01-19-2011, 07:12 AM | #1 |
Rep 387
Why BMW making the move to turbo and not superchargers
It just seems that superchargers are much better at preserving the NA tendencies of immediate throttle response with no lag.
Clearly, with all the supercharged e9x's they could also maintain the high rpm redline and free revving nature of M engines. So why is M dept moving to turbo's instead of superchargers? Are turbo's more fuel efficient? Or is there some other reason? |
01-19-2011, 08:13 AM | #2 |
Rep 379
the point of a turbo is to save fuel when not going full throttle. a supercharger is just a way of increasing power without increasing displacement.
01-19-2011, 09:24 AM | #3 |
Rep 2,464
Short answer: To save money.
BMW's answer: Turbo is more efficient. Efficient dynamics. Blah Blah... Real answer: BMW doesn't want to invest on R&D too much. High revving NAs are gone because they don't want to spend money. If they do supercharger, that'll require more R&D than using a modified version of one of their turbo engines for the M3.
2011 MINI Cooper S
previous cars: E92 M3, Z4MC, Z4 Roadster, E36 328 Sedan |
01-19-2011, 09:56 AM | #5 | |
Rep 379
saving money is bs because all BMW has ever done was developing high revving n/a engines. so the r&d effort there is minimal compared to shifting into a whole new technology. |
01-19-2011, 10:02 AM | #6 |
Moderator
7515
Rep 19,368
01-19-2011, 10:05 AM | #7 | |
Rep 6,845
Drives: 2018 Audi RS5 coupe
turbocharging AND supercharging read up on the twin charger they have it on a 1.4, but it puts out the power of a 2.0 while using less fuel |
01-19-2011, 10:54 AM | #8 | |
Rep 4,567
http://www.autoblog.com/2011/01/19/r...uld-be-killed/
'09 E92 M3: Space Gray, Black, Carbon Leather | ZTP 2MK ZPP 2MT 6FL | link 1 / link 2
Mods: M Performance exhaust | ZCP retrofit | Euro airbox | GTS DCT flash | JPN 240 ECU flash | Euro LCI taillights | CRT lip | OEM alarm retrofit | Space Gray bumper plugs | BMW Performance: Mk. II spoiler / Mk. II non-electronic steering wheel / mirror caps / front grilles / side gills / intake louvers / emblem |
01-19-2011, 11:02 AM | #9 |
Rep 795
I believe the efficiency of superchargers are more influenced by heat compared to turbos. The superchargers start to lose a large amount of efficiency once the heat start building up, so that could be a problem.
Plus turbos does save fuels... |
01-19-2011, 11:33 AM | #10 |
Rep 530
01-19-2011, 11:47 AM | #11 |
Private 1st Class
23
Rep 473
I recall many posters on here referencing the 997 TT as dream car in various threads over the years. Doesn't seem to be much wrong with that. Variable veng whatyamacallit etc.
PS - Is is me or does it seem a little bit premature/small minded/daft to write off BMW's chances of producing a successful turbo M3 ? Personally a 450bhp TT straight six sounds like the dogs from where I'm standing, Ken
01-19-2011, 11:54 AM | #12 | |
Rep 2,464
But which one is better? A lot of torque in short powerband that allows you to use tall gear, or decent amount of torque in a wide powerband where you can fit short gears (which will multiply torque&power at the wheels)..? I think the latter is better.
2011 MINI Cooper S
01-19-2011, 12:22 PM | #13 | |
Rep 8,496
01-19-2011, 05:32 PM | #14 |
Rep 387
Thanks for the replies. I'm not sure I see how turbos are more efficient if when you get on them they burn as much fuel as a larger displacement engine. Where if you lay off its like they don't exist.
Now I get that because the supercharger is belt driven there will be parasitic losses, but if you are not getting on it, shouldn't it be just as efficient as turbos? Also, this is not a thread about if BMW should go FI, just curious why the choice of turbos v. Superchargers. Audi seems to like both. Fwiw |
01-19-2011, 09:37 PM | #15 | |
///M POWER
Rep 4
01-19-2011, 09:45 PM | #16 |
Rep 511
Currently looks like MB has the lead in the green car race .
Check out those mpg rating on the CLS63 at 23.1 combined @ 518/519 , mercedes number though. Also it weighs less than the E93, but about 500 more than the E92. http://www.insideline.com/mercedes-b...rst-drive.html |
01-19-2011, 10:08 PM | #17 |
Havin' a blast!
125
Rep 4,847
If I had to swallow FI, I'd be down for a twin charger.
BRP 1:56 | CVR 2:01 | ACS 1:53 | WSIR 1:34
01-20-2011, 12:14 AM | #18 | |
Rep 2,464
Turbos are more efficient because you get higher bhp/liter. So let's say you get 400bhp from 3liters instead of 4. Now when you're cruising (which is what u do most of the time) you have the "economy" of smaller engine.
In the case of supercharger, that always works and hence always draws power from the engine. Maybe someone can make a supercharger with a clutch so when you're cruising it can be disconnected from the engine. But than, when u want to accelerate it'll have to spool hence lag. Quote:
2011 MINI Cooper S
01-20-2011, 07:36 AM | #20 | |
Rep 387
01-20-2011, 08:38 AM | #21 | |
Rep 331
