11-18-2014, 10:30 PM | #1 |
Rep 1,616
6MT weird shudder when accelerating from stop
I was wondering if anyone else has had this same problem. When I'm accelerating from a stop I get a weird shudder from what I assume to be the transmission (although could be from diff). Basically when I release the clutch and press the gas, it's very hard/impossible sometimes to get a smooth transition
It's kind of like when your were a noob driving a stick and you couldn't slip the clutch correctly and the car would kind of die for a split second... Except I've been driving a stick for like 15 years and even when I'm really focusing on it I can't get it to transition correctly It seems to be an intermittent issue that is usually worse when I'm accelerating from a stop on an incline.
11-18-2014, 10:56 PM | #3 |
Rep 1,616
It's not all the time and I don't feel the clutch slipping, only 45k miles on the car and they aren't hard miles.
When I release the clutch and press the gas there is like a slight pause, shudder, then the car catches and moves
11-19-2014, 02:14 AM | #4 |
Rep 530
I'm going through a similar situation. My mechanic took the driveshart off and noticed the rear portion is binding. I've yet to find time to go back and get it fixed. I'll keep you posted
11-19-2014, 11:53 AM | #5 | |
Rep 1,616
Does it get better or worse with the car being cold vs. hot? Have you noticed this issue getting worse or stayed the same? Are there any particular noises (metal scraping, grinding etc)? Is it like really noticeable and you feel like you need to stop driving the car or does it just seem more like an annoying thing that you could deal with? Guess I will look up driveshaft issues for the car. Thanks
11-21-2014, 05:04 PM | #6 |
Rep 76
Very timely post. I was just booking an appointment with BMW to have them look at this issue on my car (2013 6MT w/17k on it).
Just to make sure we are talking about this same thing, here is what I'm experiencing. On an incline (even small incline) or if I have multiple people in the car, if you take off even gently, at the very end of releasing the clutch, you can feel it shutter a bit. It's not a horrible shutter, but I have had more than 1 passenger give me a hard time for "almost stalling the car". Even though that is not whats happening. Revs never go below 1000-1100. In my car, it doesn't do it until I have driven the car a bit. I don't need to drive it hard to really heat it up. Just my normal drive to work, by the end of a 25 mins commute, it will do it on and off. I have been spending some time trying different things to be able to reproduce it on demand, because I can already hear the BMW SA "It's normal for these M3 cars". I have owned the car since new, and it only started this within the past 1000 miles or so. |
11-21-2014, 09:19 PM | #7 | |
Rep 1,616
11-22-2014, 10:56 AM | #8 |
Bad Lieutenant
232
Rep 3,517
Maybe have the guibo or center bearing inspected.
11-23-2014, 10:04 PM | #9 |
Rep 1,974
Interesting...I have been noticing this lately as well. I just thought it was because I wasn't giving it enough gas while releasing the clutch so the revs dip <600 causing the slight shudder. I'll keep my eyes on this thread though.
2013 BMW E92 ///M3 AW/BLK ZCP CF Roof 6 Speed - Perfection
2011 BMW E90 328i xDrive Space Grey/Black - Daily 2011 BMW E93 ///M3 MW/FR/BLK 6 Speed - Gone but not forgotten |
11-25-2014, 01:41 PM | #11 | |
Rep 1,616
It doesn't seem to be the clutch it seems to be coming from the rear end
11-25-2014, 04:09 PM | #12 | |
Rep 76
I'm asking as a broken pressure plate is a big thing, and I would expect more than a "slight" shutter with a broken plate. |
11-25-2014, 05:29 PM | #13 |
coupe la goon
373
Rep 1,640
Drives: green, black, white
Garage List 2011 BMW 1M Coupe [10.00]
2013 BMW M3 Coupe [10.00] 2010 BMW 535i xDriv ... [0.00] 2008 BMW M3 Coupe ( ... [0.00] |
This is very telling of a prop-shaft center-bearing failure--at least if my days from the older BMWs are any indication. Hopefully it is fixed quickly
11-26-2014, 12:47 PM | #14 |
Rep 1,616
Not sure if everyone here is having the same problems but here is a test from rogue engineering that you can try to see if it's the giubo that's starting to fail, besides looking at the actual thing of course.
http://www.rogueengineering.com/bmw/GUIBO.html Btw, I did a quick google search and didn't find any but is there an upgraded giubo and center bearing? Or is OEM the only option?
11-26-2014, 01:49 PM | #15 |
Rep 57
yes, broken pressure plate seems a big thing and u would expect a lot of noise.. but the service guys said... the car can be driven even without repairing it..
all i heard was a small shutter when i changed gear from 1st gear to 2nd gear. the best thing to do is .. just go to bmw service.. they will fix it .. |
11-28-2014, 11:57 AM | #16 |
Global Moderator
6381
Rep 2,309
Drives: E90 M3 6MT
I get the shuddering from time to time but it is very inconsistent.
Did a search and it seems to be common amongst BMWs (though i don't remember experiencing this on my E46). http://www.e90post.com/forums/showthread.php?t=463335 http://www.1addicts.com/forums/showthread.php?t=739881 http://www.bimmerfest.com/forums/sho...d.php?t=629950 The normality of the phenomenon is debatable but the general consensus is that uneven wear from excessive stop & go causes hotspots and deposits to form on an otherwise smooth flywheel and/or evenly worn clutch. Hence the shuddering sensation. It does seem like based on those discussions, as long as the clutch is not slipping at full engagement, a clutch/flywheel replacement is not necessary although the hotspots/deposits are there to stay until a new clutch/flywheel assembly is installed. Hope this helps and also open to more input from those who have experience with this.
2011.5 E90 ///M3 | 6-Speed Manual | Slicktop | Jerez Black | Fox Red
E9x M3 Press/Media Archives Thread | S65-based Racing Engines Thread Last edited by Law; 11-28-2014 at 12:06 PM.. |
11-28-2014, 01:53 PM | #17 | |
Rep 1,616
It's pretty sporadic/minor at this point but I will continue to monitor.
