04-03-2021, 02:42 PM | #1 |
Rep 614
New battery question
Just replaced my battery with the exact same battery type I had before. Now I realize that there is a very minor difference between the two.
Old battery: Cold cranking amps: 825 Reserve capacity: 135 New battery: Cold cranking amps: 850 Reserve capacity: 150 Everything else (brand, type, size) is 100% identical between the two. I did register the new battery. Based on the above difference, will I have any issues? Do I need the new battery coded? |
04-03-2021, 03:35 PM | #2 |
Field Marshal
6723
Rep 1,833
Drives: '08 E92 M3
Since you did register the battery - you will be fine. No coding is necessary once the battery has been registered to the ECU/DME. Registering is done simply to ensure the alternator supplies the correct output needed to charge the battery properly. PS: The E9X alternator has an engagement clutch that disconnects at wide open throttle (WOT) thereby given a few extra ponies at WOT..
///M Power-Belgium62742.50 dpilat858865.50 |
04-03-2021, 04:00 PM | #3 | |
Rep 614
04-03-2021, 04:57 PM | #4 |
Field Marshal
6723
Rep 1,833
Drives: '08 E92 M3
It has been said that the E9X Series cars are basically rolling cyborgs. A new battery - combined with an alternator outputting the correct voltage - to keep it charging when ancillaries are on, has beneficial effects that others have also noticed and commented upon over the years on this forum. The car may indeed feel better because the prior low voltage gremlins are now gone from the electrical system. The throttle bodies seem especially sensitive to low voltage - they throw codes when the battery is on its last legs, as are the traction control and EDC modules. There's probably a placebo effect too, but keep in mind replacing the battery also causes some of the prior stored codes and adaptations to clear. Enjoy.
dpilat858865.50 ///M Power-Belgium62742.50 |
