02-03-2009, 06:53 PM | #1 |
Rep 5,767
Rear Spacer size for OEM 19" wheels?
what size rear space should i run to make the wheels flush with the fender? i don't want to rub...
02-03-2009, 07:04 PM | #2 | |
Rep 12,999
Yes, 3mm can make a difference... |
02-03-2009, 08:16 PM | #4 | |
Rep 18,823
Drives: BMW
Macht Schnell - Competition Wheel Spacer kit for BMW - 10mm http://www.europeanautosource.com/pr...oducts_id=2199 Macht Schnell - Competition Wheel Spacer kit for BMW - 15mm http://www.europeanautosource.com/pr...oducts_id=2201 No need for the longer lugs, the kits come already equipped.
02-03-2009, 08:18 PM | #5 |
Rep 18,823
Drives: BMW
02-03-2009, 08:41 PM | #6 |
Just call me J.J. McClure
156
Rep 2,834
Can spacers cause any negative effect on your car? Can it harm the suspension or reduce the longevity of OEM components?
MODS: Meisterschaft GT Racing Exhaust / BMC Air Filter / UUC SSK & DSSR (Modded)/ RPI Scoops / Passport SRX Hardwired / Custom Wrap 3M Clearbra / 20% Tint / 50% Windshield Tint / Key Hole Delete / Matted Out Accessories / VRS Type II Diffuser / Smoked Reflectors / Euphoria 6K LED Interior Lights / Rear Fog Light Mod / 6000K HID's / 6500K LUX H8 Angel Eyes / RDash License Plate LED Kit / LED Xenon Reverse Lights
"M3 drivers have no friends" |
02-03-2009, 08:48 PM | #7 | |
Rep 18,823
Drives: BMW
The 10/15 combo seems to work just fine.
02-03-2009, 08:52 PM | #8 |
Rep 4,318
02-04-2009, 01:32 AM | #9 |
Rep 10,407
Based on the pic of the white car above I went with 15F/10R on my stock 19s. I think this is absolutely perfect. Just lines up the outer edge of both tires with the edge of the fender bulges. I suppose if you want a really aggressive look you might consider 15R but for me the 15/10 combo is perfect.
02-04-2009, 01:36 AM | #10 |
yodog
197
Rep 5,025
I think 15 front/12 rear looks the best from the pics I have seen.
02-04-2009, 02:04 AM | #11 |
Rep 10,407
You do realize how small 2mm is, right (12mm vs. 10mm rear)? It is about 80 thousandths of an inch or about small fraction over 1/16th of an inch (for you non metric dudes). In other words I seriously doubt you can see the difference on a car.
02-04-2009, 04:45 AM | #12 |
///M South Lead
46
Rep 863
Drives: Jerez Blk / Fox Red Ext
Can anyone post pics with the 15/10 on OEM 19s and possible with an H&R Sport Springs.....I am also debating which is the best route for a sedan without rubbing...any info would be greatly appreciated
02-04-2009, 01:57 PM | #13 |
Rep 18,823
Drives: BMW
Agreed. I would be amazed if someone could pick this out based on a forum pic.
02-04-2009, 08:52 PM | #14 |
Rep 10,407
The pictures from Tom above on 18s are what you need to see. Recall that the overall outside diameter of the OEM 18s and 19s is almost exactly identical. Other then the appearance of the rim itself and the lesser sidewall height, from a width perspective the 15/10 combo looks identical on 19s as on 18s.
02-05-2009, 10:14 AM | #15 | |
///M South Lead
46
Rep 863
Thanks......for pointing that out and reminding me of the obvious. Good looking out. |
02-06-2009, 08:13 PM | #16 |
Sheriff
109
Rep 1,481
I had 15mm all around and it was perfect and no rubbing.
2023 Porsche Spyder, 2024 Porsche Macan GTS, 4Xe Rubicon & 2021 BMW X5 M Package
02-10-2009, 11:59 AM | #18 | |
Rep 12,999
So before making any decision of getting a particular size of spacers it might be wise to take also in consideration the tire sizes used -or planned to be used - as well as the desired looks. |
02-10-2009, 12:43 PM | #19 | |
Rep 10,407
02-10-2009, 12:44 PM | #20 |
Rep 2,937
Drives: 2013 Estoril 328i M Sport
I have the stock 19s as well, and I went with 15 front and rear. The rear looks perfect with this amount, although the fronts could come out a little more to match the flush look of the rears. Ideally, I would have done 20F/15R.
05-22-2009, 05:42 PM | #21 |
Rep 424
I know a lot of people have 15mm rear spacers and say they have no problems and others rub with 12mm rear spacers. What I want to know is what is the largest rear spacer size I can go without any rubbing under any condition, even with a huge load in the rear. In other words, I want the rear wheels to be able to tuck without rubbing.
I think 15mm is out of the question since some people rub with stock OEM 19's and 12mm rear spacers. 10mm sounds like it isn't a problem though. Anyone know? I have looked at all the threads on spacers and haven't seen anyone say that the rear wheels can tuck under the fender without rubbing with a Xmm size spacer. |
05-23-2009, 10:42 AM | #22 |
My other car is a Scooter'ia
85
Rep 1,303
For what its worth, I'm running 15 front and 12 rear, OEM tires, stock suspension, E90 with no rubbing, and plenty of room to spare.
Personally, I think the 15/12 set-up is perfect. These spacers will be for sale in a couple weeks, btw. http://www.m3post.com/forums/showthread.php?t=240884
A91 Edition Supra | Armytrix | Rays M3 Saloon | Akrapovic EVO | B&G Sport M3 Saloon | VF540 | Klässen ID M52-R | Akrapovic | Vorsteiner GTS5 | KarbonWerke CSL [SOLD] |
