05-02-2019, 01:12 PM | #1 |
Rep 23
Paint Correction Strategy - Please Help
I'm going take a shot at performing a paint correction on my Jerez Black 2008 M3. It has some water marks, swirls, and what looks like faded paint (not sure what this is) - I took pictures of the worst areas. I was wondering if anyone experienced has any advice on how to approach the paint correction. I was thinking Menzerna Heavy Compound 400 on an orange pad followed by SF3500 on a black pad. I'm working with a PC7424XP and have orange, white, black, and red pads and the Menzerna polished mentioned. I've never done this before and am going to have a practice run with my ZHP first as I'm prepping to sell it to some lucky person. Any advice is much appreciated.
05-02-2019, 01:43 PM | #2 |
Rep 261
This is my process...
Wash - 2 bucket system...Chemical Guys Mr Pink soap with Torq Foam Cannon Wheels - Chemical Guys Diablo Wheel gel with Chemical Guys Wheel Whoolies Using the Griot's Garage 6" orbital for below... Paint decontaminate - Nanoskin Autoscrub Fine Grade with Nanoskin Glide and Nanoskin Fine grade sponge in tight areas Compound - Meguiars M105 with Chemical Guys Hex Logic Orange pad Polish - Meguiars M205 with Chemical Guys Hex Logic White pad Glaze - Chemical Guys EZ Crème Glaze with Chemical Guys Hex Logic Blue Pad Paint Sealant - Jescar (Mezerna) Power Lock Plus Polymer Sealant with Chemical Guys Black Pad Wax - Chemical Guys Butter wax with Chemical Guys Red pad Quick detail - Chemical Guys Hybrid V7 Optical High Gloss Spray Sealant/Quick Detailer |
05-03-2019, 07:03 AM | #3 | |
Rep 23
Does this seem like a good approach? |
05-03-2019, 07:59 AM | #4 |
Rep 261
I'm not convinced the glaze is worth the effort. It prob helps a little. It adds some depth..like you can see into the paint.
You may not need your step 2. Hard to say until you get there and see what step 1 did. |
05-03-2019, 02:51 PM | #5 |
Rep 942
If you're new to the correcting game, I would highly suggest watching [literally] hours of YouTube how-to vids. Try AMMO NYC, Pan the Organizer, Dallas Paint Correction, Obsessed Garage, etc...
Remember that paint correction is detrimental to your paint/clear. You don't get to do it infinite number of times. Start with less aggressive, like a cut polish, and then work your way up to more aggressive, like a super cut compound - but only if the paint needs it. If your paint is swirled and neglected, you're likely going to see a dramatic improvement with just a medium polish and a cutting disc. Something like CG V36 or like Sonax Perfect Finish, etc and a CG Orange hex pad. You can start here and might notice a big difference. (Do a small test spot (2' x 2') on a rear fender or something first.) Then a coat of wax or sealant and your car will likely be night and day better. If you can tell from your test spot that just polish isn't enough, you can move up to a more aggressive compound. Then polish after you compound. You likely won't see much added benefit from a glaze at this point. Regardless, glad you're giving the paint some TLC! P.S. Obsessed Garage just did a multi part series on paint correcting an e92: |
tdott3941.00 |
05-03-2019, 03:34 PM | #6 |
Rep 3,986
Yup, research research research if you wanna do it right. Oh an you probably have to spend a couple of hundred on a good machine that old PC wont remove those heavy scratches, pads, compund/polish, etc.
05-03-2019, 03:52 PM | #7 |
Rep 942
I didn't mention above, although it's already been said here.
