12-17-2015, 05:20 PM | #1 |
30
Rep 132
PE | Performance Eurowerks | Shop Showcase
Performance Eurowerks | Shop Showcase IntroductionPerformance Eurowerks came into fruition due to the drive of enthusiasts wanting to give back to the community. Our team grew up enamored by all things automotive and motorsport. Through the many years, we gained so much experience through formal training, working on personal/client cars, participating at endless track events, and supporting competitive race teams. In everything we do, we take our experiences, grasp everything we learn, and do our best to serve the community. Moving into our new shop In 2015, we moved into a new shop that served to be a clean slate for us to mold into our own proficient work environment. After some minor renovation, we finally got it to a state at which we were ready to call our new home. Here's are a couple shots from the first day we got our keys. You'll notice in upcoming posts how it transformed from bare bones to fully stacked! Moments after getting keys, we scooped up a handful of client E46 M3s to get straight to working as we waited for all of our equipment to get moved. Shop Showcase In this thread, we'd love to share with you some of the work we do here on a regular basis ranging from simple product showcases to our own project cars to full client builds. We work on a multitude of different kinds of cars, so we hope you enjoy the diverse documentation we have to share! Shop Information Performance Eurowerks 1694 Barclay Blvd, Buffalo Grove, IL 60089 224.676.0756 Website |
12-17-2015, 05:47 PM | #2 |
30
Rep 132
BMW E92 M3 | Supersprint Race Exhaust
M3post member came by the shop for us to do a full Supersprint E92 M3 Race exhaust system. Supersprint has been one of the industry standards for decades, manufacturing some of the highest quality and top performing exhaust systems on the market. For this project, we installed the following: Supersprint Front Pipes with Resonators (PN 980902)Supersprint versus Stock Supersprint Front Pipe and XPipe The legendary Supersprint exhaust tips! With the stock exhaust removed, you can see the fancy factory header collectors. Supersprint Front Pipes are in! Supersprint Front Pipe with resonators. Supersprint XPipe smooth bends! Perfect alignment of the Supesprint exhaust as expected. Big tips! From dynoing a similar Supersprint setup on other cars, we usually get ~30-35whp/~20-25wtq throughout well majority of the power curve. We hope to visit the dyno with his car for a new baseline prior to flashing it with our new tuning solution from, mcchip-DKR Software Optimization from Germany! Keep an eye out for a formal announcement thread regarding mcchip-DKR in the very near future, you won't be disappointed. Last edited by Performance Eurowerks; 12-21-2015 at 01:53 PM.. |
12-21-2015, 11:20 AM | #4 |
Rep 3,387
12-21-2015, 12:36 PM | #5 | |
30
Rep 132
Thanks!
Here are several dyno graphs of another E90 M3 with similar Supersprint XPipe, but with cats. We don't expect the catless version to really yield any tangible and measurable gains versus the cat'd version. DynoJet SAE whp vs wtq - You can see the huge gains through the power band. The midrange showed the biggest gains of nearly 35whp and 25wtq. Peak figures are notated on the graph which yield roughly 28whp and 22wtq. DynoJet SAE whp vs AFR - Two good graphs to compare since AFR targets are nearly identical. The MSS60 DME does have a tendency to swing AFR values from run-to-run, so on an otherwise same "tune" it's crucial to compare graphs that have very controlled data variables. Dynojet SAE whp vs Ignition - Same two graphs to comparing hit Ignition targets. The MSS60 DME does have a tendency to hit different Ignition values from run-to-run, so on an otherwise same "tune" it's crucial to compare graphs that have very controlled data variables. |
12-21-2015, 01:52 PM | #6 |
Rep 3,387
12-23-2015, 04:12 PM | #7 |
30
Rep 132
