      05-17-2015, 01:02 PM   #1
JEllis
JEllis's Avatar
532
Drives: E36 M3, E92 M3
Some Updates on the Signal Green M3
The car is over two years old now and I felt it was time to transition to the final form I wanted the car to take. The huge wing, green TEs and SC were fun but in the long run I felt I wanted something a little more OEM+.
First, I contacted Malek at MRF and discussed the move to an RKP GTS/GT4 wing. With Maleks help I ordered a new E92 trunk lid that would have welded in reinforcements for the wing.
IMG_0830 by JEllis, on Flickr
As you can see the RKP reinforcements are welded to the structure of the trunk lid. Very sturdy!
MRFs paint guy did a great job matching both the exterior color but also the matte under coat.
IMG_0828 by JEllis, on Flickr
I chose the flat black version of the wing as it best represented an authentic GT4/GTS wing. And, I think it flows nicely with the signal green paint.
IMG_0831 by JEllis, on Flickr
This is the first time the car has been at MRF since the new wheels and RS3s. Time for an alignment check. As expected, I had fallen out of spec due to some changes I had made in ride height and camber.
IMG_0832 by JEllis, on Flickr
Having the car on the lift and a good tire shop down the street gave me an opportunity to have the wheels re-balanced with a road force machine. No more pesky vibration.
IMG_0826 by JEllis, on Flickr
Now I loved the SC and I still believe the ESS 550 is one of the best kits on the market. But, I had always intended for this car to be NA over the long haul.
IMG_0836 by JEllis, on Flickr
I had saved just about every tiny part when I installed the SC. Even this connector housing that had to be removed for integration with the ESS manifold. Its all about the details.
IMG_0838 by JEllis, on Flickr
I normally try to go with OE parts but this Clampco clamp is far superior to the OE one.
IMG_0849 by JEllis, on Flickr
The kit sold in two days after removal and went to a good home!
IMG_0844 by JEllis, on Flickr
Cleaned up some pieces I removed during the SC un-install.
IMG_0850 by JEllis, on Flickr
Cleaned and protected my wheel hubs!
IMG_0851 by JEllis, on Flickr
Touched up and then sealed the corners of the bumper with helicopter rotor tape. These little corners are not normally seen but they sometimes rub on the headlight.
IMG_0852 by JEllis, on Flickr
I ordered a bunch of replacement clips and OE fabric tape to put all the wires I had moved during the SC install back into OE position.
IMG_0853 by JEllis, on Flickr
I am a little OCD when it comes to my cars and after 14 years of E36 ownership I know how these wire looms can rub through paint. I decided to prevent it here with some stick on rubber sheeting.
IMG_0854 by JEllis, on Flickr
Well I am not going all the way back to stock with the motor. Here is the Dinan intake side by side with the OE intake.
IMG_0855 by JEllis, on Flickr
A lot of people have questioned any advantage a Dinan intake has over a drop in filter. Here you can see the size difference in the collars that attach to the filter. Dinan claims theirs is 30% larger. It certainly looks less restrictive.
IMG_0857 by JEllis, on Flickr
Its a beautiful piece installed.
IMG_0858 by JEllis, on Flickr
The noise the Dinan intake helps the motor make is bliss.
IMG_0859 by JEllis, on Flickr
IMG_0863 by JEllis, on Flickr
IMG_0872 by JEllis, on Flickr
IMG_0871 by JEllis, on Flickr
Messing with my camera to try convey the true color of my car.
IMG_0869 by JEllis, on Flickr
http://www.m3post.com/forums/signaturepics/sigpic14547_7.gif
Instagram: jellismotorwerks
      05-17-2015, 01:39 PM   #2
X5-User
X5-User's Avatar
188
Drives: X5 35d
man...what a beautiful car !
      05-17-2015, 01:43 PM   #3
E90M3velocity
Philippines
338
Drives: Manual-Slicktop E90 M3
Yours is one of the best builds i've seen while lurking in this forum for years. Functional and no bs. Have you ever thought about stroking the motor too?
      05-17-2015, 01:51 PM   #4
JEllis
JEllis's Avatar
532
Yes I am considering a built motor as the next step.
      05-17-2015, 01:57 PM   #5
BobS
BobS's Avatar
97
Drives: M3
If your going to go NA and keep the car, a stroker would be awesome! The car looks the part for sure...very nice
ESS 650 ACM-R Upgrades
      05-17-2015, 04:54 PM   #6
webninja
Drives: 2011.75 E90 M3
Great photos. Saw this car in person at MRF, and the level of detail is impressive, the signal green looks much better in person. It's interesting you went back to NA, maybe a stroker in your future
      05-17-2015, 05:38 PM   #7
buddalun
buddalun's Avatar
Drives: 911 x 2, Tesla M3P & MYP
Very nice. What kind of side mirrors are those?
