03-07-2024, 04:19 AM | #1 |
Rep 1
New Tie rod end will not tighten to torque spec.
2012 BMW 335i E92 Replacing the tie rod ends.
Taper is bottomed out all the way with a 21mm wrench while counter holding the stud with a T40. I can put all my weight into the wrench and it’s definitely bottomed out. When I go to tighten the 21mm with a socket on my torque wrench set to 122 ft lbs it will not get anywhere past 100 ft lbs and starts to spin the stud with it mobdro . Even if I put a jack under the ball joint it still spins when trying to get a click out of my torque wrench. I did not have this problem on the other side. I removed the nut to inspect everything and noticed some metal shavings on the threads of the nut. I am 100% positive I did not cross thread anything. The nut spun on smoothly by hand until it reached the nylon lock. Where should I go from here? Last edited by wadde; 03-11-2024 at 07:15 AM.. |
03-07-2024, 05:07 AM | #2 |
mTekMods
2143
Rep 2,902
jack under the ball joint of the tie rod end and send it home with an air gun.
03-07-2024, 07:14 AM | #3 |
Rep 3,988
You need to hold the ball joint stud with the T40 while tightening the nut.
RocketyMan229.00 |