Dyno & Data Logging | Eventuri E46 M3 CF Intake Since the advent of it's publicly announced prototyping, the Eventuri CF Intake for the E46 M3 surely created some buzz. The goal with the Eventuri CF Intake was to use some innovative engineering to produce an intake that actually made power, looked good, and sounded ferocious. The Eventuri CF Intake utilizes a fully pre-preg carbon fiber air filter housing with an inverted style cone filter. The air filter housing and filter create a venturi-like effect that naturally draws in air seamlessly into the factory airbox. In addition to the intake itself, they have supplementary accessories to make it a complete system. They include two heat shields to safe guard away from radiating heat from the engine. One of the most effective portions of the system is the CF air scoop/air feed. It directs air from the driver side brake duct and straight into the intake. This helps capture high velocity high volume cold air! The engineers at Eventuri spent a lot of time perfecting the airflow with the aspiration that it would actually create tangible power, that most other branded cone filters and intakes don't. We have spent a lot of time with the E46 M3 testing out different intakes and full carbon fiber airboxes. Once we finally got our own Eventuri CF Intake, we very excited to install and dyno test. Before going to the dyno, we went back to the stock intake and factory tune. The car was strapped down, baseline runs were taken. After that, we repeated the same test, minutes after with the Eventuri CF Intake. This time around, we visited a new dyno shop in the area. Unfortunately, they didn't have a data logger for us to graph certain parameters along with our whp/wtq. We brought our SnapOn diagnostic tool to do our best in monitoring some parameters before each run was taken place to try and control all variables respectively. With the Eventuri intake, controlling IATs were much easier which we think truly does attribute to the power/torque gains. Before each run began, we got the IATs to around the same 4-5ºF above ambient when cruising at a steady state in 4th gear. After the run was complete, IATs stayed fairly stagnant. The highest we ever saw was 6ºF above ambient. With the supplied heat shields and CF air feed by the driver side brake duct, we believe that IATs are managed much more controllably. The results we got after swapping in the intake truly surprised us. We honestly were not expecting the gains we measured. The results are staggering. With the dyno shop not having the typical fan setup that we're used to, we think that our baseline results might have been on the lower side of things since the factory system was just having a tough time with temps. Due to the brilliant Eventuri setup, it's simply able to suck in cool air so much more efficiently. As many know, the ECU in the E46 M3 is very sensitive to IATs. If IATs are on the higher side and if air flow is minimal, the ECU will certainly try to pull ignition timing and run on the richer side, hampering power. We do have plans to dyno back at our usual spot with a fan setup that we think we could better control IATs for both setups. Ultimately, we just want to provide accurate, precise, and repeatable results. Overall, we are so pleased that we had the opportunity to finally provide the community with an independent test of the intake. We hope you enjoyed this quick review. Vehicle Information 2004 BMW E46 M3 6MT Supersprint V1 Stepped Headers Supersprint V1 SPipe Supersprint XPipe Supersprint Sport Muffler OE CSL DME Conversion - 100% factory except for 6MT compatibility OE CSL MAP Sensor OE CSL IAT Sensor Dyno Data Here are all of the stock runs we did. We typically try to do runs quickly back-to-back to test repeatability. Since we had a tougher time control temps with the stock intake, we did have to space these out by a handful of minutes. Here are all of the Eventuri CF Intake runs we did. These three runs were literally done right after the other. In between runs, we needed just a few seconds to stabilize IATs and get to full throttle! Here are all of the runs from the evening of dynoing. Here are the best of each intake setup. We typically define "best" not as highest peak power/torque, but as which run has the most area under the curve. We feel that this typically depicts gains on more tangible level. Ultimately, it was very rewarding to see a clear depiction of the gains we felt both on the track and street. For all candid purposes, we weren't expecting to measure this much of a jump in power. Eventuri typically estimates slightly less gains. Whether it be our tough time controlling IAT on the factory system which skews results or if it's our much bigger header/exhaust system which raises the gain potential, we're not entirely sure! None the less, we do plan on revisiting the dyno for further testing to provide a greater sample size of data results. Stay tuned for another dyno test. This time, we will be on a 100% factory standard E46 M3 ECU to eliminate the CSL calibration as a variable. We will also be on a dyno that has full data log graphing capabilities. We'll see if we can still record a measurable and strong gain. |