DO NOT SKIMP in the prep before you correct your paint Thoroughly wash the car with a soap that will strip waxes or any type of protection that might be in there. Something like Adam's Strip Wash or CG Clean Slate for this instead of Mr. Pink. Then you can chemically decontamination the car with something like Iron X - do your homework here! Use a clay bar method (or nanoskin as mentioned above) to physically decontaminate. Use an IPA wipedown to make sure there are no residues, etc. on the surface before you correct. Also, tape off any areas like trim, glass, etc. that you're not correcting/polishing. You don't want polish getting stuck in all the crevices or you'll have some noticeable white stuff between all your panels - dead giveaway of a cheap/lazy/novice detail. Don't skimp on the protection once you're done. A good wax or sealant, or layer both! |
05-05-2019, 05:38 AM | #8 |
Rep 23
Thanks for the guidance. I have been researching for the past few months but watched the Obsessed Garage series again and pick up on new things every time I watch it. I think I have everything I need in terms of products. Any suggestions on how to clean up the shadowline trim without a small machine? By hand?
I'll do as you suggested and start with the less aggressive polish first. I know it's a lot of experimentation, so I'll jump into it when I have a couple of days to devote. Last edited by BimmerSixDeuce; 05-05-2019 at 05:59 AM.. |
05-05-2019, 08:17 AM | #9 | |
Rep 527
The 7424xp is a pretty forgiving machine as are DAs in general. They don't tend to burn as quick or easy as a rotary. As others have stated just start with your least abrasive pad and least abrasive polish until you get a solid feel for the following: 1. Determining when the polish flashes so you know when to stop polishing. Others may call this "breaking down" but this is the point at which the polish is no longer effective and you will start doing more harm than good with mostly just your pad introducing more scratches on the surface that you were just trying to correct 2. The right pad/polish combo for the car you're working on and the goal you're trying to accomplish I always preferred multiple passes with the least aggressive (fine polish like Menzerna PO106 on a green pad) combo over a single pass with a more aggressive combo before I was able to meter the paint (I assume you likely won't have one). Every paint job is different and even different panels and substrates on the same car react differently to the polishing action. If 2-3 passes of that didn't clean it up I might consider going to something like Megs M105 on an orange pad for the first pass and then clean it up with PO106 on a green pad. In short there is no one right way to do things. Everyone develops a slightly personalized way of doing this. You just have to experiment and find what works for you, the car you're working on, and the result you're trying to achieve. I self-taught over a couple of years and decided to open my own side business for extra money. Before I knew it I didn't have to work my regular day job anymore and I was hiring/training employees to help me keep up with demand. Good luck to you and have fun learning! |
05-13-2019, 08:39 PM | #10 |
Rep 416
I’ve had great results with m105 on a surbuf microfiber pad using a porter cable 7424. Finish with m205 on a white lake country CCS pad.
Surbuf with a pc7424 gets rotary like results without the risk. |
05-31-2019, 02:52 PM | #11 |
Rep 1,256
Like others have said do some research. FG400 is my favorite polish/compound. It's excellent with a LC white pad if you're doing a one step.
Stay away from Chemical Guys products unless its their car soap. PERIOD. It's all junk. You also don't need anything more than a 7424XP. The big expensive machines don't do anything better other than cut down on time. I have a 7424, Flex 3401, Rupes LHR15 and LHR75 so I'm not bullshitting here. The 7424xp takes out 1500 grit sanding marks, its more than capable.
05-31-2019, 05:09 PM | #12 |
Stop the hate, get a V8
3850
Rep 8,625
I'll take the bait. Please explain.
Past: 2011.5 M3 sedan ZCP |
05-31-2019, 05:50 PM | #13 |
Rep 1,256
I promise I'm not trying to bait haha.
