02-14-2019, 03:51 PM | #1 |
Rep 203
First sign of DCT issue?
Hi all,
I was pulling from a stop pretty aggressively in S4 mode and shifted into 2nd at around 6k rpm, all went well. From 2nd to 3rd I was on the throttle heavily and shifted at around 7k rpm. I felt and heard a clunk far worse than the typical shift coming from underneath and there was quite a bit of lag prior to the shift completing. Perhaps 2-3 seconds before it engaged 3rd with a thud. I took it easy for the rest of my drive and haven't had the issue again. But I am a bit concerned as this could be the first sign of an issue. has anyone run in to this? I'd like to be as proactive as possible at correcting it. I also have the Dinan DCT tune if that matters. |
02-14-2019, 03:59 PM | #2 |
Rep 1,617
That's how it felt for me on track when I had DCT issues. Replaced with Slon Workshop baffled DCT bottom pan and all is good now. Issue was transmission oil sloshing around and eventually limp mode for loss of oil pressure. (error codes reflected it)
Your situation is on street, so it's different. Perhaps your DCT oil is low? May be similar loss of pressure. |
BayE301341.00 |
02-14-2019, 04:18 PM | #3 | |
Rep 203
02-14-2019, 04:35 PM | #4 |
Rep 1,389
Intersecting.. how many miles OP? I just clocked 100K and have had some oddities start as well. guess I need to schedule a DCT oil change also. Is the labor pretty intense for this? Any benchmark cost estimates?
02-14-2019, 04:36 PM | #5 |
Rep 203
Only at 58k miles on mine. I'm not too sure on cost for this, I'll have to do some research.
02-14-2019, 04:39 PM | #6 | |
Rep 1,389
02-14-2019, 05:23 PM | #7 | ||
Rep 1,617
wfdeacon881105.00 |
02-14-2019, 09:26 PM | #8 |
mTekMods
2142
Rep 2,902
02-14-2019, 09:33 PM | #9 |
Rep 12,726
are you sure it wasn't wheel hop and traction control stepping in? was the ground wet or significantly cold?
02-15-2019, 12:03 PM | #12 |
Pwrdbym
60
Rep 343
The pans start leaking on the duct eventually. It will doa bunch of weird things when low on oil. When I discovered my leak and fixed it I only drained about 8 quarts of oil out. The DCT takes about 14.
02-21-2019, 02:41 AM | #13 |
mTekMods
2142
Rep 2,902
uwotm8
02-28-2019, 03:09 PM | #14 |
Rep 8,076
Drives: 11 E90 M3 Individual
I get the occassional clunk or weird shift but I don't worry about it. Not unless it happens again.
2018 F30 320iX Melbourne Red
02-28-2019, 03:16 PM | #15 |
Rep 203
02-28-2019, 03:58 PM | #16 |
Rep 1,389
I found out my DCT was 2 qts low on oil since I've owned the car... topped it off (until I get it fixed) and all of my issues are gone. Even cold start driving is silky smooth.... all of the cold jerking and occasional bangs/jerks are gone. Check your fluids if yours is jerky, because some stickied thread that said it was normal made me not realize I was really close to ruining my DCT.
