      08-11-2018, 02:15 AM   #1
e92m3sf
Drives: e92 m3
Thermostat stuck in thermostat housing
There must be an obvious screw/sign/button that I'm missing somewhere on this thermostat housing because this thermostat is STUCK in there... Can someone tell me whats the easiest way to get this thermostat out of the housing
      08-11-2018, 08:33 AM   #2
WingZeroX5
WingZeroX5's Avatar
Drives: F80 / F30
You just have to pull harder.
I set the assembly on the floor, used my feet to hold the housing, then used large pliers to pull the actual thermostat out. It's like Mario pulling a turnip from the ground
      08-11-2018, 10:21 AM   #3
JsL
Drives: 2011 AW M3 ZCP
Good advice above. I did the below.
CAREFULLY... Use a screwdriver and pry it out. Don't pry around the edges, stick the screwdriver in the opening where the coolant would flow and pry.
Also, may want to set the housing on a cloth so you don't scratch it.
      08-11-2018, 05:46 PM   #4
GORDON.M3
GORDON.M3's Avatar
Drives: E92 M3 • F25 X3 M-Sport
just pry it off with a flat head or chizzle away at the black hardened gasket. it's stuck because the rubber gasket has hardened and pretty much lodged itself in between the housing.
INSTAGRAM: GORDON.M3
North American Mr12Volt Carplay/Android Auto Distributor
      08-11-2018, 07:42 PM   #5
e92m3sf
Drives: e92 m3
I figured I needed to use more force, but I was afraid to f- something up
THanks guys
      08-11-2018, 09:45 PM   #6
GORDON.M3
GORDON.M3's Avatar
you won't damage anything, the thermostat housing is a very strong piece.
Even if you scrape up the sides of the housing, it cleans up and seals perfectly fine still.
But of course, do everything with caution. Also if you can buy the replacement o-rings for the two tubes if your car is a higher mileage S65.
      08-14-2018, 01:14 AM   #7
e92m3sf
Drives: e92 m3
I was afraid to use force in the beginning, but after I read the responses, I got it off with two channel locks gripping the thermostat
