03-26-2011, 05:01 PM | #1 |
Rep 67
Why are the connecting pies " s shaped"
So the stock connecting pipes from the rear exhaust are really curvey like 2 big "s" shapes. I notice a lot of aftermarket systems do not deviate from this.
Why however is there not just a straight pipe or straighter pipe without all the bends. I would think gas velocity would be faster through less turns and twists. I can see for a stock system to slow the gases down and thus be quiet but why are aftermarket companies not addressing this. I know for years exhausts would focus on providing a better direct pathway for the gases to flow. I cant see the curviness has any benefit?? |
03-26-2011, 05:09 PM | #2 |
Rep 5,012
Pipes need to clear suspension components and half shafts, so they have to be close to the differential. Problem is the stock exhaust has the muffler inlets all the way to the edges, hence that routing. But most importantly, a properly (Mandrell) bent pipe flows basically the same. Plus you have much more radical bends inside the muffler anyway .
03-26-2011, 05:36 PM | #3 |
Rep 2,736
Drives: 2008 E92 ///M3 Alpine White
The diff is in the way.
03-27-2011, 12:00 AM | #4 | |
4th down; 4th quarter? Renegade.
87
Rep 3,850
03-27-2011, 03:14 AM | #5 |
Rep 4,567
Here's a quick and dirty image I created to help illustrate why those twists and turns are necessary (other than just looking cool):
The first bend is to clear the rear differential. The second bend is to clear the camber link. The final bend is to line up with the exhaust canister.
'09 E92 M3: Space Gray, Black, Carbon Leather | ZTP 2MK ZPP 2MT 6FL | link 1 / link 2
Mods: M Performance exhaust | ZCP retrofit | Euro airbox | GTS DCT flash | JPN 240 ECU flash | Euro LCI taillights | CRT lip | OEM alarm retrofit | Space Gray bumper plugs | BMW Performance: Mk. II spoiler / Mk. II non-electronic steering wheel / mirror caps / front grilles / side gills / intake louvers / emblem |
03-27-2011, 09:31 AM | #6 |
Rep 726
2011.5 E92 M3 Jet Black, DCT, Competition, Premium 2, and Convenience Packages, Black Novillo, Enhanced Premium Sound, 15% Tint, Black Kidneys/Reflectors/Gills/Roundels, DINAN Full Exhaust, DINAN Tune.
2006 Range Rover Sport Supercharged Black everything. |
03-27-2011, 10:22 AM | #7 |
Rep 67
I get that but if you look at the pictue above you could aslo draw a "straight" line through the middle of all the "s curves" and you would clear everything as well. I have seen that in many other cars where aftermarket essentially removes most of the bends in their aftermarket stuff. I really think it is more about slowing exhaust gas down then avoiding stuff. I mean yes it has to avoid certain things and cant be perfectly straight through but you could essentially have a very gradual straight curve fit in that same area with no issue looking at the picture.
The S of the curve actualy looks like it is RIGHT against the diff whereas a straight one could avoid that based on the pick if you picture a straight one through the center of all the middle points of the S curves |
03-27-2011, 11:55 AM | #9 |
Rep 687
Could you remove bend 1 and 2 and go right next to the diff but wrap the piping with header heat wrap?
2008 Alpine White E92 ///M3
03-27-2011, 02:25 PM | #10 |
Rep 4,167
Cool thread, interesting.
Audi R8 v10 Ford Raptor m3e46freak@yahoo.comfor all euro parts!! ebay/craigslist verified/ m3post/e46fanantics/m3forum/zpost/bimmerforum |
03-27-2011, 02:30 PM | #11 |
Rep 67
That is the point, didnt you look at the picture above? My whole point is the current S setup makes the exhaust pipe almost touching the differential-now how is that good as far as heat goes? A straighter pipe would be MUCH further from the componenets than the S shape now-just look at the picture and draw a straight line connecting the pipes to the mufflers instead of the S-pipe.
04-12-2011, 06:54 AM | #12 | |
Rep 896
You also got to think about "cut outs" and mounting points for the S-shape pipe. To put in a stright pipe you would need new mounting points at least so aftermarket manufacturers probably don't feel like messing with all of that so they leave the S shape like the stock configuration. |
04-13-2011, 07:53 PM | #13 |
Rep 7,652
not all designs follow that convention. Here is the bastuck with a much straighter piping design.
04-17-2011, 12:45 PM | #15 |
Rep 12
I think what the OP is trying to say/ask, what is gained by keeping the S curves? Straight pipes are definitely possible since there is already a manufacturer who does it, but why do most manufacturers keep the curves? I too would believe there is certain reasoning behind that might of been found during R&D.
