      10-27-2018, 01:05 PM   #1
5speed5er
Drives: 2011 M3
Grinding/Shaking low rpms
Hi All,
I just bought a 2011 ZCP M3 6spd with 91k miles. I have put on about 800 miles since purchase.
Today when driving the car I started to get a grinding/shaking feeling while in low rpms in 1st/2nd gear. It is much more noticeable if I am turning the wheel.
Based on the feeling through the steering wheel it feels like the wheel is rubbing up against something but I looked and nothing is wrong. It also feels like it sort of bogs the car down.
The car undoubtedly needs new engine mounts along with trans, diff, and brake fluid. All of which I will be having done in the next month or so when I change the rod bearings.
Does anyone have any idea what this could be?
      10-27-2018, 02:51 PM   #2
bvrider1
Drives: e90 m3
what kind of wheels are you running?
      10-27-2018, 02:55 PM   #3
Mvy
Drives: 2008 E93 M3
The much more noticeable when turning the wheel leads me to believe it power steering pump related.
Harrop Supercharger, BPM Tune, K/W Coil over kit, Stoptek BBK, Magnaflow exhaust, ear to ear grin everytime I drive...
      10-27-2018, 03:04 PM   #4
5speed5er
Drives: 2011 M3
Stock ZCP wheels. There isn't anything physically rubbing, that is just what the sensation feels like.
It has been totally fine until I drove around downtown for roughly 30 mins today.
There is definitely a shaking sensation. I thought it might be steering pump related but after researching steering pump symptoms it doesn't seem to fit. Also, I feel like the issue is still there even if I'm not turning, just not as noticeable.
Could it be clutch related? I also need new sparkplugs soon, not sure if it could somehow be related to that.
wfdeacon881013.00
      10-27-2018, 03:30 PM   #5
5speed5er
Drives: 2011 M3
UPDATE: Just drove the car after letting it sit for 2.5hrs. The issue is definitely not power steering related. I am also pretty sure it isn't a problem with the engine because the tachometer is perfectly normal and no codes.
The car is shaking pretty bad when at low rpms. It isn't as bad when stopped with the car in neutral. It is much worse once in 1st or 2nd gear below 2500rpm. I think the car definitely needs new engine mounts but I'm not sure it would cause this, and certainly not suddenly.
Any ideas?
      10-27-2018, 03:35 PM   #6
EnVe46
EnVe46's Avatar
735
Drives: 14 M6 GC Comp
Any ideas?
Can you take a video with good sound of what's happening? Is it stumbling like it's having a hard time accelerating or is more like clutch slippage?
2011.5 E90 M3 ZCP
Interlagos Blau
      10-27-2018, 03:36 PM   #7
Mvy
Drives: 2008 E93 M3
were gonna need video.
      10-27-2018, 03:41 PM   #8
5speed5er
Drives: 2011 M3
There isn't any sound really. You can just feel like it through the car.
It does feel like there may be more clutch slippage but it might just be me imagining it.
I haven't mashed it at low rpm but it is accelerating with no problem when I ask it to.
      10-27-2018, 05:15 PM   #9
m3jala
Drives: Jet Black 2013 BMW M3
Since you are saying it is more noticeable when you turn the steering wheel, sounds like it is front of car.
If possible, lift the front of car and manually turn the front wheels. If it's stuck or grinding maybe something with the rotors?
      10-29-2018, 03:00 AM   #10
Erickuokwa
Erickuokwa's Avatar
188
Drives: E90 M3
Does it feel like it's hesitating in the low revs? Change out your spark plugs and see if the problem still occurs
wfdeacon881013.00
      10-29-2018, 03:03 AM   #11
Erickuokwa
Erickuokwa's Avatar
188
Drives: E90 M3
Or more so it hesitates(shakes the car in a sporadic intervals) when ur under heavy load. Maybe like turning right from a slow roll in second gear
      10-29-2018, 06:06 AM   #12
Mvy
Drives: 2008 E93 M3
Could it be your mounts are letting the exhaust move and vibrate against something? Is the vibration in the wheelwell area of the car? Another possibility is the giubo and intermediate shaft bearing are loose. Just throwing out some guesses as this is tough without experiencing the issue first hand.
