09-03-2019, 05:58 AM | #1 |
Rep 117
Apex EC-7 fitment question
What’s up guys, I’m looking to buy a new set or apex etc-7s. I love the deep concave look on these wheels and I’m shooting for as flush a fitment as possible. I’m looking for 19s. I currently have 245s up front and 275s in the rear and I also have 12.5mm spacers all around, but would be happy to ditch the spacers if that would help me get better fitment, if not I will keep them. Any help is hugely appreciated ! Thanks
09-03-2019, 10:26 PM | #2 |
Rep 201
Drives: E92 M3 | F15 X5 | G30 M550i
19x10 ET25 with 275/30/19 and 19x10.5 ET22 295/30/19 would be best for what you are looking for.
Fronts are ideal, but rears not so much. Apex doesn't make 19s for the rear with the best offsets. ET25+ would be much better for a 295. You can run 285s instead, but there isn't a great selection of tires in that size. I had that setup on my old M3 and fitment was flush. The fronts will be a problem if you have suspension larger than stock. Otherwise it's fine Rears may slightly rub at first depending on how low you are. After a few hundred miles it goes away.
Previous- E46 M3 | E63 M6 | E92 N55 335i |E70 X5M | | E92 M3 | W211 E55 AMG | E30 325is | W204 C63 AMG Current- '11.5 ZCP E92 M3 | '17 F15 X5 | ‘18 G30 M550i instagram.com/xuvm |
09-04-2019, 08:48 AM | #3 |
Rep 1,320
I run EC7s on my E93. My wheels are:
9.5X19 et22 10.5X19 et22 and I USED to run 265/30/19 & 285/30/19, but tire seizes are extremely limited nowadays. Thus, NOW I run 255/35/19 & 275/35/19 PS4S and the fitment looks great. I wouldn't say super flush, but def the right look. |
09-05-2019, 06:49 PM | #4 |
Rep 6,758
With the wide fenders on the E9x M3 chassis, there are a wide variety (no pun intended) of APEX wheel fitments that can work, with or without spacers. The sheer amount of options can be scary, but here is a small taste of what staggered fitments we have found to work best!
If you wanted wheel widths the best suit your current tire sizes, we would recommend the following staggered fitment which replicates the OEM ZCP/GTS wheel specs: Front: 19x9" ET28 with 255/35-19 tires Rear: 19x10" ET25 with 275/35-19 tires
You will not need to use any spacers with the fitment as listed above. This is a direct, drama-free fitment! If you are looking for something a bit more aggressive (flush), while still maintaining a spacer free fit, we would recommend the following setup. You can reuse your current tires until they wear out, but they will be a touch stretched. Front: 19x9.5" ET22 with 265/30-19 tires Rear: 19x10.5" ET22 with 285/30-19 tires
We have worked hard to design an entire fitment guide that details every fitment on offer for the M3 chassis, including the two fitments listed above! The fitment guide for your chassis can be found here: LINK to E9x M3 Wheel & Tire Fitment Guide These guides are an overview of every fitment we offer for this chassis. I would highly recommend taking a look at this guide as it should answer most, if not all, of your questions. I hope this helps! Best, - Max
925-245-0773 /// info@apexraceparts.com
Wheels /// Accessories /// Vehicle-Specific Fitment Guides /// Careers Last edited by Expert@ApexWheels; 09-05-2019 at 06:59 PM.. |
10-09-2019, 05:17 PM | #5 | |
Rep 6,635
Expert@ApexRaceParts I bought an e90 m3 ZCP stock suspension no spacer car that apparently came with Apex EC-7 19x10 front with 255/35/19 tires and 19x10.5 rear with 285/30/19 tires. I want to know if I can change the rear tires to 275/35/19 to reduce the fender gap a bit? Car is for street driving rather than track. If 275/35 rear won't work, what would you recommend? |
10-10-2019, 01:09 PM | #6 | |
Rep 2,663
I have listed tire heights respectively below: 275/35-19: 26.6" 285/30-19: 25.7" It is also important to note that the 275/35-19 can work but is not ideal when mounted on a 19x10.5" wheel. We would recommend sticking with the the 285/30-19 for this application. - Max
Wheels /// Accessories /// Vehicle-Specific Fitment Guides /// Careers Last edited by ApexWheels; 10-10-2019 at 02:47 PM.. |
