      01-14-2019, 05:02 PM   #1
wyatth
Drives: E90 ZCP
Trunk Cargo Net/Storage for 2011+?
Gents,
I am used to having a net in my trunk anchored at 4 points. To me this is the best organizer/storage solution. But of course the morons at BMW decided to remove the 2 forward anchors, I think, in 2011.
So what you guys doing for trunk storage/net solutions? Are the anchors something I could install and cut holes in the liner for? Any other solutions you swear by?
Thanks,
      01-14-2019, 05:16 PM   #2
Tewie
Tewie's Avatar
Drives: 2011 E92 ZCP Melbourne/FoxRed
Gents,
Thanks,
My 2011 e92 has 4 hooks...
      01-14-2019, 05:19 PM   #3
Tewie
Tewie's Avatar
Here.
      01-14-2019, 05:29 PM   #4
kscarrol
kscarrol's Avatar
Drives: 2011 E90 M3
Maybe it's an E90 thing but my 2011.5 E90 is as wyatth describes. I have the two hooks at the back of the trunk but not the two up front near the rear seats. Not sure if it is the production dates (2011 vs 2011.5 etc) or the E90 vs E92...
Edit: I do use a cargo net and simply double hook it to the points near the trunk...
2011 Space Grey E90 M3, DCT, Comp. Pkg.
1997 Z3 2.8, Artic Silver, Tanin Red interior, MT
1974 2002tii, Inka, 5 sp manual
BMWCCA # 327475
      01-14-2019, 05:54 PM   #5
wyatth
Drives: E90 ZCP
It must be an E90/92 thing. I have the 2 at the rear of the car, but not by the backseats. Mine is an 11.75, FWIW.
Nonsense to remove this, just as stupid as it was to make fold-down rear seats standard in the 92 but not the 90.
I could fold the net and double up at the rear anchors, but that's definitely not as functional as 4 squared anchors.
      01-14-2019, 05:56 PM   #6
kscarrol
kscarrol's Avatar
Drives: 2011 E90 M3
^ Agreed, silly to not have all four anchor points! Thankfully I did order my car with the fold-down rear seats but also silly to not have this as standard...
BMWCCA # 327475
      01-14-2019, 06:12 PM   #7
SFCM3
Drives: 2011.75 E90 M3 ZCP
my e90 is the same. im guessing the mounting point is there behind the trunk liner, can probably buy the front anchors and cut a hole in the liner to install. maybe i will give it a shot.
Current Garage - [2011 E90 M3 ZCP] [2005 E53 X5 3.0 Sport] [1988 E30 325IS 24V]
      01-14-2019, 06:46 PM   #8
wyatth
Drives: E90 ZCP
Cutting the liner is easy/clean enough, I did that with some coilovers in my previous E46M. I will also dig for a PN for the front anchors. Would be cool if it's a cheap/simple part that can bolt right in. What a stupid place to save some bucks.
Doable but kind of a PITA:
https://www.e90post.com/forums/showthread.php?t=336827
      01-14-2019, 08:32 PM   #9
Tewie
Tewie's Avatar
I believe mine is 2011.5 e92. Production date is 12/2010. All four hooks.
      01-14-2019, 10:38 PM   #10
wyatth
Drives: E90 ZCP
Letís make the practical body style less practical! #BMWlogic
      01-15-2019, 12:30 AM   #11
Maseroche
Maseroche's Avatar
Bahrain
39
Drives: '12 BMW M3
2012 BMW M3  [0.00]
Mine is a Dec/12 production Euro car. This is what mine has. My old '08 had a normal four hook. This 2012 has an updated six hook net.
IMG_20190115_092257 by Bℓow Fish, on Flickr
Khalid
'12 BMW E92 M3
'03 BMW E46 M3
'07 BMW E60 M5
      01-15-2019, 12:35 AM   #12
wyatth
Drives: E90 ZCP
I would be happy with that net even though Iíd need to poke holes in my rubber mat. You also have the normal 4 anchors. Time to search for that 6 anchor net ... any idea how they attach? Do the 6 anchors look oem? Odd youíd have a total of 10 from the factory.
