I use normal power for tracking.
BMW ///M3 Coupe
Completed November 16, 2009 Received December 29,2009 |
08-16-2012, 05:02 PM | #12 | |
Rep 5,506
Can some tuner/shops chime in with actual throttle maps? |
08-17-2012, 09:14 AM | #13 |
General
21117
Rep 20,741
Drives: 2021 911 turbo
My track settings:
EDC: Normal or Sport depending on the track DSC: off Throttle (sport): Sport DCT: S6 Servotronic: Sport If find DSC way too intrusive at the track even in MDM mode. Note that it will make soft interventions without flashing the light in the cluster. I find that it cuts back on power too much and makes the car less amenable to minute throttle steering adjustments. The fact that I am running a square setup makes DSC intervene even more. As for throttle sensivity, I find the normal setting less natural. Contrary to what others are saying, I feel the normal setting is actually dampened and less linear. In the good old days when I was driving track cars with an actual cable between the pedal to the throttle, you had that same feeling where the last part of the travel had little impact in the lower RPM range. This is because in lower RPMs the engine does not need as much air, so as of a given point a bigger throttle opening will not yield more power. However, in the higher RPM range the throttle becomes more precise. I agree that Sport+ is pretty much useless though. I am a bit torn regarding EDC. I find the car has better overall composure in the normal setting. However I find the car more predictable and more responsive in the Sport setting. I pick the setting based on track smoothness. Note that my car is non-ZCP. I would be very curious to try a ZCP car in sport EDC mode since sport is dynamic on ZCP cars. As for DCT, I find S6 provides the crispest downshifts and responds faster to paddle inputs. It is quit harsh when you shift in lower RPM in 1st and 2nd gears, but is smooth enough when you shift at redline in the higher gears. My 2 cents. Have fun and enjoy the car Last edited by CanAutM3; 08-23-2012 at 03:21 PM.. |
08-17-2012, 09:19 AM | #14 |
Rep 1,250
I run:
EDC: Sport (when I had it, now I have coilovers) DSC: Off Throttle: Sport (Not sport plus!) DCT: S4 (Still shifts really fast, and is easier on the trans, at least in theory) Servotronic: Sport |
08-17-2012, 10:29 AM | #15 | |
Rep 1,887
Drives: '20 M5C, '09 M3 DCT Coupe
And every instructor who preaches "smooth" and that's most of them, will tell you to go with the normal on the power setting. That button should not be called the "power button", it should be called the "throttle sensitivity button" 'cause that's all it is. It has nothing to do with power.
M5C 20% tint, Xpel full front, partial sides and rear. Spacers, 15mm front, 12mm rear. Turner Motorsport Oil Cooler Guard.
M3: Active Autowerke filter, Dinan underdrive pulley, Dinan full exhaust and software, 3.45 Differential, Springs, Brakes, Dinan/HRE wheels, 275/30-19 w/10mm spacer, 295/30-19 w/3mm spacer, painted front reflectors, 30% tint, Escort 8500i & Lidar Jammer, LUX H8 V5 halos, Euro rear foglights, 3M ClearBra. Last edited by MysticBlue; 08-17-2012 at 10:35 AM.. |
08-17-2012, 03:25 PM | #16 |
Rep 14
Thanks for the responses, I'll reply after the event with my findings.
Gerry Walsh
08-17-2012, 03:54 PM | #17 | |
General
21117
Rep 20,741
08-17-2012, 04:34 PM | #18 |
Rep 1,749
couldn't tell very well but seemed like you short shifted up in that right hand turn.
edc settings depend on the track surface. smooth, go firmest. rough, middle setting. comfort allows too much roll for my taste. running R888's will stress brakes out even more on such a heavy car. fresh brake fluid and some more aggressive pads than the oem ones would help for repeated laps, especially while taking students. brakes are still weak point.
"It gave you amazing satisfaction, but anyone who says he loved it is either a liar or he wasn't going fast enough." - Jackie Stewart on racing at the Nurburgring
08-17-2012, 07:08 PM | #20 | |
General
21117
Rep 20,741
I shift by ear/feel. So I do sometime shift sligthly before redline . It does not change the point I am making though... I just grabbed the first example I found without paying attention to where I shifted . Here's another lap where I push a little harder and shift closer to redline (got a rabbit to catch ). Car is still very stable ! Last edited by CanAutM3; 08-17-2012 at 07:57 PM.. |
08-17-2012, 08:48 PM | #21 | |
Rep 1,359
2014 E63 AMG-S
2012 C63 AMG (P31) - gone 2011 E90 M3 FBO - gone |
08-17-2012, 09:22 PM | #22 | |
Havin' a blast!
125
Rep 4,847
BRP 1:56 | CVR 2:01 | ACS 1:53 | WSIR 1:34