      10-29-2018, 07:50 PM   #13
5speed5er
Drives: 2011 M3
Took to mechanic today. He is confident that it is the engine mounts. That is what it feels like but I am shocked at how quickly it went from fine to severe symptoms.
      10-30-2018, 05:39 AM   #14
Mvy
Drives: 2008 E93 M3
Mounts make a huge difference and do go bad fast on our cars. I just did mine last month and when mine went bad, my motor was 1/2 inch lower than after puting in new ones. Caused me issues with my cats buzzing on the heat shield. Cold start delete helped a lot with all manner of vibration in my exhaust area at start up.
      10-30-2018, 08:42 AM   #15
donnyblaze1
donnyblaze1's Avatar
Drives: E90 M3 6MT
+1 on the mounts being a likely culprit. I had some pretty similar symptoms with my E90 6mt. Had the engine mounts done, and it was a night and day improvement. Smoothed out my 1-2 shifts massively.
      10-30-2018, 09:07 AM   #16
spazzyfry123
spazzyfry123's Avatar
Drives: JTR
2011 BMW E90 M3  [5.00]
Time for Vibratechnics!
      10-30-2018, 10:00 AM   #17
Kamen
Drives: BMW M3 E92
Had a similar problem after changing spark plugs on my other car. It was running perfectly fine at idle, but as soon as put in drive or introduced yo any load( in your case that might be turning the steering wheel), the engine was shaking pretty badly. As soon as I changed the spark plugs for another set, everything worked fine. Obviously, your problem might completely different
      10-30-2018, 10:15 AM   #18
5speed5er
Drives: 2011 M3
Ok so now I have a dilemma on my hands. The car is sitting at my mechanic because I don't want to drive it until I get the engine mounts swapped (it feels really bad). However I wanted to go ahead and knock out rod bearings at the same time so I don't waste a bunch of money on labor twice.
I ordered some BE Bearings and bolts but I just got an email saying they actually ran out of stock on Friday. I have already searched and know about options from VAC and WPC treated OEMs but I've always heard you want the BEs. I am wondering what other members would do if they were in my situation?
Just go with VACs? Should I still get the BE bolts since I can find them in stock?Or if anyone knows a place with BE bearings in stock right now that would be incredible.
Thanks guys.
wfdeacon881013.00
      10-30-2018, 03:01 PM   #19
Helmsman
Helmsman's Avatar
Sweden
2538
Drives: 2011 E90 M3 ZCP
I wouldn't worry too much about the brand here, good thing to have them replaced regardless at 91k. Plenty good stories about VAC (believe they have extended clearance as well). Used ACL myself, happy. No doubt BE are good stuff but again OEM took you this far, VAC will do equally good job or better.
      10-30-2018, 06:01 PM   #20
5speed5er
Drives: 2011 M3
Thanks for the feedback. Parts ordered.
So I'll be doing rod bearings, engine mounts, transmission fluid/filter service, and differential fluid service next week.
Then in a few months I will be doing spark plugs, 4 wheel brake pad/rotor service, and brake fluid. Hoping she will be pretty well sorted at that point.
      10-31-2018, 08:43 AM   #21
Helmsman
Helmsman's Avatar
Sweden
2538
Looks the business man!
      10-31-2018, 11:47 AM   #22
PACarGuy
PACarGuy's Avatar
Drives: 2012 E92 M3 DCT ZCP
Jumping in a bit late here, but what is the condition of your tires? That could cause a grinding feeling when turning if they are excessively worn, flat spotted or unevenly worn.
2012 E92 M3 | ZCP | DCT | Space Grey Metallic | Black Novillo | BE Bearings | CF Rear Spoiler, Diffuser, Front Splitters | Black grill + side gills | DTEC 160W Angel Eyes
Search this Thread:
Advanced Search
Copyright ©2000 - 2020, vBulletin Solutions Inc.
