11-09-2014, 05:08 PM | #1 |
Rep 855
My Interior LED Mod experience.
I'm changing out the rustic amber LED's and updating them with a fresh blue.
I wish I could have written a DIY for this but, this is very involved. You must take apart almost everything inside "down to the bones". I wanted to share for others maybe looking to do this. You need soldering skillz (with a Z). If you never soldered before then I suggest you practice removing and installing surface mount parts on some crappy electronic first!! LEDs are small and also burn fast if you have the soldering iron on them to long. If you do not have great eyes, you should have a magnifying glass. A digital multi-meter is your Friend!!!!!!! If you set it to the symbol that looks like the diode symbol (LEDs are diodes after all), you can actually make the LED illuminate. The black lead goes to the side of the LED with the corner notched out. BEFORE YOU REMOVE ANY LEDS, FIND OUT THEIR CORRECT ORIENTATION AND MARK IT WITH A SHARPIE PEN. I put some dots on the attached pics that shows orientation and color (if no dot or its on the LED, I don't remember). This is the PCB with the Hazard Button. Pry up on the little PCB to remove. This Board had 0603 surface mound LEDs. I was able to make the my size fit. This takes practice! The Start Button!! This LED goes on it's side. There's two resistors on the side with the LED, remove the smaller one to make it shine brighter CCC iDrive knob button. This is the hardest so far. See the white things? Those have to come off by heating the back side of the PCB until the solder melts. My butane soldering iron has an attachment that blows hot air so I used that. It took about 2 minutes of slow heating to remove each piece but they will come off. These pieces are what makes the capacitive button feature work. Here, I have the new LEDs along side of where they will be installed between the large pads. Again, I challenged it with a larger size LED then the footprint that's on the PCB. To mount these pieces back, put some solder the ONE pad (PCB) that is going under the side of the piece with the colored dot. Place it down and put the soldering iron on the METAL right above the colored dot and wait for it to melt. you will feel it drop and you'll know its attached. On the other side of the white piece there is barely any metal showing but its enough to get it hot and flow solder under there. Skillz required on this unit. HVAC control (with LCD already removed). Blue Dots for Blue and White dots for white. I plan to revisit this.. I would like to put a blue and red LED under the temp band around the knobs.. This is the enclosure for the HVAC LCD. CAREFULLY slide the LCD out (not shown in pictures). It has a very delicate rubber strip that is the conductor. Under that is an orange strip. Use a razor and scrape the orange off. Half done here: Done! Heated seats control: Fun Stuff: I did not get any pictures of the steering wheel controls. You will need to remove the airbag for that! Read the DIYs and unhook the battery while your doing all this. Here is the head light control PCB: I didn't do the amber LEDs under the rubber since they cannot be seen anyway. If you haven't done it, now would be a good time to do the "Rear Fog Light Mod"! Shifter knob All the hardest parts out of the way!! The pictures SUCK! Sorry. The blues are much darker and richer. They are also all the same color and uniform (some look lighter and greenish in the pics).
-- 08 JB e92 6MT ///M3 ESS VT2-625 --
11-09-2014, 05:09 PM | #2 |
Rep 855
Update: Adding the window controls and ambient door lighting.
Figuring out how to access all the leds is like a puzzle. For the ambient door light, the light module slides out just enough to get to the tabs that lock onto the light pipe. Carefully slide it back (further than shown in the picture). You can see the tabs that holds it to the light pipe. And the board. Led stands on end. The drivers side mirror and window control Passenger side window control The ambient lights in the dome light modules are now blue. Sorry but it looks like I never took any pictures. The SOS button is still amber (i think for technical difficulties) but, I like the idea of a life/safety button in amber. I love it!
11-09-2014, 05:14 PM | #3 |
Grown Azz Man
429
Rep 3,021
So far so good......nice work. In for the finished mod...........Phil
2016 GT4.....Sapphire Blue Metallic, Platinum stitch Leather/Alcantara interior, Carbon Fiber Trim, PCM w/Nav, Guards Red Belts, 2 Zone Climate, Sport Chrono, LWB, Smokers Pack, Big Gas Tank, Light Design Pack, Bi-Xenon w/PDL, Auto Dim Mirror, Clear Side Markers, GTS Clear Taillights
11-09-2014, 05:46 PM | #4 |
Rep 584
Drives: 2023 M3 CX
I think it looks awesome! I dont have the "skillz" or time for this...
2023 BG G80 ///M3 COMP XDRIVE Dinan CF Intake | Valvetronic SS Full Exhaust | AST Adjustable Springs | UNIT 17 Front Splitter | UNIT 17 Sideskirts | BC Forged HSC21 Wheels 20x10 et12 / 20x11 et12 |
11-09-2014, 06:19 PM | #5 |
Ultimate Driving Machine E92ESS625 M3/G05 X5 Msport 40i Individual
456
Rep 2,000
Drives: 2011 E92 M3 DCT/ESS 625 kit
Looks amazing how did u get that display on ur screen. Looks awesome.
