      09-24-2023, 10:03 PM   #1
bknight2851
bknight2851's Avatar
Drives: 2014 bmw 335i
2008 E93 M3 DCT
I have been chasing this problem with no avail. The car starts up and will occasionally misfire on idle. Once driving the car is perfectly fine under any type of load(meaning on the gas). As soon as I take my foot of the gas the car stalls out completely no matter the speed.
Once I get stopped I can turn the ignition off completely and restart the car and it runs the same till it stalls again.
Using INPA and ISTA I have found a few things.
-only modification is catless full exhaust dual resonated from valve Tronic
Section Dme
2b6b
2b57
2b6a
2b6e
2b6d
2b68
2b6c
2b69
2b67
2789
278a
2739
27c5
Section EGS
5a73-paddle shifter voltage fault
Section ASK
A1A3
Section FZD
A670
Section MOSTGW
E18D
E18F
Battery is brand new
Coils and spark plugs brand new
If you have any ideas please help!!
      09-25-2023, 11:49 AM   #2
RocketyMan
RocketyMan's Avatar
2008 BMW M3 E93  [10.00]
What spark plugs did you use? What coils did you use?
Be very specific!
2008 BMW M3 E93 MT
R135
..246
      09-25-2023, 12:54 PM   #3
askjeeves
Drives: e92 m3/spece30
Did you buy coil packs from any source other than BMW? The “oem” coil packs are all junk. Hope you saved your old ones.
2011 e92 ///m3 zcp - jzb/fr
ED 6/29/10
      09-25-2023, 02:10 PM   #4
pjk380
pjk380's Avatar
88
Drives: 2010 E92 M3
I would check the fuel system. Fuel pump might be going out.
      09-25-2023, 02:45 PM   #5
bknight2851
https://www.ecstuning.com/b-assemble...2137841754kt4/
This is the coils and spark plugs I used. They are OE parts and were professionally installed.
      09-25-2023, 02:48 PM   #6
Trinh_7
Drives: E90 M3 JB/BLK
That's probably the problem. None of the non-BMW coils work on the s65.
kolosy1493.00
      09-25-2023, 03:27 PM   #7
kolosy
Drives: over potholes
yeah those coils aren't OE or OEM even
Current '21 DG X5MC, '22 X5M50i, '11 E90 M3
Recent Past '12 E92 M3 ZCP, '08 E93 M3, '18 F80 ZCP, '04 E46 M3
I think I have an M3 problem.
DrFerry6728.50
      09-25-2023, 03:34 PM   #8
bknight2851
What coil pack and spark plugs would y’all recommend?
      09-25-2023, 03:35 PM   #9
kolosy
it's gonna hurt.
https://www.fcpeuro.com/products/bmw...93-12137841754
The NGK plugs are fine.
*edit* what was the reason for the wholesale coil replacement? do you still have the old ones?
DrFerry6728.50
      09-25-2023, 04:29 PM   #10
spammysammich
spammysammich's Avatar
1585
2009 BMW M3  [10.00]
This. There are a couple threads on the subject if you search. Very recently ECS made a guy send them a video of a resistance check with a multimeter before they would refund the money for the junk coils.
nick37531020.00
      09-25-2023, 04:30 PM   #11
spammysammich
1585
2009 BMW M3  [10.00]
You might also have a throttle actuator problem. Google those codes.
      09-25-2023, 05:46 PM   #12
RocketyMan
RocketyMan's Avatar
I hope you still have the stock coils. Those most likely would at least still work for the most part.
I've had some very poor experience in the past with ECS tuning. I've turned all my business to FCP as of late. Good luck on getting an RMA from ECS.
Let us know what you end up doing--but clearly those are non-useable coils.
2008 BMW M3 E93 MT
R135
..246
DrFerry6728.50
      09-25-2023, 05:48 PM   #13
bknight2851
Just to update you guys. One of my good friends works at a bmw dealer. Having him order the coils on discount directly from dealer will see how that goes
      09-25-2023, 05:54 PM   #14
RocketyMan
RocketyMan's Avatar
Awesome! I would suggest trying to get your money back from ECS. Coils for our cars are not cheap.
2008 BMW M3 E93 MT
R135
..246
      09-25-2023, 07:19 PM   #15
askjeeves
It’s crazy that a place like ECS is still selling coils that don’t work. This is a well known issue already. A company focused on selling BMW parts should know better.
ED 6/29/10
nick37531020.00
      09-25-2023, 08:09 PM   #16
kolosy
Not just sells, but actively markets as part of a kit. Borders on a scam. I don’t buy from them anymore unless absolutely necessary.
      09-26-2023, 10:11 PM   #17
RocketyMan
RocketyMan's Avatar
I 100% agree with this statement.
2008 BMW M3 E93 MT
R135
..246
      09-27-2023, 05:13 AM   #18
nick3753
nick3753's Avatar
1020
Drives: 2012 e92 M3 DCT ZCP
2017 Audi S6  [0.00]
1997 BMW 328i Touring  [0.00]
2012 BMW M3  [0.00]
It would also be helpful if those who have been down this road with them left reviews on these coils so that others don’t fall victim in the future.