Years ago when I first got into the higher end of detailing, I learned a lot from Chemical Guys youtube videos and of course fell into their excellent marketing and purchased Chemical Guys everything. Only to learn over time that majority of their products aren't any good. There is a reason you'll never find a professional using their products. I should be clear I'm speaking about their chemicals. We are talking about a brand that sells "wax for white cars" and an $850 paste wax which requires an allen key to open. Its all non sense. Their wheel cleaners don't work. Diablo Wheel Gel is just car wash soap. I've wasted a lot of money of their stuff and don't want anyone else to go down that road. Hyper V7 Spray sealant doesn't do what they claim, Jetseal paint sealant doesn't last over a week, I could go on and on. I do like their car shampoos though! Best bang for the buck in my opinion. But save yourself the time and frustration and buy more professional products that work. I don't do this full time, but I do make a living off it. If anyone cares, my personal favourites are: Polishes/Compounds: Menzerna FG400, Jescar Correcting Compound, Sonax Perfect Finish Wheel Cleaner: Nextzett, Sonax Wax: Collinite 845 Coating: Cquartz UK Tire Dressing: Optimum Opti-Bond Tire Gel Sealant: cclinard1 had a great recommendation of Jescar Powerlock Soap: Chemical Guys Mr Pink Decontamination: Nanoskin Mitt, CarPro Iron-X Masking Tape: Rinrei Tape Prep Wipe: CarPro Eraser APC: Meguiars All Purpose Cleaner Engine Bay Dressing: Meguiars Hyper Dressing
05-31-2019, 06:14 PM | #14 | |
Rep 942
I completely agree with you. CG's marketing is out of control at times and it's painfully obvious they're trying to capitalize on every single dollar they can. There are definitely better products and manufacturers out there to find all your detailing needs. CG should not be used as a one stop shop at all. That being said, if you can cut through their flack, they have some decent stuff - again granted their marketing is obnoxious and there are comparable/better variants out there CG's soaps are pretty good: Clean Slate, Glossworkz, Mr. Pink I've used the V36 one step polish and it's honestly not bad. I'd also add that Jetseal is a very easy to use and decently durable sealant. As an experiment, I put one coat on my wife's car's that she daily's, never topped it with anything and didn't add wax during maintenance washes, and the water beaded nicely for about 5 months before the sealant began to fail. For beginners, it's good to power through some learning curves and figure out works best while not spending too much $$. |
05-31-2019, 06:25 PM | #15 | |
Rep 527
I like CG Honeydew and Mr. Pink but that's about it. Polishes/Compounds: Menzerna FG400, Menzerna MC2500, Menzerna Power Lock, Meguiars M105 Wheel Cleaner: Adams Intensive or Sonax Full Effect, whichever is cheaper at the time Wax/LSP: Collinite 845 + Blackfire Wet Diamond Coating: Cquartz UK 3.0 Tire Dressing: Adams Super VRT Soap: Chemical Guys Honeydew, Adams Car Wash Decontamination: Nanoskin Mitt, CarPro Iron-X Masking Tape: Rinrei Tape Prep Wipe: Homebrew IPA mix (IPA, DI water, and citrus APC) APC: P21S Total Auto Wash or Optimum Optiwash, whichever is cheaper at the time Engine Bay Dressing: Meguiars Hyper Dressing Detail Spray/Clay Lube: Adams Detail Spray Spray Sealant: Beadmaker |
06-04-2019, 12:37 PM | #16 |
Rep 23
I did a trial run on my ZHP that I'm about to sell. It's paint was in pretty good condition to begin with but after a one step with the sf3500 and a black pad it looks awesome. I also managed to get a long scratch (from a twig hanging into the road) out of the passenger door with the fg400 and an orange pad. Topped off with Jescar Power lock. The car looks so good now can't wait to tackle the M3!
06-23-2019, 01:04 PM | #19 |
Rep 527
That's certainly acceptable and a lot of people do it. Collinite 845 has a different look and feel than most sealants do - gloss depth is great. By layering it on top of a sealant you get the best of both worlds.
06-23-2019, 01:22 PM | #20 |
Rep 170
06-23-2019, 02:16 PM | #21 | |
Rep 942
Sometimes you'll get a hazy quality a few days after the Collinite application. That'll go away with your first maintenance wash. Then use a spray wax with each maintenance wash to keep those initial layers strong. |
06-27-2019, 07:48 PM | #22 |
Rep 9
I’ve always had good results with Griots products. The boss line of products are really easy to work with. They have correcting compounds and then I use the boss finishing sealant. This time I tried something different and used the Adams spray ceramic over the griots instead of the griots poly wax I normally do over the sealant. So far so good.
