01-02-2020, 07:01 PM | #1 |
Rep 25
E92 M3 Wheel Fitment Help
Hey lads!
I'm by far no means a wheel expert and have done some extensive research on shopping for after market rims for my 09' E92 M3. I'm after a semi aggressive look that fills out the fenders with no spaces, zero rubbing and no impact on handling. Down the track i might drop the car on KW HAS lowering springs. I've decided to purchase Work Meister M13P rims for the car because i love the old school BBS look to them. https://www.jdmconcept.com.au/part/work/meister-m13p I've come up with the below set up: 19x9.5 ET22 & 19x10.5 ET22 265/35/19 & 285/35/19 Is this a good set up for someone wanting a OEM+ look with no spaces, zero rubbing and no impact on handling? Last edited by S65_Screamer; 01-02-2020 at 07:19 PM.. |
01-02-2020, 08:32 PM | #2 | |
Rep 6,285
01-02-2020, 11:47 PM | #4 |
Rep 46
Just checking but you can order PCD 5x120? Just didn't see the option on the page you posted?
Beautiful wheels btw.
Jerez Black BMW M3 E92 MY11 ZCP
01-03-2020, 12:51 AM | #5 | ||
Rep 25
I can't wait to slap them on! ***EDIT*** So the supplier has come back to me with the following specs. Since the wheel is a 3-piece construction, they can only produce the wheels in the following configurations - thoughts? Front 19x9.5 +19 A disk (71mm dish) 19x9.5 +32 A disk (58mm dish) Rear 19x10.5 +19 A disk (83mm dish) 19x10.5 +30 O disk (83mm dish) 19x10.5 +17 O disk (96mm dish) |
01-31-2020, 11:29 AM | #6 |
Rep 79
Hi, Can't help you with what rubs or not. For example ET22 vs. ET30 is 8mm different, so please be careful to check, or find someone else that has had exactly that measurement before.
I find this calculator very useful, it shows clearances around a specific wheel and rim when you change from one to the other: https://www.wheel-size.com/calc/ |
01-31-2020, 11:40 AM | #7 |
Rep 1,263
You need 265 and 285 30 profile tires. NOT 35 profile.
You will rub because the 35 profile in 265 and 285 is too large in diameter for the wheel well, not talking about fender clearance. |
01-31-2020, 12:51 PM | #8 |
Rep 3,972
I wouldn't put those balloon tires on the car.
try willtheyfit.com and keep the overall tire diameter within 3% of stock
02-06-2020, 04:31 AM | #9 |
Rep 6,285
Do you wish to run any neg camber, I'd be keen to run the more agressive setups on the list
Front 19x9.5 +19 A disk (71mm dish) Rear 19x10.5 +17 O disk (96mm dish) |
06-13-2020, 04:04 AM | #10 |
Rep 170
You might find this site useful: https://tiresize.com/
