BPM
      11-12-2020, 10:20 PM   #1
maicol76
Schrick 292 + Akra Evo
I installed a Schrick 292 camshaft a few days ago, and the picture is the result of ECU tuning.
My Mods of engine and exhaust are
stock intake with K&N drop in filter.
Akra Evo
I uploaded the STD and SAE graphs together.
Since each shop shows different dyno measurements even for the same vehicle, so I also uploaded graphs that compares the data measured with other E92 M3 in the same shop.
The ECU mapping was done very conservatively. Because My M is trackday only car, it is set to focus on stability and durability rather than pulling out max power. So, A/F ratio and ignition timing are not aggressive.
With the aggressive setting, the STD got almost 420 hp, but I didn't want it.
(I have now ordered the Karbonius Intake. After installation, ECU will be mapped again.)
2011 LCI W/DCT / K&N drop in filter / CSF radiator / do88 oil cooler / do88 DCT cooler / Akra Evo / Moton CS 2 way coilover / Wiechers strut bar(F) / ARC strut bar(R) / Alcon Superkit BBK / Tarox rotor / Geoff steel EHPS / Sard carbon-Kevlar GT wing / GT4 carnard / Aim Evo4+G-dash+GT Steering+S/C GP HD / Bride Zeta3 / etc.
Appreciate 12
911r891.00
roastbeef11586.00
Not Sure212.50
SYT_Shadow11490.00
Samo6556130.50
Kelse921131.50
///Mobbin1478.00
DrFerry6728.50
      11-12-2020, 11:09 PM   #2
911r
911r's Avatar
891
Drives: slowly
Wow...jealous. How does the car feel with the cams? Any less "streetable" (weird idle, etc etc) And did you raise the rev limit at all?
      11-13-2020, 12:42 AM   #3
Redd
Wow. It makes a ton of power up top even without headers. Very interested to know if it loses any power below 3k.
How does the car sound with the 292s?
      11-13-2020, 02:45 AM   #4
tdott
Drives: M3
How was the cams install? Did you limit vanos or change the valve springs?
      11-13-2020, 02:49 AM   #5
maicol76
Idle and rev limits are stock. 780 & 8400.
My stock idle rpm was always 780-800 without modification when I installed the AKra Evo. (I don't know why, but always 780)
The engine is a little rough during cold start, but it's not severe, and it gets better as soon as the temperature rises slightly.
IMO, if idle rpm is set to around 800~830, it will be exactly the same as the stock even at cold start.
Of course, there is a slight drop in torque at less than 2500rpm in the data. But if I don't have full throttle, I can't feel the difference with stock.
Since I rarely drive on public roads, and rarely step on the accelerator hard or speed up a lot because my car is track only car, I didn't feel any difference in test driving on public roads in my driving style.
911r891.00
      11-13-2020, 04:37 AM   #6
maicol76
No VANOS limit...still stock
Valve springs, retainers and keys were replaced with schrick's parts as recommended by Schrick.
      11-13-2020, 04:51 AM   #7
Redd
What's the diff between the blue and green lines?
      11-13-2020, 05:12 AM   #8
amrazM
mTekMods
amrazM's Avatar
Drives: like a granny.
Does it idle any differently? I have a set of these waiting to go in.
G-Power Supercharged
      11-13-2020, 06:07 AM   #9
pbonsalb
Is it on 91 or 93? Thanks for the dyno testing!
      11-13-2020, 06:11 AM   #10
Gossypiboma
Drives: 13' M3 6MT 18' M3 CS
Would love to see what the car would do with a catless xpipe.
DrFerry6728.50
      11-13-2020, 06:54 AM   #11
statik
Drives: 2010 M3, 2017 RS3, 2013 BRZ
awesome results, who tuned the car?
Eric@NRP174.00
      11-13-2020, 07:34 AM   #12
Gossypiboma
Whats the labor cost for cam installation?
      11-13-2020, 11:40 AM   #13
exVtekGuy
Drives: none yet
could you explain what mods for each of the dyno runs?
      11-13-2020, 11:54 AM   #14
SYT_Shadow
///M Powered for Life
SYT_Shadow's Avatar
11490
It's nothing strange. OG already had similar results, although tuning is not complete IIRC.
I've been saying it for years already, 292 cams are the real deal. If you get the Schrick setup you don't need to limit vanos or do any other weird crap, it's plug and play.
With BW LT headers and Karbonius I'm sure we'll end up getting 420-430whp out of a 4.0L with 93 octane fuel
To put these numbers into context, my completely stock F80 CS gets 435whp. It's a great result for the S65
Looking at the curves: blue is stock, green is FBO Stage2 and red is 292 cams. Note that OP needs a better xpipe (Bimmerworld or ESS forward placed Xs) to have the torque curve stay constant until 6k rpm, but overall you see the important things: stock cams stop creating power after 7500rpm, 292s allow power to continue increasing.
People keep asking about raising the rev limit: you shouldn't go beyond 8500rpm if you have hydraulic lifters.
Appreciate 7
911r891.00
//steve\\1074.00
statik63.00
6ixSpd6015.50
      11-13-2020, 05:36 PM   #15
Lienrocs
Lienrocs's Avatar
703
Drives: E92 M3, M4 GTS, HP4
Oh yes. This is what we all want to see. What was the labor like to install them?
      11-13-2020, 05:56 PM   #16
SYT_Shadow
SYT_Shadow's Avatar
11490
I haven't seen anyone do it inside the car, so it's an engine out job.
      11-13-2020, 05:59 PM   #17
Lienrocs
Lienrocs's Avatar
703
Well if I'm pulling the engine then the rods, pistons and crank are going to become a lamp/table combo and be replaced. What's the limiting factor of doing them in the car?
911r891.00
      11-13-2020, 06:03 PM   #18
SYT_Shadow
SYT_Shadow's Avatar
11490
I would never allow someone to touch the insides of the engine. No one is replacing rods/cranks/pistons on my S65s.
But anyway, it's very different to pull an engine, remove the valve covers and do cams than to crack the block open. And one of the two solutions is not going to blow up later.
It may be possible to do the job while it's in the car but you'd be working in a very tight space.
      11-13-2020, 06:07 PM   #19
Lienrocs
Lienrocs's Avatar
703
Don't you have a stroker S65? Or did it blow up?
Gotcha. Limited space would be a pain for sure but if they're all bolt in parts that don't require limiting vanos or checking piston to valve clearance then I suppose it would be doable in the car, just a massive pain. Just thinking out loud.
      11-13-2020, 06:58 PM   #20
Redd
I really got to stop reading M3post. It's bad for my bnak account. I really want those Schrick 292s now.
Kelse921131.50
swanlake180.00
Ajolives922.00
      11-13-2020, 07:39 PM   #21
maicol76
91
      11-13-2020, 07:42 PM   #22
SYT_Shadow
SYT_Shadow's Avatar
11490
I have a stroker S65, that's where the experience comes from
My street E92 may get 292s but never internal work
