02-20-2020, 10:46 PM | #1 |
Rep 198
Drives: 2011 e90 ZCP
DCT Stuck in Neutral, Clicking Repeatedly
This one is a bit baffling. At the end of my drive home tonight I shifted the car into reverse, heard and felt a clunk, and the DCT shifted itself into neutral. The "secure vehicle against rolling" warning displayed. Shifting into reverse or drive did nothing - the transmission remained in neutral. And there was a loud repetitive clicking coming from under the gear selector - a loud plasticky click every 1.5-2 seconds that didn't stop until I turned the car off. I turned the car off and back on a few times, same result.
Went inside to do some googling and came up with nothing, so I went back out to get some video of it. Shifted into drive and reverse no problem that time. Drove fine. No clunking or clicking. On one hand I'm relieved, on the other hand it was pretty disconcerting and I don't want to get stranded somewhere in neutral. Any ideas? |
02-20-2020, 11:04 PM | #2 | |
Rep 780
02-20-2020, 11:39 PM | #3 |
I got lei'd
844
Rep 7,593
it's the start of your alternator/battery dying or aged, time to replace, I've had it twice within 2 years because I would change the battery twice, but not the alternator
02-21-2020, 04:56 PM | #5 |
Rep 198
Interesting. I would think it would show up first with a reluctant start. The car starts up no problem. It just didn't want to shift out of neutral. So did you have this same problem with the clicking and everything?
02-21-2020, 05:00 PM | #6 | |
Rep 198
I've been pretty on top of that, changing it every 30k miles. Last time was a year ago. Might not hurt to get the level checked though. |
02-21-2020, 05:45 PM | #8 |
Rep 198
02-21-2020, 06:19 PM | #9 |
Rep 780
Correct. Most generic scanners will only ready dme/ecu codes. You'll want a reader that scans all modules. If you know anyone with bmw Carly those are great for scans. Android Protools is already good. Kdcan with ISTA is great.
02-22-2020, 12:08 AM | #10 |
Rep 754
Drives: 09 //M3 e90 Interlagos Blue
My DCT failed at 160k miles and it cost $15k new installed at the BMW dealer.
Recommend you visit AutoTalent in Gardena, CA. They will check your alternator/battery and replace either if bad. Valeo 180A OE alternator is only $400ish. That might do the trick. Low voltage could cause engine limp mode and DCT problems. A bad fuel pump might also cause the DCT to go into N, but your engine would stall too, if that were the issue. If you need a new DCT, AutoTalent might order a used low mileage DCT from deansbimmer in Texas (Mporium). He is a valued m3post member. Rent a car at a nearby Enterprise in Torrance. They are near the Porsche Experience Center in Carson too make the trip worth it. WoW, new DCT Fluid every 30k miles. So much for lifetime fluid. There is a plastic pump ($80) in the DCT that can be replaced with a fluid change. Wonder if that is the issue. A larger metal pump ($800) is in front behind the wet clutch ($2k-3k). Also look for leaks at the mechatronics unit or the round o-ring above that where the harness enters the DCT. If your mileage is above 150k, then a replacement DCT is the safest option. If your battery/alternator is more than 7-8 years old, replacing them is probably the simplest solution. Good Luck, Cheers |
02-22-2020, 04:46 AM | #11 | |
I got lei'd
844
Rep 7,593
On top of the reluctant start...mine started up normal. I tried getting another mile or so to get to a safe curb and it went to N and clicking again. Even once I pulled over and wanted to drive a bit more, started up fine but again N and cliclicliclicliclic |
02-22-2020, 08:28 AM | #13 |
Rep 4,160
How old is your battery/alternator? When my alt died and the batt didn't charge I got stranded on the roadside and gearbox errors were among the lights I got.
