01-01-2009, 02:49 PM | #1 |
Rep 516
What is this? Shoulder related
Look at the picture, you will notice the middle finger of the hand poking the part of the shoulder that has been hurting. I have looked up shoulder charts but they are all way too detailed and I can't tell what is what.
01-01-2009, 03:12 PM | #2 |
Rep 1,414
Drives: 2008 BMW 550i
Backne?
01-01-2009, 03:29 PM | #6 |
The Boss
110
Rep 4,948
Drives: %E2%80%9816 F15 X6
That is true. What is your age? Typically in younger people, it is more of a labral issue that a cuff issue. That does mean it is not a cuff however. What other symptoms are you having? Catching, clicks, night pain, pain with over head activities. How did this injury occur, exactly how. Do you weight train a lot and if you do, heavy weights or light weights with more reps. Sorry for all the questions but hard to make a diagnosis with just location.
2016 F16 X6
2015 F15 X5- Retired 2013 F10 535xi- Retired 2011 E92 M3- Retired 2011 E90 335- Retired 2008 E92 335- Retired |
01-01-2009, 03:30 PM | #7 |
Rep 516
01-01-2009, 03:37 PM | #9 | |
Rep 12
01-01-2009, 03:39 PM | #10 | |
Rep 516
I have been doing elastic exercises every other day but that was because the pain where my fingers pointing went away so I had a random PT tell me 3 impingement workouts to do but I don't think that is solving the issue on this spot. |
01-01-2009, 03:39 PM | #11 | |
Rep 465
jk |
01-01-2009, 03:40 PM | #12 |
The Boss
110
Rep 4,948
Agreed. I was thinking along the lines of a posterior labral tear due to heavy weight training or a specific type of injury. Just guessing that the guy is younger in age.
2016 F16 X6
01-01-2009, 03:45 PM | #13 |
Rep 516
What would repairing this consist of? Arthroscopic? Or just PT? Costs? and recovery time? Once repaired is it like a bone where a healed one is stronger than the one that never broke? My career is on the line.
01-01-2009, 03:49 PM | #14 | |
Rep 12
When you say you fell how did you land or break your fall? |
01-01-2009, 03:58 PM | #15 |
The Boss
110
Rep 4,948
Good question! As far as the repair would be concerned. What would happen, at least what I would do. I would order and MR arthrogram. It is an MRI where they inject a dye into your shoulder. The reason for this is because, IMO, it sounds like a labral issue. The arthrogram is a better diagnostic test for looking at the labrum. If this comes back positive, a course of PT and anti-imflammatory medication would be tried for a while. If that did not work, arthroscopic evaluation would be needed. Once in there, they would be able to physcially look at the entire shoulder to see what is going on. If you needed a reapir, you would def be out for a while.
2016 F16 X6
01-01-2009, 04:02 PM | #16 |
The Boss
110
Rep 4,948
I think you should continue with the theraband therapy you are doing. DO NOT over do it. I would def back off the push ups as I feel they are contributing to some of your issues. Try an anti-inflammatory medication for a while. I like alleve a lot. Two in the am and two in the pm with some food or milk. You MUST take this everyday to get the anti-inflammatory effects. Try this for a month and see where you are at. Do you have an allergies to meds? Alleve is also known as naprosyn or naproxen sodium BTW
2016 F16 X6
01-01-2009, 09:57 PM | #18 | |
Rep 516
01-02-2009, 11:09 AM | #19 |
n00b
Rep 178
I had some issues with my Teres Minor (in that area), it was eventually diagnosed as some inflammation, probably from weightlifting, but the bottom line is that PT did absolutely nothing to alleviate the problems, but it DID help the orthopedist with his diagnosis. After the course of PT he was able press my shoulder joint backwards and the pain vanished 100%, whereas before it didn't do that.
One cortisone shot later I'm back in business, going on 5 years now.
His: 08 E92 335i (sold), 99 Corolla beater car
Hers: 09 Tiguan Previous: 09 e93 328i, 04 WRX, 07 S40, 03 E46 330xi, 04 F4i, 04 EX250 |
01-02-2009, 01:27 PM | #20 |
Rep 1,668
Can`t tell without testing.................the location you are pointing yor finger is the m. Infra Spinatus
Taking NSAID for a month is far too long, it may cause stomach pain..........talking off; Ibuprofen, Diclofenac, Naproxen ( Don`t know if these are common names all over the world) Labrum tear is possible with a trauma, like falling on a stretched arm. For Gleno Humeral instability; Use the Apprehension/Relocation test Labrum leasion; Jerk / Kim test ( Dorso-caudal Labrum) Last edited by Romo; 01-02-2009 at 01:44 PM.. |
01-02-2009, 05:48 PM | #21 |
The Boss
110
Rep 4,948
Why do you think taking an NSAID for a month is too long? As long as you do not take them for years it would be fine. Celebrex is an NSAID and although it is a cox-2, it is still metabolized in the liver extensively. Both celebrex and naproxen are metabolized by CYP450. Both inhibit cyclooxygenase correct? Patients are on celebrex for years. NSAID's can cause damage if taken for a long period of time, I totally agree. However, I don't think taking them for a month if going to do that much damage. Just my .02 but what do I know?
Subacromial bursitis is also a possibility. But I would think you would have more pain with overhead activities. Theraband exercises would consist of internal and external rotation along with flexion. Performing a set of 10, once a day is usually enough. Even though i do not believe it is a rotator cuff injury, strengthening these muscles is always a good idea since they provide stability to the glenohumeral (shoulder) joint. What color is the theraband? The color determines the strength. I would have to agree that a cortisone injection is an option. The purpose of this injection is to apply direct relief to the shoulder. This would help two fold. First, it could allow immediate relief of the pain. It would also help the orthopod in the diagnosis of your injury. Second, it would buy you some time to perform these exercises. Hope this helps. Best advice? Go to an orthopedic surgeon and have him or her examine your shoulder. I would not go to your internist, no offense to you guys.
2016 F16 X6
01-02-2009, 07:20 PM | #22 |
Rep 572
Teres minor or maybe posterior deltoid.
Dude, you really need to get that MRI. I second the idea of doing it with intra-articular (not IV) contrast. With contrast in the joint, MRI can look at the cuff, the labrum, the bursa and the bone. |
