08-09-2011, 12:30 PM | #1 |
Rep 74
Best tire sizes on E92 M3
hi guys,
i am looking for changing my wheels, and i just want to know what everybody recommend on the best size wheel/tire to go, basically i'll go for 19". |
08-09-2011, 01:01 PM | #2 |
Rep 1,575
if you plan on a lot of track days and dont have a set of dedicated track wheels, go for some 18s with a wide track. 10-10.5"
if tracking is a non-issue, 19s with 9.5-10" front and 10.5-11 rears would be nice and agressive.
08-09-2011, 01:11 PM | #3 |
Rep 1,530
Ok. You know what. I heard this a lot and despite SEARCHING I still couldn't figure out why 18s are "better" than 19s on track. Any explanation? Thanks
2011 E92 JB/BL/DCT--->80K Miles
2015 F80 SS/SO/DCT?->28K Miles 2015 Porsche 911S |
08-09-2011, 01:22 PM | #4 | |
Rep 4,232
http://www.caranddriver.com/features...sted-tech_dept |
08-09-2011, 01:26 PM | #5 |
Rep 1,379
Drives: Goal: Another ///M
I need to buy rear and wanted to go a little bigger.
14 Lexus GX460 & 14 Lexus ES300H 14 BMW 528d Touring Estate - UK Previous M's: 11 BMW M3 JZB ZCP 6MT, 02 BMW M3 Conv 6MT & 02 BMW M3 Coupe 6MT |
08-09-2011, 01:27 PM | #6 |
Rep 4,255
19x9 +25ish on 255s
19x10.5 +20ish on 275s No rubbing, with a solid stance, pretty much flush. My 2c. Our forum members have done some incredible things with their stances. 19x11 and 19x10s (see: EAS) are another combination I think looks incredible. Personally I wouldn't run it.
///M Power
08-09-2011, 01:27 PM | #7 |
Rep 4,232
08-09-2011, 01:30 PM | #8 |
Rep 4,709
Basically if you have an 18" and 19" wheel made of the same material, the 19" wheel will not only weigh a tad more, it will take more HP to rotate/stop it due to the barrel being further away from the center.
08-09-2011, 01:30 PM | #9 | |
Rep 783
2. 18" tires are cheaper than 19" tires 3. You run a thicker and stiffer sidewall with an 18" rim which allows for better feel, turn in, and traction
2021 M3 6MT Brooklyn Grey/Silverstone
Previous: 2009 335i ZMP 2013 M3 6MT ZCP Space Grey/Fox Red |
08-09-2011, 01:32 PM | #10 |
Rep 783
Eric, welcome to the forum!
For a 19" rim and a stock motor, it is best to run 255 in the front and 275 in the rear. If you are supercharged, go as wide as you can! I would say 275 in the front and 315 rear. It all depends if you want to have more grip or more balance
08-09-2011, 09:27 PM | #11 | |
Rep 1,820
08-09-2011, 09:47 PM | #12 | |
Rep 3,157
yes 18'' tires can be heavier but it also give a bit of flex which is want you will need. 19''s are a bit too stiff unless you have 19s with a sidewall that is slightly thicker like the GTS
Past: Gintani stage3 M3, Cayman GTS present: Porsche 993RWB, 964RS America,996 cupcar, 964 turbo 3.6,Macan Turbo,997GT2,930 turbo,i3, MINI JCW |
08-09-2011, 10:06 PM | #13 |
Rep 74
thanks guys, just everyone has different setting so i was trying to figure it out. basically i won't go track often maybe just once a while, so i think i'll be good with 19"
08-09-2011, 10:08 PM | #14 | |
Rep 8,952
Btw, I thought you were Eugene for a second. The screen-names are too similar |
08-09-2011, 10:09 PM | #15 | |
Rep 74
08-09-2011, 10:10 PM | #16 |
Rep 74
08-09-2011, 10:21 PM | #18 | |
Rep 109
08-09-2011, 11:16 PM | #19 | |
Rep 3,157
I'm not following you. but I do have 18s
08-10-2011, 03:03 AM | #20 | |
Rep 3,157
I think your reply is also subjective as well , off a link and everything becomes correct that 19s are better then 18s ok if you fell that way.
08-10-2011, 03:08 AM | #21 |
Rep 3,157
very funny Eric