"The Ultimate Driving Machine"
2011 E92 M3 supercharged ESS 625 2016 F15 X5 Msport 35i |
11-09-2014, 06:37 PM | #6 |
Rep 57
Drives: 2009 Alpine White E92
What kind of display is that on your screen? Was that apart of your mod? Looks slick.
11-09-2014, 07:13 PM | #7 |
Rep 1,083
Spotify & YouTube? Want!
Nice Blue lights too
11-09-2014, 07:21 PM | #8 |
Rep 2,716
Drives: M3
Garage List 2016 BMW X5M [0.00]
08 BMW M3 [0.00] 14 BMW X5 50i - sold [0.00] 09 BMW 335i - Sold [0.00] 09 BMW 328i - Sold [0.00] 07 BMW 328i - Sold [0.00] |
Not really digging the color but mad props for the DIY!
Evolve, Eisenmann, Strasse, StopTech, Active Autowerke
11-09-2014, 07:46 PM | #10 | |||
Rep 855
http://www.m3post.com/forums/showthread.php?t=1030774
11-09-2014, 07:55 PM | #11 |
Rep 855
I'm sure the amber will appeal to more folks. My last three BMWs had it and my Pathfinder has it... I'm so happy to have a new color!
Like I said, my photos suck. I'll try and get some good ones soon that show color accurately.
11-10-2014, 08:58 AM | #12 |
M3NTAL
132
Rep 608
Jesus, talk about a project. I too am a fan of the amber but can respect the amount of work that went into this. You need skillz AND ballz to start messing with the boards. I'm a beginner to intermediate level solderer, but I wouldn't touch this
11-10-2014, 08:07 PM | #14 | |
Rep 855
The proccess for replacing SMPs is something like this for me: Prep Inspect the original LEDs first and find which side has the notch out of the corner. Use a marker and put a Good size dot. TAKE A PICTURE (incase the marker gets smudged off). If you are unsure which side is the "notched" side, use the meter. Removing the LED from the PCB The side of the LED on the ground-plain usually needs more time to heat up (your heating the metal in the PCB too). It also holds the solder melted longer (keep that in mind). Start there. Put a small bit of solder on the tip of your iron and put it to the part. You'll see the solder get shiny when it is melted then continue to hold it there for a few seconds. Quickly move the iron to the other side of the LED and melt that side. Use a little bit more solder if you have too.. the melted solder will help transfer some of the heat from the iron. Move the iron back and forth QUICKLY from side to side and it will slide right off the pads. Another way would be to use a hot air blower (my butane iron has an attachment), and circle around the LED while SLIGHTLY lifting with tweezers. NEVER PULL OR PUSH ON THE PART WITH ANY FORCE. You are melting the solder so it becomes unattached. When using hot air, use have to be careful it doesn't burn other parts or blow them right off the PCB. Remove one color at a time so it doesn't get confusing. Installing LED Clean the pad off with solder wick if needed. Apply a little flux paste (careful not to get it on your mark). Place the LEDs and Solder ONE side and move to the next LED. Soldering one side at a time gives it time to cool between. Don't heat soak the LEDs. If you're not getting it in place within a few seconds, give it a chance to cool and come back. Once you do all of them, do the other side. Testing Use the meter on the diode setting and make it illuminate by touching points on the boards (follow the traces). Some of the boards have little round test points that you can use. Clean Use rubbing alcohol and Q-Tips to clean up the PCBs. Clean the conductors for the buttons really well! Thats about the "Long of the short". And don't call me Jesus
11-11-2014, 12:04 PM | #16 |
Rep 2,448
This is awesome!!
What's showing on the screen? Is it from one of the BMW apps?
Current Bimmer: '16 F80 M3, '20 F87 M2c Gone but never forgotten: '13 FO e92 M3, Swifts, volks/advan, Akra Evo, Kics R40 Past: Alpine white e46 323i, Jet Black e39 530, Saph Black e60 530, Space Grey N54 e92 335, Mineral White N55 e92 335 |
11-11-2014, 01:45 PM | #19 | |
General
63077
Rep 24,610
BTW....hat off for OP...congrats man !
11-11-2014, 02:43 PM | #20 | |||
Rep 855
In a nutshell, its an AndroidPC connected to a "BMW multimedia interface". I posted a DIY link how to optimize Android for this a few posts ago. Quote:
Honestly, not for sure. If I had to guess, I would say its because amber would be the more desired color among most people.
///M Power-Belgium63077.00 |
11-16-2014, 09:18 AM | #22 |
Rep 1,486
Drives: 2012 e92 M3 DCT ZCP
Respect! How many hours of labor did this take?
