08-16-2019, 08:31 AM | #1 |
Rep 234
Increases Emission Error
I recently did a secondary Cat delete on my e92 m3 and started to incur a Increased Emission error . I did not touch the primary . I called the shop and he basically said that it’s a sensor and nothing related to his work . Strange if you ask me . I ran a OBD on it and these are the following codes it spat out :
P2432 P2430 P279D P279 Thanks for your help guys !! |
08-16-2019, 10:51 AM | #2 |
Rep 3,972
Do some research, none of those codes have anything to do with 02 sensors.
Even if it was, they aren't related to chopping off the secondary cats.
08-16-2019, 12:55 PM | #3 |
Rep 234
I did do some research and it appears there are no definitive answer out there . From what I read it might be a crack in the hose line
08-16-2019, 12:56 PM | #4 |
Rep 4,427
I know I had my secondary cats removed about 3 years ago (primaries still present) and have yet to receive an increased emissions code.:
08-16-2019, 02:26 PM | #5 |
Rep 4,105
2021 X3 M40i
OldenburgerM372.00 |
08-16-2019, 08:12 PM | #7 | ||
Rep 234
08-16-2019, 08:23 PM | #8 |
Rep 2,989
What's the mileage and model year of your car...?
INSTAGRAM: GORDON.M3
DINAN | EVOSPORT | VAC | ARP | RD SPORT | NEEZ | EIBACH | CSF | IND | BILSTEIN | KLASSEN | BREMBO | ENDLESS | BBS | BPM SPORT | PROJECT MU | EVENTURI |
08-16-2019, 08:33 PM | #9 | |
Rep 234
91000KM |
08-16-2019, 09:04 PM | #10 |
Rep 2,989
Original O2s, then it's normal, time to go.
My car has 80,000km now and I have done the primary O2s 3 times already.
08-16-2019, 09:30 PM | #11 | ||
Rep 234
Thanks buddy ! I'm going to get it fixed Tom . What's your setup like? Would could be reason for it failing |
08-16-2019, 10:01 PM | #12 | |
Rep 2,989
The previous owner of my car also did them at the dealership before I got the car.
08-17-2019, 08:43 AM | #13 |
Rep 1,256
What? This is NOT normal.
08-17-2019, 12:09 PM | #14 |
Rep 2,989
doogee is right, it isn't normal for them to go bad so soon but for the s65 its in of best interests to have them replaced earlier as preventative maintenance.
Noticeable improvement of fuel economy as they no longer read as accurate as they once were, the car is also a lot more responsive. I still have primary o2 sensors that had roughly 30k,KM on it, if you want them let me now.
08-17-2019, 01:54 PM | #15 | ||
Rep 234
If I was to get a tune since I'm taking out the primary cat .. would this help with the problem or no ? |
08-17-2019, 02:38 PM | #16 | |
Rep 2,989
The o2 sensors are a closed-loop system measuring the unburnt hydrocarbons in your exhaust gasses as they escape the rear end. When you are running a car without o2s its called open-loop. Getting a tune only suppresses the light from coming on. If you have other problems/codes happening on your engine, it might not be only just the o2 sensors. Have the car properly diagnosed (take it to a professional instead of doing guess work on the forum) before you start dumping money on replacing things that might not potentially solve your problem.
08-17-2019, 03:28 PM | #17 | ||||
Rep 234
GORDON.M31403.00 |
