      11-29-2017, 10:42 PM   #1
M3MPH1S
M3MPH1S's Avatar
Drives: 2010 E92 M3
DIY engine ground cable replace
This is a potential solution to issues with your car not starting. Sometimes the ground cable will get corroded or even damaged.
This is a very easy DIY
Part number: 12427840580
Part diagram: http://www.realoem.com/bmw/enUS/show...06#12427840580
Tools needed:
Jack
Jack stands
socket wrench
8mm socket
16mm socket
13mm socket
13mm wrench
Get the car up on jack stands and begin taking off the thick metal plate surrounding/attached to the front central jacking point. There are x7 16mm bolts (don't forget the one in the middle of the central jacking point!) and x3 8mm screws that connect to the transmission shield.
Once the metal plate is off, you can access the ground cable. It is located by the driver side header-to-xpipe connection. One side of the cable is attached by a 13mm bolt, and the other side of the cable is attached to a stud with a 13mm nut. The 13mm nut can be taken off with a standard 1/4in drive socket wrench with room to spare (so a 3/8in drive would probably also fit), but for the 13mm bolt, there is not enough room so you will have to use a 13mm wrench.
Put your new cable in and reverse all steps. Make sure you note that the cable has a different style "plate" on each end. The totally flat side goes with the bolt, and the "folded" side goes on the stud with the nut.
jun_e92140.50
M_Torx326.50
      11-29-2017, 11:13 PM   #2
Redd
Thanks. What problems/symptoms were you seeing?
      11-30-2017, 05:16 AM   #3
M3MPH1S
M3MPH1S's Avatar
Drives: 2010 E92 M3
I've been having issues where randomly the car won't even try to start. Electronics come on fine, but the starter is just silent, no struggling or anything. Then after I press the start button like 10 times it just jumps to life no problem.
I replaced the battery first, since it was 8 years old, but that did not fix it. So I saw another thread mentioning the ground cable and figured I'd try it. It's only about $40 so might as well. The starting problem would only happen about once in every 8 starts, so I won't know for sure until a few days out, but fingers crossed.
If this doesn't work, next up would be either the starter cable going to the positive signal from the battery, or the cable between the alternator and starter, or both. Following that I would finally try replacing the starter. I didn't start with that because there are a handful of threads where people replaced the starter and it didn't fix anything (same with the battery, so shame on me for not reading first ).
      11-30-2017, 08:04 AM   #4
doogee
doogee's Avatar
748
Your ground strap looks to be perfectly fine and isn't the problem.
I think it's time for a starter.
I went through the same issue.
Get to the starter and I think you'll find the ground strap from the solenoid to the motor will be loose. In my case, the resistance created enough heat after enough attempts to actually create contact and the starter would crank.
Replaced the starter and all has been well since.
roastbeef11574.50
dkexige61.50
irokwrx762.50
jun_e92140.50
      11-30-2017, 11:58 AM   #5
M3MPH1S
M3MPH1S's Avatar
Drives: 2010 E92 M3
Thanks for the tip. So would it not be possible to just replace the solenoid ground strap? Or is that an integrated part of the starter?
      11-30-2017, 12:01 PM   #6
doogee
doogee's Avatar
748
I thought the same thing.
I tightened down the nut and a few days later it was loose again. Very strange. Tried loctite and same thing.
There was clearly so much resistance in the motor that it was getting this connection really hot.
      11-30-2017, 12:03 PM   #7
M3MPH1S
M3MPH1S's Avatar
Drives: 2010 E92 M3
Well damn, can't ever be that easy right?
      11-30-2017, 12:06 PM   #8
doogee
doogee's Avatar
748
I had my damn manifold on and off for weeks trying to diagnose this!
Try tightening down that connection and maybe you'll get lucky!
M3MPH1S592.00
      11-30-2017, 12:07 PM   #9
M3MPH1S
M3MPH1S's Avatar
Drives: 2010 E92 M3
I'll try it out, thanks a lot for all the info!
      12-11-2017, 08:15 PM   #10
ec_E92
Enginerd
Drives: E92M3,E36M3,957GTS,E39M5S2
That cable sits right next to the driver side header and is exposed to elements. Enough heat cycles and wet weather and corrosion/fatigue from a vibrating engine will degrade these.
Here is mine at 110k, fell apart in my hands when I removed it.
