      04-05-2020, 03:32 PM   #1
E92Gok
E92Gok's Avatar
64
Drives: 2008 e92 m3
Rough cold start idle
Hey everyone, so I've been having this issue recently where my car had a rough idle on cold start. For a few seconds the needle jumps rpms from high to really low sometimes about to stall out. Only happens on cold starts after the car is warmed up it starts normally. My car is a 2008 e92 with 58xxx miles. Doesn't throw codes or anything. Possibly the idle control valve? Or maybe even the fuel breather valve? Anyone have a idea what it may be please drop a comment. Thanks!
      04-05-2020, 09:51 PM   #2
NeverL8
NeverL8's Avatar
523
Drives: Slow
I had the same issue, changed spark plugs and battery and the problem went away so far (been 2 weeks)
E92Gok63.50
      04-05-2020, 11:33 PM   #3
Bpark1977
Bpark1977's Avatar
Drives: E93 M3
Is your eco stock?
E92Gok63.50
      04-06-2020, 05:30 AM   #4
mapster37
mapster37's Avatar
Drives: F80
i had a similar issue. my was throwing a code for fuel pressure sensor. i replaced sensor-no more rough idle after cold start
E92Gok63.50
      04-06-2020, 10:17 AM   #5
E92Gok
E92Gok's Avatar
64
Drives: 2008 e92 m3
My battery and sparks were changed to long ago. Checked voltage on battery it was fine, so I doubt it will be that.
      04-06-2020, 10:18 AM   #6
E92Gok
E92Gok's Avatar
64
Drives: 2008 e92 m3
Originally Posted by Bpark1977 View Post
Is your eco stock?
You mean my ECU? I am running a tune from BPM, with a primary decat
      04-06-2020, 10:20 AM   #7
E92Gok
E92Gok's Avatar
64
Drives: 2008 e92 m3
Hmm interesting, haven't gotten a code yet. Hopefully nothing serious
      04-06-2020, 10:57 AM   #8
Bpark1977
Bpark1977's Avatar
Drives: E93 M3
Is your eco stock?
Lol. Autocorrect. Yes, your ECU.
I'd check and see if it's something they've had experience with.
E92Gok63.50
      04-06-2020, 12:10 PM   #9
E92Gok
E92Gok's Avatar
64
Drives: 2008 e92 m3
Is your eco stock?
Haha damn autocorrect. Gonna check my tune, that's a good point. Maybe if I return it too stock files see if the cold start improves that way.
      04-06-2020, 03:48 PM   #10
NeverL8
NeverL8's Avatar
523
Drives: Slow
Could also be Fuel breather valve, does your idle bounces after fill up?
E92Gok63.50
      04-07-2020, 08:44 AM   #11
E92Gok
E92Gok's Avatar
64
Drives: 2008 e92 m3
Nope nothing was happening after fill ups as well. I believe my tune is the issue. Went back to stock!
      04-07-2020, 08:48 AM   #12
E92Gok
E92Gok's Avatar
64
Drives: 2008 e92 m3
Update: I looked into my tune and went back to stock files yesterday. It had been sitting for a few hours so the engine was cold. Fired her up and it sounded great, no rpm bounce. Let her sit all night and started it up again this morning before work and no issues. I believe the tune was the issue. I will run it until I get my CEL (because I'm catless) back. And upload the tune again and see if that fixes it. Thank you all.