* Onto something here: http://www.pantritrading.com/bmw-boo...476955266.html
https://www.e90post.com/forums/showthread.php?t=467045
      01-15-2019, 11:23 AM   #13
SFCM3
Another retrofit.
derbo967.00
      01-15-2019, 12:48 PM   #14
wyatth
Drives: E90 ZCP
^ Linked above.
I am going to try for the 6 point net pictured above. Looking for all of the PNs now. It seems like an easier install than the primary 2 front anchors.
      02-12-2019, 05:08 PM   #15
wyatth
Drives: E90 ZCP
Info/PNs on the 6 point net, post #20:
https://f80.bimmerpost.com/forums/sh....php?t=1565715
6 x Floor Cover Retainer: 51-47-6-955-266
6 x Floor Cover Hook: 51-47-6-955-265
1 x Cargo Net: 51-47-7-248-530
I am having trouble finding the male and female ends of the anchors. Otherwise it seems like these can be punched into our floor carpet the same way. Im curious how well they anchor though. If the net is holding down something big, wouldn't it lift the carpet/mat?
      02-12-2019, 05:58 PM   #16
Jive
Jive's Avatar
40
Drives: 2013 E92 M3
I just let the hookers roll around in the trunk however their cold unbeating hearts content. Really upsets the balance of the car at a trackís inflection point though.
      02-22-2019, 11:46 AM   #17
wyatth
Drives: E90 ZCP
The parts arrived and the anchors/hook system are pretty trick. The anchors will be a slight pain to install in the floor because its so stiff, but that stiffness will also prevent it from bowing as the net is loaded. Also way easier to install than the front 2 anchors that BMW removed.
Shout out to Get BMW Parts - the best prices on these parts and great customer service.
Guides I've found (may need to run Google Translate):
https://www.drive2.ru/l/7909175/
https://www.3er-faq.de/e90/anleitung...chruesten.html
I'll try to add my comments when I get around to installing.
6ixSpd4184.50
      02-26-2019, 01:42 AM   #18
Maseroche
Maseroche's Avatar
Bahrain
39
Drives: '12 BMW M3
2012 BMW M3  [0.00]
If you need specific pictures or closeups just tell me. More then happy to post some.
Khalid
'12 BMW E92 M3
'03 BMW E46 M3
'07 BMW E60 M5
      02-26-2019, 06:59 AM   #19
shimmy23
e90 daddymobile
shimmy23's Avatar
1091
Drives: e90 IB M3
If you're taking grocery getter hooks, I'm about to install some audi flip down hooks. Loved them in my A4.
What exactly would you put in our trunk that would require a storage net? Maybe it's because it's 5am, but I don't see what I would transport that would need a net
-brandon
e90 IB journal
      02-26-2019, 10:32 AM   #20
wyatth
Drives: E90 ZCP
Anything from a grocery bag to a pizza, whatever is prone to sliding that Id rather it not.
Used it a lot in the E46. The bag hook would solve half of it but wouldnít work for my pizza boxes.
I actually donít drive my car much or haul things but at least twice per month I get take out pizza from a small town about 10 miles away, the pizza is the best in CA and the drive there is fun. I dont want a hot pizza on leather and I donít want it sliding around the trunk.
      02-26-2019, 11:24 AM   #21
shimmy23
e90 daddymobile
shimmy23's Avatar
1091
Drives: e90 IB M3
Used it a lot in the E46. The bag hook would solve half of it but wouldn’t work for my pizza boxes.
I actually don’t drive my car much or haul things but at least twice per month I get take out pizza from a small town about 10 miles away, the pizza is the best in CA and the drive there is fun. I dont want a hot pizza on leather and I don’t want it sliding around the trunk.
Solid use of a net. I'm getting pizza tonight
-brandon
e90 IB journal
      02-26-2019, 11:32 AM   #22
wyatth
Drives: E90 ZCP
Haha!
Now I'm hungry.
Search this Thread:
Advanced Search
Copyright ©2000 - 2019, vBulletin Solutions Inc.