      05-17-2015, 05:44 PM   #8
JEllis
JEllis's Avatar
532
BMW DTM/Le Mans Motorsport Mirrors and RKP mounts from IND.
IMG_0548 by JEllis, on Flickr
      05-17-2015, 06:47 PM   #9
Curt2000
Curt2000's Avatar
Drives: '93 Supra Turbo
Very nice Jason! You have unmatched attention to detail and impeccable taste!
Former Car: '16 SUNBURST GOLD F80 ///M3--6MT/Carbon Cloth (ED Thread)
Former Car:'13 SANTORINI BLUE E92///M3--6MT/Speed Cloth/ZCP(ED Thread)
INSTAGRAM:@C2KMotorsports
      05-17-2015, 10:42 PM   #10
STooK
STooK's Avatar
Drives: 2013 E92 M3 ZCP
I thought I was OCD but your attention to detail is unparalleled…car is perfect in every way. I hope you end up holding on to it for as long as you can…although if you do sell it whoever buys it will be very lucky.
2013 BMW E92 ///M3 AW/BLK ZCP CF Roof 6 Speed - Perfection
2011 BMW E90 328i xDrive Space Grey/Black - Daily
2011 BMW E93 ///M3 MW/FR/BLK 6 Speed - Gone but not forgotten
      05-17-2015, 10:48 PM   #11
mah1688
Drives: 2016 Porsche Cayman GT4
gorgeous car!
      05-17-2015, 11:15 PM   #12
AP3X_FTW
AP3X_FTW's Avatar
Glad to see that the blower was removed. The extra power can be fun on the street, but the S66 is a beautiful high revving NA motor that really does not need a blower. You will be much better off this way should you put her through her paces at the track.
I love your attention to detail. I think the gold E88's are beautiful on a white or black car, but I would go with silver with a polished lip in this case.
Very nice
E46 ///M3 Race Car
F15 X5 ///Msport
For Sale - E92 M3 Full Black Interior Part Out
      05-17-2015, 11:19 PM   #13
JEllis
JEllis's Avatar
532
Very nice
The blower made the car a beast on the straights of big willow. I think my times on that particular track will suffer. The smaller tracks, like streets, probably a wash.
That being said, the S65 is a beautiful NA motor.
      05-18-2015, 12:22 AM   #14
Hujan
Hujan's Avatar
Drives: M3
Amazing car. Still can't believe I haven't seen her in person. Someday soon, I hope.
      05-18-2015, 02:29 AM   #15
KudosM3
Drives: M3 V8
One of my favourite builds
Is this a car for life? No plans to move to the new F8X?
      05-18-2015, 07:34 AM   #16
BMWDEMON
Super modder
BMWDEMON's Avatar
Drives: E90 M3 & E46 M3
Looking great as usual!
SOLD - 2005 E46 M3 ZCP - I/B on black
CURRENT - 2011 E90 M3 - meticulously modified
2015 X1 Xdrive 28i
      05-18-2015, 07:48 AM   #17
JEllis
JEllis's Avatar
532
Bimmerfest? You going?
Yeah no plans to ever sell. I could see myself in an F8X but it would be in addition to my small collection instead of a replacement.
      05-18-2015, 10:05 AM   #18
nicksm3
nicksm3's Avatar
Drives: e92 m3 Competition
- Hence why i kept my motor N/A and will
Always loved your car man!
      05-18-2015, 10:56 AM   #19
mkPOTO
Mr. Nice Says Hello
mkPOTO's Avatar
636
Drives: BMW M3 | X5 xdrive 35i MSport
great work. I have been thinking about doing the same thing as well. Car looks stunning as always though!
      05-18-2015, 11:37 AM   #20
SheaButter
SheaButter's Avatar
Drives: F80 M3CP F86 X6M
Was the first drive home without the blower sort of depressing? I remember when I uninstalled my blower from my C6 and went back down to around 450hp it felt like my E-brake was up... haha
Great looking M3 btw!
      05-18-2015, 12:32 PM   #21
JEllis
JEllis's Avatar
532
Honestly, I dont miss it. The 550 kit is fairly mild to begin with and it was not really on boost till higher in the rev band. I did really like the kind of boost squirt high in the rev band as it rolled in.... it always made me giddy.
      05-18-2015, 01:11 PM   #22
Edward
Drives: 2013.9999 E92 Jerez ZCP
I like this car a lot better now.
It looks like Tom Schirmer's M3 builds.
I think the S65 powerplant is too special and unique to muck up with a blower anyway. You'd do your laptimes more of a favor by ditching more weight (if possible) and going even more hardcore on the suspension and chassis.