2008 E92 AW 6MT /// 120k orig rod bearings
M3MPH1S592.00
roastbeef11574.50
rhyary1557.00
jun_e92140.50
M_Torx326.50
      12-12-2017, 09:57 AM   #11
doogee
doogee's Avatar
748
For sure!
Mine was the same way but did not solve my starting issue.
BMW is too cheap to insulate these wires like they used to.
      12-14-2017, 07:15 AM   #12
M3MPH1S
M3MPH1S's Avatar
Drives: 2010 E92 M3
Just an update, changing the cable seems to have helped very slightly, but it did not fix my issue. I went ahead and ordered a new starter, and hopefully that fixes it.
      12-14-2017, 08:08 AM   #13
ec_E92
Enginerd
If it is your starter that is going bad it makes sense you'd see a marginal increase with a new ground strap as it would prove less electrical resistance to the starter.
Good luck, not a very hard job but still a PITA!
      12-14-2017, 08:10 AM   #14
M3MPH1S
M3MPH1S's Avatar
Drives: 2010 E92 M3
Yeah the actual replacement of the starter looks quite simple, it's just getting to the starter that will be a pita
Tewie195.50
      12-14-2017, 08:34 AM   #15
pbonsalb
At 90k miles, the engine ground strap on my winter driven 08M3 is no longer shiny but is intact. I have treated it with deoxit and protectant. My exhaust grounds broke a couple of years ago and I made new ones.
      12-14-2017, 08:52 PM   #16
ec_E92
Enginerd
For $40 it might be worth it to just replace it proactively so you don't get stranded. I was lucky mine failed on my morning commute in my neighborhood (car just died on me while driving and would not restart). I was able to walk back home and get another car without too much delay to my day.
      12-15-2017, 06:53 AM   #17
pbonsalb
I have a lift and am under the car every month or two. As soon as I see a sign it is disintegrating I will replace it. I’ll be under there this weekend and will check it again.
It may be that people who drove with failing motor mounts prematurely stressed their cables. Or maybe people with the stock x pipe are putting more heat into that area due to the cats.
      12-15-2017, 09:25 AM   #18
WingZeroX5
WingZeroX5's Avatar
Drives: F80 / F30
I replaced my starter last year, pretty much the same symptoms you had. Tried the ground strap and it didn't do anything.
Made a thread about DIYing the starter. Not a bad DIY, just make sure you have flex sockets and the correct sizes.
I also sat on top of the engine to get to the bolts behind the engine. IDK why people were complaining it was hard to get to, but there is plenty space.
M3MPH1S592.00
      09-22-2018, 10:06 PM   #19
pbonsalb
GROUNDS ARE IMPORTANT! I have to follow up on my earlier post. Last month, I parked the car for a few weeks and it failed to start. Sounded just like a low battery. So I replaced that. Started ok the first start but not when hot. So I changed the alternator. Same results — started cold, barely started hot. So I changed the starter and solenoid. Same results. I am a bad mechanic right now — normally I would have put the car on the lift and inspected it but I am renovating the carriage house at my new house and everything is in storage so nI have no shop or lift or tools and am working outside with basic tools right now.). I spent $300 on an alternator and starter and a day of my time (battery was free) and did not fix the problem. So I added an extra ground wire from the front engine lift hook to an unused passenger side inner fender ground. Cranks fast when hot now. So it was the ground — the part I dismissed in an earlier post. And it sent me chasing my tail for weeks at a cost of time and money. I will be replacing my engine and exhaust grounds when my carriage house is done and I install my new lift (hopefully a month). GROUNDS ARE IMPORTANT.
M_Torx326.50
      12-30-2018, 03:14 PM   #20
GORDON.M3
GORDON.M3's Avatar
Drives: E92 M3 • F25 X3 M-Sport
A little word of advice, when replacing your ground cable...
Before installing the new one, heat-shrink it with a clear one. protects it from the elements and you can still see if it corrodes.
INSTAGRAM: GORDON.M3
M3MPH1S592.00
      12-30-2018, 04:00 PM   #21
roastbeef
roastbeef's Avatar
Are the exhaust grounds that critical? I always thought they were to get rid of static or something.
      01-02-2019, 08:02 AM   #22
Helmsman
Helmsman's Avatar
Sweden
4380
Drives: 2011 AW E90 M3 ZCP
Nope. Haven't had them mounted since years.
Tags
corroded, engine, ground cable, starter
Search this Thread:
Advanced Search
