BPM
      04-25-2016, 09:37 PM   #1
SaNGRia
SaNGRia's Avatar
985
Drives: LCI E93 M3 + F85 X5M
DIY : E93 M3 Frayed Cord Replacement
TENSION ROPE, INTERN
Manufacture Part No : 54377277475 (You can not find the part number anywhere what so ever! I even looked at a video on youtube, the guy had the part but did not write the part number on description area)
Link for the part : https://www.ecstuning.com/ES2080486/ (ECSTuning employee could not find the part either)
You will need a Small bungee cord to keep the flexible part tighter in order to remove the string without damaging.
There is 2 screw you need to remove in order to re install the new string!
After using the bungee cord as you see in the second picture, you can cut the old string and just get it out from your way! If you cant memorize what way to re install the new one, just walk other side and see what it looks like originally or take a picture if you are lazy
This is how frayed cord looks like!
Metal spring covered with plastic, you should slide down in order to install the new one! If you have right tool you can also remove the bottom screw to make it easier! I didn't have right tool to remove the bottom one it is so tight to work there!
This is one of the screw you need to remove and make sure you put the string right position, I had to remove and re do again! And the whole behing this metal part is narrow so it can damage to the new cord. Be Careful!
After oulling the new string all the way to the end, I found it is easy to re attach the metal piece when you are sliding the old one out.
But the tricky part is the old one will not get removed at the first circle so I cut it to make it faster!
And make sure both side holds the cord with same tension and same angle!
I got 2 other product to maintain the roof package (seals, rubber, trim parts)
1- NextZett Rubber Protection Gu (Made in Germany)
The best price : http://www.autopia-carcare.com/1z-91...l#.Vx7axo-cE2w
2- Krytox GPL205 :
The best price tag : http://www.ebay.com/itm/271163422328...%3AMEBIDX%3AIT
E93 M3 6MT , Nav, Prem, Cold Weather, Sports package, & CA, RGBW DTM with RGB Demons + Eisenmann Race + BE + ARP + Brembo GT 380s, $3AG, $5AC, $508, $6NF, $601
Please "Appreciate" If you like my post!
DIYs : OEM Camera Retrofit, FLA Retrofit , Drive Shaft Ticking , Starting Issue,
, F85 ACC Retrofit
SYT_Shadow11479.50
CTMike262.00
victo6.00
      08-25-2018, 11:58 AM   #2
yeahM3
finally, a BMW
yeahM3's Avatar
Great thread! Just replaced mine!
SaNGRia984.50
      08-25-2018, 12:16 PM   #3
SaNGRia
SaNGRia's Avatar
985
Glad to help you out. Enjoy
, F85 ACC Retrofit
Dpc2u11503.00
      01-06-2021, 08:14 AM   #4
LakeSurfer
Drives: bicycle
Do not hesitate to replace these cords early.
I didn't think about replacing them until it was to late. My passenger side cord snapped without me realizing it. The plastic piece on the pillar that the cord connects to is spring hinged and the cord keeps it where it needs to be. I was cleaning the interior with the top down and noticed a 3 inch gash on the side interior panel by the rear head rest. this is caused by the plastic piece scrapping on it when the cord is broken and the top is operated. I'm shocked i didn't notice. a $20 cord will not cost me the price of a panel.
-Mark
victo6.00
      01-06-2021, 05:32 PM   #5
SaNGRia
SaNGRia's Avatar
985
Good point!
-Mark
, F85 ACC Retrofit
victo6.00
      01-08-2021, 03:29 PM   #6
BimmerRookie
BimmerRookie's Avatar
Drives: E93 Cavalier Z24 M3
-Mark
This EXACT thing happened to me as well. Any thoughts on repairing it? Or is getting a new panel our only option?
      01-09-2021, 02:59 PM   #7
LakeSurfer
Drives: bicycle
-Mark
I picked up some kind of 2 part repair stuff that i haven't used yet. I probably won't even try it. I'm not sure why I even got the stuff. I think it's safe to say that you'll never really be able to repair it to undetectable standards. I'm just gonna look for a new used panel. My only issue is that I have individual sound system or whatever it's called so I think the speaker configuration is different or it just has different trim pieces around the speakers. I'm sure it would be easy to use any black panel and fit the speaker trim into it.
      01-13-2022, 05:40 PM   #8
siriusmello
Drives: bmw e93
bmw e93 tension cord snapped
Hi everyone, my tension cord has snapped so i have to replace it now but is it possible to do so with the roof closed? because the roof isnt operating but i can hear the motors working. Any info or tips would be greatly appreciated
      01-13-2022, 06:26 PM   #9
SaNGRia
SaNGRia's Avatar
985
You can manually open and close the top. Then you can fix the cord!
, F85 ACC Retrofit
      01-14-2022, 09:34 AM   #10
siriusmello
Drives: bmw e93
Thank you for giving me hope! i cant seem to find how to manually work the move the roof do you have any information regarding that? Thanks
      01-14-2022, 06:13 PM   #11
SaNGRia
SaNGRia's Avatar
985
No problem. Here is the video for you :
, F85 ACC Retrofit
      09-04-2023, 10:28 PM   #12
guig
Drives: BMW M3
Very helpful post, thanks.
I unfortunately dropped the tiny lower silver bracket into the depths of the trunk while I was replacing the second cord. Does anyone know the part number for it or where to find one?
Thanks,
Steve
