07-15-2018, 05:40 PM | #1 |
Rep 468
Tire brand and size advice
Hey guys I'm in the market for some new tires for my te37 sl 18x9.5 et15 x 18x10.5 et20 I currently have on them 265/35/18 and 285/35/18 rs-3. I want to run something more meaty. Suggestions and advice pls, thanks.
07-18-2018, 11:15 AM | #4 |
Rep 468
07-18-2018, 11:40 AM | #5 | |
Rep 21,703
The 265/285 combo is the easiest to find a matching performance set of tires.
07-18-2018, 01:18 PM | #6 | |
Stop the hate, get a V8
3850
Rep 8,625
If you are not tracking the car, why do you want something more "meaty"? That will just reduce your selection (as someone else alluded to), drive up the price, and decrease comfort & wet traction.
Past: 2011.5 M3 sedan ZCP |
07-18-2018, 04:43 PM | #7 |
Rep 6,734
You will not fit a 295/35 or 305/35 on the rear of your car with the offset you have. You might be able to fit a 295/35/18 Michelin PSS because that tire has a rounded shoulder. A more square tire will rub the painted fender at the 10:00 position on the driver's side. I always recommend 10.5 (or 11) et25 for someone who is looking to run a 295/35/18 tire. I have been able to fit a 295/30/18 Hankook TD on a 10.5 et20 wheel but that tire doesn't seem to run as wide as others - plus the smaller diameter (30 series) helps with fitment. A 295/30/18 Michelin Cup2 would definitely not fit since it runs wider than the TD. All things considered I would stick with the 265/285/35/18 combo if I were you.
'23 X7
