04-05-2015, 05:30 AM | #1 |
Rep 65
climate control
Is there any way to set the climate control when it is off to let outside air flow inside the cabin? I can't for the life of find any info on this in the manual. For example on my dd, if I have the ac and fan off and vent set to recirculate, no outside air would enter the car. Air would flow in while driving if the vent was set to outside air (non recirculate) . So how the heck would I do this without turning on the climate control or fan?
04-05-2015, 05:36 AM | #2 |
Rep 2,940
I find the climate control in the M3 to be ridiculously complicated and redundant. And then you have the hot/cold switch on top of that which seems to override your temperature settings. What is even the point of that??
Audi S6 * Audi S3 * Porsche Cayman GTS
--Former BMW M3 owner |
04-05-2015, 05:44 AM | #4 | |
Rep 7,132
Agree on the cold/warm switch on top, never figured out what the idea is here and how this works with the temp setting. Anyone? Cheers |
04-05-2015, 06:03 AM | #5 |
Rep 65
Basically whenever the climate control is off, absolutely no outside air will flow into the cabin. Is there a way or setting to make it so outside air will flow through the vents while climate control is off, while driving?
04-05-2015, 06:21 AM | #6 |
Rep 7,132
Still not following bro, so does the fan stop when you turn AC off..?
Maybe its possible to shut the whole thing down, and stop fan + inlet, but why would you want that man? |
04-05-2015, 07:31 AM | #7 |
Rep 65
Cause usually when I'm driving around with the windows up, and the climate control unit off, it gets stuffy really fast. It's nice to just have fresh air venting into the car without having to roll down the windows, if that makes sense?
04-05-2015, 07:41 AM | #8 |
Rep 7,132
Hmm...still don't understand man. The only way I can shut down the fan is to turn "auto" off and then lower the fan to zero. Otherways you have your went there mate.
Good luck |
04-05-2015, 08:12 AM | #10 | |
Rep 214
Drives: 2012 E92 M3 ZCP 6MT AW/BLK
2012 BMW M3 ZCP 6MT |
04-05-2015, 09:47 AM | #11 |
Rep 1,544
yes...turn on the climate control fan but uncheck the AC through a button or idrive i believe.
04-05-2015, 10:15 AM | #12 | |
Rep 4,488
OP, if you just want the vents open but everything entirely passive, I don't know if there's a way to do that. I don't know for certain that the vents are actively CLOSED when AC is off, but there doesn't seem to be a way to adjust that state without having the fans on at least to some degree.
04-05-2015, 10:16 AM | #13 | |
Rep 4,488
04-05-2015, 11:01 AM | #14 |
Rep 105
I often use this feature to blow slightly warmer air on my hands while keeping the overall temperature cool.
04-05-2015, 11:03 AM | #15 |
Rep 1,974
Interesting. I thought with everything off, the air comes in. You guys are saying it's the opposite? Going to have to test this out.
2013 BMW E92 ///M3 AW/BLK ZCP CF Roof 6 Speed - Perfection
2011 BMW E90 328i xDrive Space Grey/Black - Daily 2011 BMW E93 ///M3 MW/FR/BLK 6 Speed - Gone but not forgotten |
04-05-2015, 11:07 AM | #16 | |
Rep 65
04-05-2015, 11:22 AM | #17 |
Rep 65
04-05-2015, 07:41 PM | #19 | |
Rep 545
http://www.shrani.si/f/2z/Eu/2cbNKAh...te-control.pdf See Page 24 to see how "technical" the fresh air system operates. Lots more interesting bits to enjoy also. |
