01-19-2018, 01:42 PM | #1 |
Rep 875
subframe bushing insert
Just saw these from ECS. Wondering if any one tried them and what are the opinions/thoughts on these compare to solid bushing/aluminum replacements?
https://www.ecstuning.com/News/BMW_E...018_EP_25647_B These looks to be easier to installer than solid bushings. Thanks in advance. |
01-19-2018, 01:56 PM | #2 |
Rep 10,614
Someone should try them to see if an improvement can be felt. Just lower the subframe a little and slip them in. Might not even need to disconnect those two short brake lines. And about 2/3 the price of new bushings. I would still want to stiffen the diff mounting since that is a more common failure point.
01-19-2018, 05:32 PM | #3 |
Rep 1,326
Interesting that 034 (big in Audi/VW) is developing BMW parts. Anyways, subbed for feedback on these.
2014 Frozen Black F10 M5 | Agency Power HFC Downpipes | Custom Open Flash Stage 2 Tune | KW HAS kit | 3D Design Lip | 3D Design Skirts | 3D Design Spoiler | IND Front & Rear Reflectors | IND M5 Badge | M Performance Steering Wheel | M Performance CF Shift Knob | Pedal Haus Pedals & Paddles | Turner Exhaust |
01-19-2018, 05:35 PM | #4 |
Rep 11,667
You still have to drop the subframe to install these.
IMO, if you're in that far, do the job the right way.
'21 M2C Hockenheim Silver
'18 718 Cayman S Lava Orange (sold) '13 E92 M3 Santorini Blue (sold) '07 Z4 M Coupe Alpine White (sold) |
01-19-2018, 07:00 PM | #5 |
Rep 4,163
Agree. If you're already dropping the subframe just do solid bushings. Zero downsides so solid bushings.
bigjae19761569.50 |
01-19-2018, 07:21 PM | #6 |
Rep 10,614
You don’t have to drop the subframe. You can lower it a few inches. Use M12x1.5 threaded rod and M12x1.5 nuts. Buy a meter and cut it in 3 or 4 pieces each several inches longer than the subframe bolts. Replace 3 bolts with the threaded rod and let the subframe hang down a few inches.
You can change bushings this way also but you need rod sections long enough to let the subframe hang down about 5 inches. The 2 short brake lines only gave a few inches play so you have to disconnect if you want to lower enough to change bushings. For the calipers you can just unbolt the line brackets to add play. Obviously some wiring has to get disconnected as well. |
01-19-2018, 09:53 PM | #7 | |
Rep 11,667
01-20-2018, 07:30 AM | #8 |
Rep 10,614
It’s not a lot of work compared to actually removing the subframe.
I was asked to test drive a modded 135i last year because the rear end was unsettled. I could totally feel it as I transitioned on and off power. The owner was thinking about using stiffer M3 bushings. I suggested he go to poly or solid. Instead he bought inserts. I have not driven the car since but the owner said the rear end is much more settled. I think someone should try these and report on how easy they are to install and what difference is noticed if any. You should realign after lowering the subframe since toe settings could change slightly. Last edited by pbonsalb; 01-20-2018 at 09:35 AM.. |
01-20-2018, 09:04 AM | #9 |
Rep 12,726
thats the stupidest shit i've ever seen. if you have to drop the subframe and press-in new bushings anyways, why not upgrade to zero downside solid bushings?
01-20-2018, 09:50 AM | #11 |
Rep 12,726
well whats stopping you broski?
01-20-2018, 09:56 AM | #12 |
Rep 10,614
I already changed my subframe and diff bushings to poly. It was a big job even though I just lowered the subframe instead of removing info it. In contrast, just adding these inserts and lowering only a couple of inches would be easy. I think someone should try them — similar inserts made a noticeable difference on a 135i that someone I know has. For $170 and a few hours, it’s in a completely different category of price and labor than a stock or solid or poly bushing job.
01-20-2018, 12:32 PM | #13 |
Rep 11,667
If you read the instructions, they recommend installing with new bushings.
These aren't intended to save old bushings from being replaced. With the age of our cars and mileage on most..... There probably aren't many out there with bushings in decent shape anyway.
01-20-2018, 03:50 PM | #14 |
Rep 10,614
I disagree. Subframe bushings last a long time. People aren’t going poly or solid because the original
ones are worn out. They are doing it to improve handling. |
02-16-2018, 11:03 AM | #17 |
Rep 10,614
The hard part is getting the stock rubber out. It’s easy if you have the right tools and harder if you don’t and the limited space you have when just slightly lowering the subframe makes it even harder if you don’t have the right tools. The right tools are a receiver and a driver and a threaded rod and washers and nuts connecting the two, but obviously they have to fit. Installing poly is easy — no tools are required.
Special tool http://www.hpashop.com/Bushing-Tool-...g-tool-kit.htm https://www.amazon.com/Rear-Suspensi.../dp/B00VONCS3O You can cobble something together on your own if you are creative. Last edited by pbonsalb; 02-16-2018 at 11:16 AM.. |
05-15-2018, 01:56 PM | #18 |
Rep 2,824
034 bushing/mount inserts are very popular in the VW/Audi world.
If these are simpler to install, it could be a great upgrade for lower-mileage street cars. For example, I'd like solid bushings but cannot justify the labor expense until more hardware needs to be replaced "while in there." If high miles (worn OE bushings) or if install is nearly the same, then these don't seem to have much advantage ... Very curious to hear about the install ... Anybody try these yet? *While ECS says the subframe needs to be dropped, inserts are a common mod for non-M subframes and those guys say inserts are a lot easier than a bushing swap. I would imagine that is equally true for an M, just "news" to us because inserts are new/not common for the M cars. Last edited by wyatth; 05-15-2018 at 07:01 PM.. |
05-15-2018, 04:24 PM | #19 | |
Rep 1,881
seems this is same tool on amazon for half the price of the one posted. |
05-16-2018, 11:31 AM | #21 |
Rep 2,824
I just want to know if the install is significantly easier than a full bushing swap. If so, I would do this to a non-track, low-mile car for sure. If comparable labor, then zero point to this.
05-16-2018, 12:54 PM | #22 |
Rep 10,614
Way easier to not press in and out bushings. Makes the most sense if not dropping SF but just lowering a bit. Might not even need to lower but I’d have to see the inserts and how they go in. The front bushings goin from the top on the M3 unlike on the regular E90.
