09-18-2023, 08:54 PM | #1 |
Rep 3
Replacing a s65 engine
Does anyone know where you can get a rebuilt s65 engine without breaking the bank in Atlanta GA? I have a 2011 E93 M3 and the engine is knocking, it sounds like a Rod bearing.
09-19-2023, 04:21 AM | #2 |
mTekMods
2143
Rep 2,902
what is your budget?
09-19-2023, 04:21 PM | #3 | |
Field Marshal
6729
Rep 1,829
Drives: '08 E92 M3
. https://trueautomotive.com/lawrenceville/ . https://trueautomotive.com/locations/ . Sorry to hear about the rod knock. Don't drive the car until the rod bearings have been replaced. Use B.E. Bearings with ARP bolts. . https://www.bebearings.com/ . https://www.bebearings.com/Overview.html .
09-19-2023, 08:48 PM | #4 |
Rep 2,023
i'm just not sure (admittedly knowing nothing about your specific spec / mileage) that it makes sense to rebuild. if it's in reasonable shape, you can probably sell it for 8-10k, and when you add the 10-15k that a clean engine install will likely run (unless you're doing it yourself, in which case -- carry on!), you're in no-story E93 land without the headache.
Current '21 DG X5MC, '22 X5M50i, '11 E90 M3
Recent Past '12 E92 M3 ZCP, '08 E93 M3, '18 F80 ZCP, '04 E46 M3 I think I have an M3 problem. |
