07-27-2020, 01:21 PM | #1 |
Rep 843
Drives: 2009 E93 M3
Garage List 2008 E90 M3 [0.00]
1995 BMW M3 [0.00] 2004 BMW M3 [0.00] 2011 BMW 335xi [0.00] 2011 BMW 335is [0.00] 2009 BMW M3 [0.00] |
[IMG][/IMG]
Hello Guys, I'm having an issue where the passenger rear wheel isn't sitting as flush as the driver side wheel. I just got alignment so both sides have matching alignment. So I'm questioning on whether it's a bent control arm of some sort or maybe an issue with the subframe. Has anyone had any similar issues? |
07-27-2020, 02:05 PM | #2 |
Rep 2,747
If you look under the car at the offset camber adjuster bolts on the rear subframe you'll probably find they don't match. Or if you've had subframe work done your subframe isn't aligned properly. Did you request a 4 wheel alignment?
9ers
07-27-2020, 02:29 PM | #3 |
Rep 1,568
check if they installed the wrong rims on the tires - the tire sizes might be in the right spot, but you might have a front rim on the rear tire, installed on the right rear, which could cause this variance as well. i caught this one time soon after I had a fresh set of tires installed and drove around.
07-27-2020, 02:30 PM | #4 |
Rep 843
Drives: 2009 E93 M3
I'll check this out, yeah I got a 4 wheel alignment. Hopefully it's something as simple as that
