04-15-2019, 09:30 PM | #1 |
///Majestic
1860
Rep 2,092
Hey y'all,
My zcps have zero scrapes or scuffs but they have baked on brake dust and it's taking away from that bright silver they used to have... Some have recommend I try 0000 gauge steel wool with lots of soap and water. Does anyone recommend this? I have already used sonax and other cleaners and they haven't worked. Any help would be great! Thanks! |
04-15-2019, 09:31 PM | #2 |
Rep 12,726
i'd say no, its going to be abrasive. have you tried claying the wheels?
commedeschatons134.00 nissanite45.50 |
04-15-2019, 09:32 PM | #3 |
Rep 216
i think a strong clay will be good for this
and using that steel wool will put scuffs in your finish, whether you use water/soap or not. I think the effect you are trying to get is kind of wet sanding?? i wouldn't recommend this. even with agitation with wheel brush you cant get it to come off? maybe try sonax w/ glass microfiber and give some pressure. |
04-15-2019, 09:33 PM | #4 |
///Majestic
1860
Rep 2,092
04-15-2019, 09:34 PM | #5 |
///Majestic
1860
Rep 2,092
04-15-2019, 09:39 PM | #6 | |
///Majestic
1860
Rep 2,092
04-15-2019, 09:51 PM | #7 |
Rep 2,747
What about some brakekleen sprayed on a rag and hosed off. I would try that before steel wool.. or pool acid.. or comet with a scotch brite they need redoing anyway right, nothing to lose!
9ers
04-15-2019, 09:54 PM | #8 |
Rep 216
04-16-2019, 12:44 AM | #9 |
Rep 12,726
Siajoon what city are you in? i'm going to have some free time in a few weeks. lets mess with some cleaning products.
04-16-2019, 01:29 AM | #10 |
Rep 94
Drench them in Sonax wheel cleaner and agitate with a brush, rinse, then try clay, repeat.
Edit: May also help to try a heavier clay. Chemical guys and a few others have heavy duty. If all else fails, you can always have it compounded and polished.
2012 E92 M3 ZCP Jerez Black/Bamboo
2020 F90 M5 Comp British Racing Green/Tartufo |
04-16-2019, 09:08 AM | #11 |
///Majestic
1860
Rep 2,092
04-16-2019, 10:05 AM | #12 |
Rep 880
Drives: 2011 E90 M3, 2019 F150
Yeah, don't use steel wool. I am amazed it wont come off with wheel cleaner and a good scrubbing, let alone a clay bar. Have you tried Iron-X or a similar product? I would go for a polishing compound and a microfiber cloth before trying steel wool. Best of luck.
04-16-2019, 09:16 PM | #13 |
Rep 942
I'm in the South Bay if you're ever up this way. I would definitely recommend against steel wool for your wheels. Only glass. You're gonna end up with some micro scratches or marring.
04-17-2019, 12:32 AM | #14 | |
///Majestic
1860
Rep 2,092
It's really frustrating, it was like this when I got it from the previous owner 2 years ago, it's been like this since.. |
04-17-2019, 08:30 AM | #15 | |
Rep 3,726
Drives: 2018 M2
04-17-2019, 12:35 PM | #17 |
///Majestic
1860
Rep 2,092
04-17-2019, 08:55 PM | #18 |
Rep 2,907
Drives: 2011 E93 M3
Never ever use steel wool on wheels or any finish other than bare metal. Iron X will help loosen it, and an aggressive red or black clay will remove the embedded debris.
commedeschatons134.00 dparm3849.50 |
04-18-2019, 08:19 AM | #20 |
Rep 1,171
Wasn’t fancy clay, just used this and a lot of elbow grease
https://www.target.com/p/meguiar-s-s...E&gclsrc=aw.ds |
04-19-2019, 12:22 PM | #21 |
Rep 3,735
You will have no choice but to use some sort of abrasive material or diminishing abrasive (compound) to remove caked on brake dust if it is not coming off with clay or standard cleaners. Start by using the latter as it's less aggressive than the steel wool. If this doesn't work, you will have no choice but to use something more aggressive. This is along the lines of wanting to remove paint defects and refusing to do a correction and cutting the paint properly to remove the defects. If you opt to use the steel wool gently, and I repeat gently, you will have to use some sort of polishing compound to undo the marring caused by the abrasive afterwards and then applying your choice of protection. With today's technologies, opt for a legitimate coating to protect your wheels.
BMW PERFORMANCE SPECIALISTS. Race Engines. Suspension. F/I. Brakes. Race Preparation. Factory Service. Alignments.
OFFICIAL PARTNERS: KW. MOTON. Brembo. AP Racing. BBS Motorsport. iND. HRE. Turner Motorsport. VAC. BMW Motorsport. Facebook | Instagram | Yelp! | Flikr Phone: 949-233-0448 | E-Mail: info@mrfengineering.com |
deansbimmer3750.50 |
04-20-2019, 11:44 PM | #22 | |
Stop the hate, get a V8
3850
Rep 8,625
Instead of clay, you could also consider the Autoscrub sponges.
Past: 2011.5 M3 sedan ZCP |
