      05-31-2021, 10:33 PM   #1
jvictormp
jvictormp's Avatar
Brazil
881
Drives: 2008 M3 E92 6MT
How can I turn off the cornering lights failure warning with NCS Expert?
Hi!
I've got the cornering lights failure warning on the dash, and I think it's related to the left ballast unit, but I'm not willing to replace it for now, so, right now I just wanted to turn off the warning.
I managed to find the following expressions and turned them to aktiv:
ERR_SCHWENK_L_IGNORIEREN
ERR_SCHWENK_R_IGNORIEREN
But could not find the following, as it was suggested in e90post:
KALTUE_FL_M2_6_M1_04
WARMUE_FL_M2_6_M1_04
The module I went was NFRM.
With only those first two, the warning kept on coming.
What else could I look for? Maybe in another module?
      06-01-2021, 10:24 PM   #2
patroklai
patroklai's Avatar
Drives: Camaro SS | e92 M3
Cornering light? You mean the inner lens that turns on while turning? If you're getting an error, it might be the bulb. Unless your talking about the corner lights?
      06-02-2021, 08:29 AM   #3
jvictormp
jvictormp's Avatar
Brazil
881
Yes, the inner lens.
This is the fault code from inpa
9CBF communication with StepperMotorBox left disturbed 73136 km 12.21 volts 0.00 volts no signal1 or vert test conditions fulfilled error currently present and already saved error would not cause a warning lamp to light up code: 9C BF 64 01 23 B6 AD 08
      06-02-2021, 09:00 AM   #4
patroklai
patroklai's Avatar
Oh I see.
You may need to code off adaptive function altogether or replace the module at the bottom of the headlight. I believe you can find those used on ebay. But once replaced you may still need to code it.
Check out this thread.
https://www.e90post.com/forums/showthread.php?t=709544
jvictormp881.00
      06-07-2021, 06:35 AM   #5
amrazM
mTekMods
amrazM's Avatar
Drives: like a granny.
edit vo remove $524 then vo write then flash cas and nfrm
G-Power Supercharged
jvictormp881.00
