08-25-2020, 08:17 PM | #1 |
Rep 4
Drives: 2012 335i xDrive
Help - Key Fob starts engine but cant lock / unlock doors
Hi There,
I'm having problems with my key fobs, I've changed the batteries on all of my fobs but I cannot lock/unlock my car or use the comfort entry on any of my keys, the only way to start my car is to put the key in the slot. I've noticed that the range slowly dropped over a few days and I thought it was a dying battery but changing them showed no improvement? Is there any way to fix this before I resort to sending my car into a shop? Thanks, -Z |
08-25-2020, 09:09 PM | #3 |
Rep 4
08-25-2020, 09:41 PM | #4 |
Rep 12,711
that is odd, i'm out of ideas. usually the comfort access starts losing effectiveness with a dying battery.
08-26-2020, 11:05 AM | #5 |
mTekMods
2115
Rep 2,872
a scan with ista will tell you if there is a module or satellite which is inop.
08-26-2020, 11:52 AM | #6 | |
Rep 698
So if you have any aftermarket devices (radar detector, dash cam, etc), try removing them to see if that resolves the issue. |
08-26-2020, 07:06 PM | #7 |
Rep 4
Well I know this is going to be annoying but...
It fixed itself somehow. I took it for a carwash and 3 days later it started working again. Probably water leaking in somewhere causing a short or a loose wire. Maybe if it happens again I'll see if I cant get my coverage to fix it with an explanation on why it failed. |
Tags |
2012, comfort access, e92, help fix, key fob, lock |
