BPM
      12-21-2017, 04:11 PM   #1
Suspence
Suspence's Avatar
Drives: 2011 E90 M3
Send a message via AIM to Suspence
Issue with my idle
I was trying to get it on video but I didn't catch it. Every time I come to a stop at a stoplight, if I have my clutch out, not in gear, it tends to drop RPM's to about 300. It'll sit at 600 no problem, but out of nowhere it'll drop suddenly like I'm about to stall out. It's been happening the last month or so. I can feel the car start to sputter a bit. Idle control valve? Gas issue? Car is on 91 Shell and VF Engineering tune IPE exhaust with primary cats. It's been fine until the last 3-4 weeks.
Thanks for any input or help.
Spencer Berke | YouTube Vlogger | Social Media Marketing
I help companies with social media/photos/videos & more!
Website | Instagram | YouTube Channel | Car Build
      12-21-2017, 04:46 PM   #2
drrust
drrust's Avatar
76
Drives: E90 M3 DCT Sedan
There is a thread in the general discussion section on various idle issues. The one I've experienced was the fuel tank breather valve issue. If that is the problem it will only happen after you fill the tank. There is a DIY on replacing it.
      12-21-2017, 04:47 PM   #3
Suspence
Suspence's Avatar
Drives: 2011 E90 M3
Ok, should have done my research first. Thanks for the fast reply.
      12-21-2017, 06:29 PM   #4
EJT86
EJT86's Avatar
1701
Drives: 2011 M3 DCT
I think the jury is still out on that issue. I donít get it often but once in a while itíll happen when itís cold out
      12-22-2017, 02:32 PM   #5
Loki Motorsports
Loki Motorsports's Avatar
12
Drives: 2008 A30 E92 M3 6MT
Spencer, Does it happen even more so when filling up the fuel tank? Mine was doing it really badly, (The car would stall sitting at a red light) right after fill ups. Then after it sat overnight or so, the next start-up would be back to completely normal again. Ended up being my fuel tank breather. Not too tough of a DYI either!
-GARAGE LIST-
1: 2008 Interlagos Blue E92 M3 6MT
2: 400 WHP Turbo M52 E36 (Drift car)
      12-22-2017, 09:36 PM   #6
Suspence
Suspence's Avatar
Drives: 2011 E90 M3
Yeah, well thankfully it's not too cold here. It'll happen randomly.
Yeah, it happens after that but also any time at all, haha. I'm going in next week to SSR Performance to have it looked at. Thanks for the help.
      04-29-2018, 12:45 PM   #7
BOOF-M3
BOOF-M3's Avatar
Drives: 2011 M3
I think the jury is still out on that issue. I don’t get it often but once in a while it’ll happen when it’s cold out
Did they fix the idle?
      04-30-2018, 08:21 AM   #8
E92_TYLER
E92_TYLER's Avatar
54
Drives: 2009 E92 M3 DCT AW
2009 BMW M3  [0.00]
Also interested in hearing a fix for this!
Replaced my fuel tank breather and still have the issue..
When stopped brakes on idle bogs down to 500~rpm and causing annoying vibration,
when brakes are released idle goes back to normal.
Current: 09' E92 M3 DCT Alpine white / Black
Current: 13' F150 Fx4 -daily
Past: 04' E55 AMG, 03' E46 M3, 99' E36 M3,
92' 240 RB26, 03' SVT Cobra, 89' Fox 5.0
      04-30-2018, 11:07 AM   #9
EJT86
EJT86's Avatar
1701
Drives: 2011 M3 DCT
when brakes are replaced idle goes back to normal.
Brake booster leak
      04-30-2018, 11:49 AM   #10
E92_TYLER
E92_TYLER's Avatar
54
2009 BMW M3  [0.00]
Brake booster leak
Require replacement or possible repair you think?
      04-30-2018, 12:13 PM   #11
R3dliner
R3dliner's Avatar
Drives: 18 M3 6MT
Doubt its the brake booster. My idles at stop has been at 550-6 since day 1.
The vibration might be your motor mounts going.
If you changed the breather valve might be your IAC.
      04-30-2018, 12:29 PM   #12
EJT86
EJT86's Avatar
1701
Drives: 2011 M3 DCT
Replacement I believe. Thereís a bunch of threads out there where peopleís idle drops when on the brakes and turned out be a leak in the brake booster
      05-02-2018, 04:18 PM   #13
Denk
Denk's Avatar
Drives: X3 M40i
I had an issue with RPM's dropping at idle with the brake applied causing a very rough vibration and seemed to almost stall. Let off the brake and RPM's popped right back up. Eventually I had a brake booster failure which put it in limp mode. Replaced under warranty. I still had the idle dropping issue with the brake applied after the new booster. Dealer did a vacuum test, all good. Since it wasn't throwing a code, they said it's normal which is BS. Very annoying and not very confidence inspiring since it limped out on me before....or maybe it was another issue.
      05-02-2018, 04:51 PM   #14
BOOF-M3
BOOF-M3's Avatar
Drives: 2011 M3
One easy fix for under $90 and an hour of your time (depending on how the rear hose clamp comes off) is the thread for the breather valve that EJT86 has. This typically is not affected by hitting the brakes but it is common with fluctuating idol issues and many of us have recently changed it out with success.
Denk743.50
      05-04-2018, 04:27 PM   #15
E92_TYLER
E92_TYLER's Avatar
54
2009 BMW M3  [0.00]
Where is this said part?
      05-04-2018, 04:48 PM   #16
BOOF-M3
BOOF-M3's Avatar
Drives: 2011 M3
Under the plenum along the drivers side. Circled in yellow. If you can take the plenum off with confidence then you can do this DIY. You can't miss the breather valve.
      05-04-2018, 06:14 PM   #17
EJT86
EJT86's Avatar
1701
Drives: 2011 M3 DCT
Iím color blind, where is it?
      05-04-2018, 06:15 PM   #18
BOOF-M3
BOOF-M3's Avatar
Drives: 2011 M3
I’m color blind, where is it?
You fixed yours already. Nothing here for you to see.
      05-04-2018, 06:18 PM   #19
EJT86
EJT86's Avatar
1701
Drives: 2011 M3 DCT
I want to make sure you didnít mislead him
      05-04-2018, 06:19 PM   #20
BOOF-M3
BOOF-M3's Avatar
Drives: 2011 M3
I want to make sure you didn’t mislead him
I got this. Time for me to spread my wings mutant tortoise.
      05-04-2018, 06:22 PM   #21
EJT86
EJT86's Avatar
1701
Drives: 2011 M3 DCT
Iíd still sleep better if I made sure. Donít discriminate on those with a disability
      05-04-2018, 07:19 PM   #22
BOOF-M3
BOOF-M3's Avatar
Drives: 2011 M3
I’d still sleep better if I made sure. Don’t discriminate on those with a disability
Sorry sir.
Search this Thread:
Advanced Search
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
