BPM
      02-18-2019, 02:10 PM   #1
Sanderb13
Sanderb13's Avatar
Drives: 2011 E93 M3
Fault Codes After Replacing Throttle Actuators
Hey Everyone,
I just replaced my throttle actuators and after clearing the codes it pulled up a few new ones that I never saw before. I tried doing research but cant find a answer that really explains what they are or what could be causing it. Any help would be appreciated.
      02-18-2019, 02:37 PM   #2
mapster37
mapster37's Avatar
Drives: F80
i would double check all of the connections under intake, check for any pinched wires as well....
      02-18-2019, 10:57 PM   #3
Space_M3
Space_M3's Avatar
Drives: 2011 Bmw E90 M3
I got the same code (2765/present Valve , inlet, bank 2, activation) and after taking everything off again I doubled checked all the wiring and the wire connection on Bank 2 Vano Solenoid wasn't fully plugged in! After putting everything back I erased the code and hasn't came back on yet! This should be your first Diagnostic! Hope it helps
      02-22-2019, 08:47 AM   #4
Sanderb13
Sanderb13's Avatar
Drives: 2011 E93 M3
do you know exactly which wire that is so I know exactly what to check even though I am going to check them all I want to make sure that one is 100% snug
      02-22-2019, 10:28 AM   #5
Sanderb13
Sanderb13's Avatar
Drives: 2011 E93 M3
Did you also get the code for EDC at the same time? If so did that go away as well?
