01-08-2020, 03:27 PM | #1 |
Rep 52
Car doesn’t have electrical power, HELP
For a few days, the car would at times not unlock the door, and when i would do it manually with the key in the door, it would not have power locks etc, not turn anything on when i put the key in the ignition.
I was reading elsewhere that it may be the receiver for the FOB, wanted some insight from you guys before i ordered the part. Upon inspection, i noticed the battery area had flooded and submerged the battery halfway in water. I uninstalled the battery, drained the water and cleaned any rust buildup, the power lead to the starter had rusted and i cleaned and reinstalled it. I then checked all the fuses on top of the battery and all had continuity. Anything else i should check or is it most likely the IBS or is it the CAS? I let the battery charge while it was out and it held a full 13.5V, i then checked continuity from the engine bay power leads (where you connect a trickle charger) and there was consistent voltage across to the battery without any drop. |
01-09-2020, 06:11 AM | #2 | |
Rep 7,053
Good luck! |
01-09-2020, 07:16 PM | #3 | |
Rep 52
01-13-2020, 10:29 AM | #5 |
Rep 5,476
Get a new battery? - if it was doing the weak unlock thing for a few days, the battery could have been on its way out anyway.
Are you saying it just doesn't have any power anywhere? If so it sounds like you need to dig into/behind the dash fuse box etc. If the water corroded the positive lead there's a chance you had a dead short iirc continuity to the large engine bay jump start post is a separate circuit This sounds a lot like the B+ connection issue this guy had https://www.bimmerfest.com/forums/sh...=661556&page=2
01-14-2020, 02:23 AM | #6 | |
Rep 52
