09-17-2015, 10:51 AM | #1 |
Rep 330
Space Grey M3 Garage Build Pictures
I finally got around to taking a few pictures of the new (to me) spacegrau M3 in its new cave. It took me about 8 months to finally complete the garage. Thought I would post a few details of the build out.
1. If you are a true BMW enthusiast you should recognize the wall decal. 2. Floor: The floor is a 3 layer U.V Resistant Urethane. The first step was to machine diamond-etch the entire surface then fill and seal random cracks here and there. Then cut in border lines with a hand grinder so epoxy wouldn’t bleed. Followed that by a primer first layer, then primary urethane layer with colored chips put down to refusal (dumped over 100 pounds of chips until the urethane couldn't stick to any more chips, i.e. "to refusal" then let it dry and scraped off the chips that didn't stick. Then finally put down a clear coat top for a slick and reflective gloss look (and extra UV protection). This floor will won’t degrade for ~20 years or get hot tire peel up like your typical big box store DIY kits. 3. Walls: First we had to remove EIGHT built in cabinets that the previous homeowner crafted himself. We had drywall and fire tape from when we bought the house so we had someone come and do the drywall preparation. We then primed and sprayed the entire thing white, and then came back with the gray lower border spray. Last step was to use a laser level to cut in the black stripe. We actually were able to put down the stripe in about an hour with two people, the laser level, and taping off the edges. Lastly, I also put in a rubber base molding on the lower wall edges. 4. Lights: Went with 3 strips of T5 strip lights that I had to custom order because I couldn’t find them in any local stores. The T5 are extremely bright (versus standard T8) which are nice to have for DIY repairs. I put in a switch timer as well so I can turn them on when getting ready to leave and close the garage door as I’m driving out without having to jump out and turn them off. 5. Cabinets: The cabinets are all diamond plate style in black steel. The upper cabinets all have hydraulic struts. The lower cabinets have a maple butcher’s block on top. Also put in a under mount paper towel holder and picked up a stainless steel adjustable stool. 6. Accessories: I put in an old sound bar that wasn’t being used and ran the source cable through the wall into a wall jack for a direct line, but also have a Bluetooth adapter plugged in for music from a phone. I also put in mini-fridge on a rolling stainless steel cart, a wall mounted bottle opener with cap catch can and a mini-shelf to set a beer or phone for music. Lastly, I put up an atomic clock and a “M Production” poster near the door which also got a stainless steel kick plate. 7. The Car: 2010 E92 Space Gray, 3 Pedals, Black Leather on Carbon Leather Trim. Mods include: Akrapovic Slip-On Titanium Exhaust, 19" BMW 220 Wheels in Jet Black on Pilot Super Sports, black kidney grills, black side gills, black M3 badge, upgraded LUX H8-160 angel eyes, 70% tint and V1 Hardwire. |
09-17-2015, 11:09 AM | #2 |
Rep 656
09-17-2015, 11:28 AM | #4 |
Rep 348
09-17-2015, 11:34 AM | #6 |
Rep 12,310
That's amazing. I plan on doing something identical in the future, in Sparkling Graphite of course. The stripes would be in M colors.
I could also do this in a future man cave, where the furniture would be as close to Bamboo Beige as possible
Current:
16 F82 M4 GTS, Black Sapphire/Black, DCT 08 E92 M3, Sparkling Graphite/Bamboo Beige, 6MT 07 E85 Z4M Roadster, Alpine White/Red, 6MT 99 E36 M3, Techno Violet/Dove Grey, 6MT |
09-17-2015, 11:49 AM | #8 |
Rep 11,891
They tend to only get loud when asked to ride in my trunk
22 Phytonic/Coffee X5 45e (CoVID-free)
08 Speed Yellow 911 GT3 Sharkwerks 12 AW/Cinnamon X5d Sports Pkg (retired) 14 AW/Beige M6GC ZCP, MPE, V2 steering wheel, vorsteiner (retired) 08 SSII/Black E90 M3 (retired) |
09-17-2015, 12:05 PM | #9 |
Rep 947
09-17-2015, 12:52 PM | #12 | |
Rep 330
1. It is much easier to do a new floor versus an existing floor because surface preparation is EVERYTHING. Anybody can lay down some epoxy in a day, but 2 years later when it start peeling from hot tires it will be because the floor wasn't prepped properly. 2. You need to etch the surface, sort of like scoring it with sandpaper. You can do that with acid or a diamond grinder. I'll admit I got professional help here. My floor had some hardening agent applied by the previous owner so I couldn't acid etch. You can rent a diamond grinder, but I wouldn't advise it. Big, bulky, expensive and grinding it flat and even across the whole garage isn't done easily. It also creates a HUGE amount of dust. You can fashion your own dust vacuum, but the pro I had help me arrived with a special dust vacuum that was 6 feet tall and ran off a gas engine. 3. Invest in a professional product. I'd recommend Legacy Industrial but there are a few other consumer friendly outlets of industrial strength products out there. http://www.legacyindustrial.net/prod...-coating-kits/ 4. Depending on square footage, you need to budget some significant hours if you decide to DIY. For a 3 car garage like mine, I'd estimate solo labor hours with trips to the store for supplies, research and product preparation, etching, etc. is around 40 hours. I would also get a second helper when you are ready to lay down the coats. 5. Bottom line, if you have $1500-$2500 to spend on a pro, do it. DIY is not for the feint of heart. By the time you add in cost of good materials, supplies (you will need to buy buckets, applicators, spike shoe attachments, squeegees, etc.), labor, disposal time, research time you'll find the money spent on a pro is probably worth it. |
09-17-2015, 01:26 PM | #13 |
Rep 12,728
car and garage look great. and in the best color, too!
all this "three pedal" and recognizing a 2002 turbo enthusiast talk and no carbon roof?
09-17-2015, 01:36 PM | #14 |
Rep 3,482
Dat mini fridge, doe. I need to sell my snapple 3/4 fridge and switch to something smaller.
BMWCCA:518970 |
09-17-2015, 01:42 PM | #15 |
Rep 11,891
But your Snapple 3/4 fits those Snapple drinks so well!
09-17-2015, 01:45 PM | #16 |
Rep 11,891
Blood stains show on Bamboo Beige tho
09-17-2015, 01:54 PM | #18 |
Rep 11,891
Yeah, I would have expected a slicktop
09-17-2015, 02:10 PM | #19 |
Rep 3,482
Fits all my beer and energy drinks, too
And....female companions love it. They always compliment how spacious it is inside...
BMWCCA:518970 |
09-17-2015, 02:38 PM | #20 |
Rep 330
09-17-2015, 02:45 PM | #21 |
Rep 330
It was on the list, trust me!!! I took my 7 months just to find this one and the CF roof was first on the "preferred" list. Just finding a well maintained (documented) space grey in a 6MT will all black interior in a E92 was hard enough... and I flew to pick it up and a 12 hour drive home.
Now you're making me want to go hunting again... |
09-17-2015, 03:02 PM | #22 |
Rep 3,482
Hahahah I denno man....That's kinda sketch - but then again, I'm a pussy even when my car is on jack stands.
BMWCCA:518970 |
