09-28-2017, 06:09 AM | #1 |
Rep 98
Oil Analysis Back. It's Terrible
Hi Fellow M3 Lovers. So I have my 08 E93 for about 3 months now. Great car. Love it. It had 42,000 miles when I got her from a local Mercedes Dealer here in Florida. It is a like new piece and an easy purchased for me considering how little it was driven.
So I decided to have the oil checked at blackstone just as a baseline check. The results were HORRIBLE coming in at 20 PPM of lead. Highest I have seen in the reports listed on this site from many of you guys. The engine has no noises whatsoever and as an automotive pro for 39 years i know what bearing knock sounds like. This engine does not have any of that. It runs like a raped ape and revs incredibly smooth. But, 20 PPM isn't something I am comfortable with considering the history of this engine. So here is the question that prompted this thread. I got an extended 36,000 mile warrantee when I got the car. My thoughts were to have my buddies at a Euroshop call the insurance company and attempt to get the bearings changed now... before they might be faced with a $25,000 bill. Do you think the extended warrantee company will take a preempted approach and save themselves a huge bill later? |
09-28-2017, 06:23 AM | #2 |
Rep 261
I'd say zero chance any warranty will do that. In my experience with my extended warranty company, they don't fix anything just because it's a known issue or it might fail. They wait until it actually breaks and there is failure or codes that indicate the issue and then there is justification.
09-28-2017, 06:52 AM | #3 |
Rep 106
M_Three,
Are you not in a unique situation with 39 years of experience and buddies with a shop? Maybe you don't wrench anymore, so bartering isn't an option. At least you'll probably be able to supervise the work and ensure that your baby is handled with kid gloves. |
M_Three90.00 |
09-28-2017, 07:07 AM | #4 | |
Rep 1,566
M_Three90.00 byroncheung179.00 |
09-28-2017, 07:20 AM | #5 |
Rep 258
My 08 was at 36 PPM with 27k miles at a slightly higher than normal interval of 10,700mi. Had the bearings changed two weeks later.
09-28-2017, 07:20 AM | #6 |
Rep 3,997
Welcome!
How was the copper levels from your report? Is there a time period on your 36k warranty? I doubt any warranty will cover preventative maintenance which is what changing the rod bearings would be classified as.
M_Three90.00 |
09-28-2017, 08:13 AM | #7 |
Rep 1,216
While I doubt they will do a preemptive change, it's worth a call to create to record and let them know you're documenting the oil analysis. Then, I'd keep a close eye on noises when it's cold and when it starts to make noise bring it to your shop. Let a shop determine your bearings are failing and see what they say. It's either replace them now or replace the shortblock when you puke a rod out of the block.
2011.5 E90 M3
LeMans Blue |
09-28-2017, 08:17 AM | #8 |
Rep 10,680
I doubt a warranty company will do any preemptive work. The motor might keep going until the warranty expires. But if it does not, you have the inconvenience of hassling with the warranty company and having your car down for a while -- who knows how long (some have been without their car for months when the engine has failed). But since you are a pro, you could change the bearings for $500 in parts and a day of your time.
M_Three90.00 |
09-28-2017, 08:18 AM | #9 |
the doctor
284
Rep 432
I have an extended warranty. I did the rod bearing myself and tried to get reimbursed for the cost. They declined it.
However, there is no guarantee that if your engine fails that they won't deny the replacement of the engine. Extended warranty companies are notorious for denying claims. Are you going to fight them in court. Spend the $2500 to get the bearing replaced. It's unlikely they are going to buy brand new parts from BMW and build you a new engine. If they decide to cover the repairs it's more likely they will find a used engine. Who know the condition of the used engine. If your car runs well. Spend the $2500 to replace the bearings. I bought mine with 85K. I had MRF engineering do the bearings within 2 days of my purchasing the car. I would also recommend that you read your extended warranty contract. Last edited by Dr. Dre; 09-28-2017 at 08:24 AM.. |
09-28-2017, 08:34 AM | #10 |
Rep 800
Generally, warranties only cover up to the value of the car, which diminishes yearly. Is a '08 E9X with 42K miles worth $25k?
If your engine blows and they replace the engine for $25K, you might not have anything left in your warranty f your car is only worth $25K.
09-28-2017, 09:13 AM | #11 |
Rep 192
Consider this too: even if the bearings go while you're still under warranty AND the warranty company kindly steps up and replaces your engine with another used one (that may or may not have been treated worse than your current one), there is no way to determine that the "new" engine won't be subject to a similar failure on down the road, possibly after the warranty coverage has run out. I think the fact is that if you plan to keep the car longer term, bearings have to be addressed eventually. Doing it sooner than later might save some headaches.
M_Three90.00 |
09-28-2017, 09:30 AM | #12 | |
Stop the hate, get a V8
3853
Rep 8,625
All you have is a single reading from a single sample -- the whole point of UOA is to establish a baseline and trends. I wouldn't panic yet. Keep driving the car and take another sample every 1,000 miles to see where it goes. You can do this with a turkey baster in the oil filter housing. And no, I don't see any warranty company (or even BMW) pre-emptively replacing bearings because of a single oil analysis result. Typically you have to wait until something fails.
Past: 2011.5 M3 sedan ZCP |
09-28-2017, 10:17 AM | #13 |
HMFIC
372
Rep 522
Drives: 2016 F80 M3
Op... one option you have is to go ahead and tear down the engine and check your bearing clearance. If it is not within spec then you will have justification to file a claim with your warranty company to replace the rod bearings. If they are within spec then the bill is on you and you can either put everything back together or go ahead and replace the rod bearings.
M_Three90.00 |
09-28-2017, 10:18 AM | #14 | ||
Rep 1,566
M_Three90.00 |
09-28-2017, 10:21 AM | #15 | |
Rep 804
Drives: Some fun stuff
Now that you have it and can drive it properly, put some miles on the car and see how things look. |
M_Three90.00 |
09-28-2017, 10:25 AM | #16 | |
Rep 800
Sure, the engine itself is not $25K, but now let's factor in labor.
M_Three90.00 |
09-28-2017, 10:33 AM | #18 |
General
64679
Rep 24,942
Usually a used S65 is crap and a waste of money !
M_Three90.00 |
09-28-2017, 10:49 AM | #20 | |
Rep 800
M_Three90.00 |
09-28-2017, 10:55 AM | #21 | |
Rep 1,566
http://www.ebay.com/itm/BMW-E90-E92-...hZnyQV&vxp=mtr EDIT: Post 414 in this thread will tell you how much a 3rd party warranty was prepared to cover for a complete engine replacement (parts and labor). Keep in mind this was 2 years ago, the cost of the used engine is lower now. http://www.m3post.com/forums/showthr...119912&page=19
M_Three90.00 |
09-28-2017, 11:24 AM | #22 |
Rep 448
Mike Benvo was selling a rebuilt motor with new bearings for $11k in the classifieds a while back. I'd take another sample in 1,000 miles or so, and if the numbers are still not good, consider getting a used motor from a forum member here. One sample wouldn't be enough for me to rip apart a perfectly good running engine especially with those low miles.
M_Three90.00 |
